1. eNewsletter Sign Up
Another Red Ascot, 1983 VT500 Restoration.
Discussion in 'Some Assembly Required' started by Tytan, Jan 10, 2018.
  1. Tytan
    Tytan Been here awhile
    Jan 12, 2015
    600
    The Wet Left Coast
    It's a Honda so it has to be Red !
    To make a long story very short I had this given to me by a neighbour about two years ago he was over looking at my FT and mentioned he had the same bike sitting in his back yard under a pine tree uncovered for about 6 years :hmmmmm hmmmm sounded like a good restoration project and a stable mate for my 1982 FT 500 Ascot. My Dad had a Red VT in the early 80's so that was another plus to restoring this bike.
    The FT500.
    The VT after dragging it out of the neighbours yard and after a bath, looks not too bad from 50ft away :jack I cleaned the carbs had the tank interior cleaned and sealed as it had water in it, changed all the fluids rebuilt the caliper and master cylinder, replaced the leaky fork seals and rode it a few times to make sure it was mechanically sound.
    Due to lack of space and a garage renovation, http://advrider.com/index.php?threads/garage-renovation.1272029/ it got stuffed in the shed until time and space allowed here it is on the lift waiting for tear down as the frame has a lot of surface corrosion.
    AK650, Bigger Al, Fast Idle and 4 others like this.
  2. JimVonBaden
    Feb 11, 2005
    88,712
    Alexandria, VA
    I used to lust after the Ascot back in the middle 80s!
    AK650, Fast Idle and scot_douglas like this.
  3. Tytan
    Jan 12, 2015
    600
    The Wet Left Coast
    Waiting for a specific socket so I can remove the swing arm.
    Pezz_gs, pennswoodsed and JimVonBaden like this.
  4. X5-
    X5- Been here awhile
    Jul 14, 2013
    345
    South Dakota
    You aren’t the only one!!
  5. Tytan
    Jan 12, 2015
    600
    The Wet Left Coast
    Off to the sandblaster and powdercoater this week.
  6. Tytan
    Jan 12, 2015
    600
    The Wet Left Coast
    Frame got dropped off for powder coating this week and the valve covers and carbs were vapour blasted then the carbs got an ultrasonic bath. I think I found some piston rings so the bores will get a light hone, new rings, lap the valves and new valve seals are next on the list.
    AK650, buzzword, MacNoob and 2 others like this.
  7. Scubawerx
    Scubawerx Scubawerx
    Dec 19, 2012
    763
    North Georgia
    Good work. Cleanliness is pretty.
  8. pennswoodsed
    pennswoodsed lizards,bugs and me
    Jan 20, 2007
    1,023
    Reading,Pa
    Always thought that A VTFt would make a great dirt road bike .Take a few lbs and tune(kit) the suspension and lite free breathing(not loud) exhaust !
    #8
  9. Tytan
    Jan 12, 2015
    600
    The Wet Left Coast
    The exhaust on this thing is heavy and mine sounds like the guts are all rotted so I might end up with a NOS Mac exhaust instead of trying to repair this one.
    I got the top end taken apart so I can get everything cleaned up and off to the machine shop for honing, new rings, new valve seals then get the heads and barrels sandblasted and repainted.
    #9
    AK650, jays100, Hi-De-Ho and 2 others like this.
  10. Tytan
    Jan 12, 2015
    600
    The Wet Left Coast
    It has been a hurry up and wait for parts week, still waiting on the gasket kits, piston rings and powder coated frame. I did get some new parts, new clutch cable from MotionPro, had a local shop make a new braided steel front brake line and ordered a NOS Mac exhaust. Some frame parts got sand blasted at the local Ublast place there's something therapeutic about sand blasting old parts :hmmmmm
    #10
    jays100, Hi-De-Ho and Fast Idle like this.
  11. Wes Kootenay
    Wes Kootenay Adventurer
    Feb 1, 2018
    32
    Slocan Park in the Slocan Valley, BC, Canada
    OK, I'm watching this. My, new to me, '83 Ascot VT is one sad puppy. I plan to get it 'rideable' this spring. The attached pics are from the 'good home wanted' ad - the ugly carrier is gone.
    Must be nice to have so many facilities close by, but I wouldn't trade where I live for an urban center. :-)
    Thanks for the great pics, they are a real help to me.
    Al
    BTW I guess you know there is an Ascot Owners forum? http://advrider.com/index.php?threads/ascot-owners-forum.661405/
    #11
    jays100 likes this.
  12. Tytan
    Jan 12, 2015
    600
    The Wet Left Coast
    I got a parts delivery and the frame was ready, now I need to make some assembly progress this weekend.
    #12
    jays100, DuaKembara and Hi-De-Ho like this.
  13. Wes Kootenay
    Feb 1, 2018
    32
    :lurk :beer
    Lookin' good.
    #13
  14. Tytan
    Jan 12, 2015
    600
    The Wet Left Coast
    I had ordered two engine gasket kits from the Honda dealer and was told they would take about two weeks well three weeks later and they are all of a sudden discontinued :becca I found one kit on Ebay and the second at a dealer in Fairbanks AK so I finally have the gasket kits which include valve seals so now the cylinders and heads are finally at the machine shop. Progress is slow but steady the frame is now on the lift all the threads chased with a tap and the wiring harness partially installed.
    #14
    AK650, Bigger Al and JimVonBaden like this.
  15. mikeysduck
    mikeysduck Slow Ride to Nowhere
    Jan 18, 2008
    885
    Acton Ca.
    Your moving pretty fast on this project. No short cuts. It looks great. I'm sure you have addressed this, or will shortly. Remove the frame paint for superior electrical grounding. Enough from the peanut gallery. You know what you are doing.
    #15
  16. Tytan
    Jan 12, 2015
    600
    The Wet Left Coast
    Swing arm came back from painting so now I have a rolling chassis, tail section, battery box, air box and most of the main electrical connections are complete. I found some NOS rear indicators the ones I have are not good the housings were very brittle from being in the sun the fronts are in good condition so they can be reused. Waiting for a few more parts from powder coating so I can finish assembling the front headlight, handlebars and gauges and waiting for the heads to come back from the machine shop so I can reassemble the engine. The old shock is there to hold the rear end together I will be finding some replacements.
    . IMG_2321 Resize.jpg IMG_2320 Resize.jpg IMG_2319 Resize.jpg IMG_2318 Resize.jpg
    #16
  17. r60man
    r60man Long timer
    Mar 14, 2013
    1,963
    Centralish PA
    Very pretty!
    #17
  18. mentolio
    mentolio Been here awhile
    Jul 14, 2016
    680
    Nice job, always liked those bikes.
    #18
  19. Tytan
    Jan 12, 2015
    600
    The Wet Left Coast
    More shiny bits showed up from powder coating today now I can get the footpegs, top triple clamp, handlebars, gauges, headlight etc assembled then work on polishing the aluminum part of the case covers.
    #19
    AK650, TonyKZ1 and Slytheslayer like this.
  20. Slytheslayer
    Slytheslayer Ride or Die!!
    Jan 18, 2017
    830
    Fort Lewis, WA
    Oooh pretty...lol
    #20
