Another fuel pump thread-Mikuni
Discussion in 'Dakar champion (950/990)' started by Kawidad, Apr 8, 2007.
  1. Kawidad
    Kawidad Long timer
    Jul 9, 2005
    6,513
    Central Coast, Cal
    In conducting my own research for a better fuel pump I have been reading about how people have been exploring alternatives. It has been mentioned in several other threads that Mikuni produces several compact vaccum powered fuel pumps that could be a possible replacement. After researching this issue, I don't believe that any of them will work. Their flow rates are too low and presumably the pressure will be too low as well. (0.06 gallons/minute for the most promising unit)
    The NAPA and Facet units are still the best so far, but who knows there may be others out there.
    I still looking around and will post more as I find more solid information.:norton
  2. cpmodem
    cpmodem Orange Caveman
    Nov 29, 2004
    7,130
    masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
    :clap
  3. Pointman0853
    Pointman0853 Unregistered Gun Owner
    Apr 14, 2005
    1,566
    Douglas County, Nevada
    Already over done...:D
    Pointman
  4. cpmodem
    Nov 29, 2004
    7,130
    There can NEVER be too many polls :pot
  5. idahoskiguy
    idahoskiguy Long timer
    Jun 22, 2005
    1,162
    The flow rate on the Mikuni pump would be more than adequate for the LC8 since one Mikuni vacum pump supplies the fuel for three 44 mm carbs on my 1,000 cc triple cylinder mod motor in my modified snowmobile. It uses fuel at the rate of 8 mile per gallon when running hard, so 30 - 40 mile per gallon should not be be any problem for the vacunm pump. And in thirty years of snowmobiling I have never had a vacum pump failure, so they seem to be very reliaable.
    Just my $.02
  6. cpmodem
    Nov 29, 2004
    7,130
    How 'bout a part number, ID?
  7. cjracer
    cjracer AWD please!!
    Sep 26, 2005
    4,139
    Mukwonago, WI
    Where on the 950 can you hook up to a vacuum pulse, like you get w/ a 2-stroke crank pulse? The fittings below the carb that are normally plugged or capped are a constant vacuum, I believe.:ear
    How does the 640 ADV work the pumps. Do we need to do some drilling into the crank area? :evil
  8. Pointman0853
    Apr 14, 2005
    1,566
    No, the problem is too many TROLLS...:rofl
    Actually, I looked into using a 640 Mikuni Fuel Pump in the beginning, but the Facet was way too trick to overlook.
    Vacuum from any one of the intake manifold fittings should be enough to run it.
    Pointman
    #8
  9. LKN4DRT
    LKN4DRT Relocated
    Aug 4, 2004
    716
    Boise, ID
  10. idahoskiguy
    Jun 22, 2005
    1,162
    I was just guessing that the vacum pulse would come from the intake manifold - do not really know if this would work. Does anybody run a vacum pump on a four-stroke? On a two-stroke the crankcase provides the vacum pulse.
    Will check on a part numbers and report back.
    #10
  11. Head2Wind
    Head2Wind MotorcycleMayhem
    Mar 13, 2006
    2,711
    NorthWet Washington
    these "vacuum" pumps require a pulsed signal to operate. I do not know if there is enough signal swing (positive to negitive) available at the crankcase on a 950 to make them work properly.
    EDIT: oh, and as a alternate: http://www.aircraftspruce.com/catalog/eppages/bingfuelpump.php
    flow rate should keep up with the 950's fuel flow needs.... just need to make it oscillate.
    #11
  12. cpmodem
    Nov 29, 2004
    7,130
    "Somebody" needs to put a vacuum gauge on the crankcase vent. I would,butt I'm "busy." :D
    #12
  13. PowerCell
    PowerCell Manufacture Super Supporter Supporter
    Sep 28, 2005
    2,654
    Southern Kalifornia
    These fuel pumps run off of vacuum from the intake manifold... anywhere between the throttle plate and the intake valve. It's a small fluctuation the won't show up on a vacuum guage.
    #13
  14. uk_mouse
    uk_mouse Aquatic adventurer
    Jul 20, 2006
    2,107
    UK
    My vacuum gauges have got little damping screws in the inputs. If I connect them up to the 950 and turn the damping right down, the gauge needles bounce around all over the place. Therefore I conclude that the vacuum from the inlet manifold does pulse, to some degree at least.
    Whether it's enough to operate one of these pumps though, I don't know.
    #14
  15. PowerCell
    Sep 28, 2005
    2,654
    Southern Kalifornia
    Early model Husabergs used this same setup to pump fuel from the lower side of their enduro tanks. The pump was mounted to the tank itself, and driven by vacuum from the intake manifold. Snowmobiles and watercraft use these same pumps as well...
    #15
  16. cpmodem
    Nov 29, 2004
    7,130
    "Somebody" needs to buy one of these little jewels and hook it up to the Big Katoom, and report back to use the results. Not me, though. I'm busy :freaky
    #16
