Another Red Ascot, 1983 VT500 Restoration.
Discussion in 'Some Assembly Required' started by Tytan, Jan 10, 2018.
  1. Tarka
    Tarka Strangely strange. Oddly normal.
    May 10, 2007
    2,870
    Across the pond.
    I still do !
    They weren't imported over here.
    We only got the stodgy VT500.
    The Ascot is one of the best looking bikes ever to me.
    #21
  2. Tytan
    Tytan Been here awhile
    Jan 12, 2015
    539
    The Wet Left Coast
    Headlight, gauges and front electrical connections complete.
    #22
  3. Gramp-Z
    Gramp-Z Long timer Super Supporter Supporter
    May 28, 2009
    1,468
    Maple Valley , WA , USA
    Totally forgot about those , thanks a lot . Now I think I will keep an eye open for one . Nice looking build !
    #23
  4. Ghengis o reilly
    Ghengis o reilly Adventurer
    Aug 3, 2016
    12
    Lovely looking bike, Honda got it just right with that, good job you are making of it:photog
    #24
  5. Tytan
    Jan 12, 2015
    539
    The Wet Left Coast
    Heads and cylinders were ready Friday afternoon so I was able to make some progress over the weekend.
    Cylinders and pistons were all within spec after a light hone, heads got new valve seals.
    Cleaned the bores with some ATF to remove the honing oil.
    Heads and cylinders were sandblasted so I could refinish them with VHT satin black barrel paint.
    Pistons in with new rings and circlips then cylinders installed.
    #25
    Rokoneer and invisa-bill like this.
  6. DuaKembara
    DuaKembara Adventurer
    Oct 2, 2017
    42
    south east asia
    i'm looking out. great progress Sir!
    #26
  7. Tytan
    Jan 12, 2015
    539
    The Wet Left Coast
    Engine is assembled and valve clearances set ready to go back into the frame.
    #27
    MacNoob and NDMX743 like this.
  8. Tytan
    Jan 12, 2015
    539
    The Wet Left Coast
    I used a 6" orbital sander with 220 grit paper to remove the paint from the cylinder fins and side covers, new stainless allen head fasteners for the cases.
    #28
    Antti and JagLite like this.
  9. Tytan
    Jan 12, 2015
    539
    The Wet Left Coast
    My Dad came over and we were able to get the engine back into the frame. I seem to have misplaced a coolant tube for the front cylinder so I had to get one off EBay it should be here by the weekend.
    #29
  10. JimVonBaden
    Feb 11, 2005
    87,300
    Alexandria, VA
    Wow, that looks better than new! :thumb
    #30
    pennswoodsed likes this.
  11. Tytan
    Jan 12, 2015
    539
    The Wet Left Coast
    It's a runner filled the fluids and fired it up in the driveway. Waiting for body work from the painter, new rear shocks and seat from Sargent. The right side ear of the center stand does not clear with the Mac exhaust so I'll have to trim it and fabricate a bracket for the stop on the left side.
    #31
    X5-, Slytheslayer, Dutch_ and 3 others like this.
  12. Tytan
    Jan 12, 2015
    539
    The Wet Left Coast
    Soooooo close ! Needs new rear shocks then I can apply for the collector plate.
    IMG_2367 Resize.jpg IMG_2368 Resize.jpg IMG_2369 Resize.jpg IMG_2370 Resize.jpg
    #32
  13. Pressingonward
    Pressingonward Looking forward to what is ahead
    May 29, 2015
    119
    SW Washington State
    Nice job! I've got one sitting in my garage waiting for me to find the time to work on it. Similar condition to yours before you started in on it. Good to see one all cleaned up and pretty for a little inspiration :ricky
    #33
    JagLite likes this.
  14. Tanshanomi
    Tanshanomi Your Favorite Uncle Supporter
    Jul 22, 2009
    2,627
    Heart of America
    Very nicely done! That's a timeless model.
    #34
  15. Tytan
    Jan 12, 2015
    539
    The Wet Left Coast
    Put two days insurance on it and did a few shakedown rides. The exhaust is too loud and not even nice loud if there is such a thing I need to quieten it down a bit so I pulled the insert out to measure for some baffles there is no packing just the offset input-output tubes in the second picture I'm going to try the cheap DB Killers off EBay in the last picture. The jetting doesn't feel correct with the stock sizes probably because of the exhaust being almost straight piped I'll fix the exhaust first before messing with the stock jetting. If anyone has any other ideas on how to quieten an exhaust I'm all ears.
    #35
  16. 79thunder
    79thunder Been here awhile
    Sep 16, 2017
    273
    Out West
    Without packing material it's going to be difficult to really quiet the pipes down.
    You could try capping the inlet side of the output tube with an expansion plug (automotive core plug) or washer,
    then drill several holes in the sides of the outlet tube.
    Just like the decibel killer insert that you have shown.
    The idea is to get a little bit less of a straight through flow, get the sound waves to bounce around inside, it's much more effective with muffler packing,
    but it's definately worth a try.
    You could also try capping/drilling the inlet tube of the muffler, but I would do the outlet first.
    If you try the inlet, drill the cap and drill the holes larger, or with more holes in the sides of the tube, as you don't want to restrict exhaust flow, just redirect it.
    Of course a quiet factory style muffler would have 2 baffle plates and an offset mid pipe, while it could be done, it wouldn't be hard to build, but getting it installed would be a challenge and would likely require welding inside the pretty chrome mufflers, resulting in not-so-pretty chrome.
    Beautiful job on the bike!!!!
    #36
  17. Tytan
    Jan 12, 2015
    539
    The Wet Left Coast
    Thanks for the input.
    I stopped by the local machinist / vintage bike guy today with the muffler and he suggested try the DB Killer first then if it's still too loud try a straight through tube with holes the tube can then be wrapped in packing and inserted into the shell similar to most aftermarket mufflers. The cheap DB Killers have been ordered so we will see where this goes I don't mind some experimenting to see what works.
    #37
    79thunder likes this.
  18. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    4,061
    Long Beach, California
    #38
  19. Tytan
    Jan 12, 2015
    539
    The Wet Left Coast
    The Hagon shocks arrived which were the last cosmetic items needed so then I was able to take some pictures and send in the application for collector status. I should get the collector plates in about a month then I can get cheaper insurance and put some miles on.
    #39
  20. jays100
    jays100 Been here awhile
    Aug 1, 2006
    353
    CT
    nicely done!
    #40
