Antifreeze getting lower and lower (???)
Discussion in 'Dakar champion (950/990)' started by eugeneorange, May 27, 2004.
  1. eugeneorange
    eugeneorange that's gonna leave a mark
    Nov 3, 2003
    306
    I have about 500 mi on my "950S" (unfortunately all just street). The antifreeze was slightly above "MAX" mark (on the white plastic bottle) when I got the bike. After VERY easy 500 mi it is at slightly above "MIN" mark.
    I never overheated it or pushed it hard and there were no antifreeze leaks or spots under the bike. I don't think that's normal. I will tell my dealer when I take it in for the 600mi service. But I wonder my self, What could it be? What should be checked? What type of antifreeze does the 950 use?
    eugeneorange
  2. barbasma
    barbasma 100% CAROTONE
    Aug 19, 2002
    1,821
    Sondrio (In the middle of the Alps) Italy
    don't worry.... it's normal adjustement at the first km... after the level stay on the line...
    pay attention if the bike goes down... the liquid goes out from the vent tube...
    refill with water for cooling system.... :thumb
  3. woodsrider
    woodsrider .........................
    Nov 22, 2003
    587
    Colorful Colorado
    Are you comparing coolant levels with the bike at the same operating temperature (e.g., cold)??
  4. Doug Matson
    Doug Matson Long timer Supporter
    Aug 25, 2003
    3,226
    Torrance, Ca.
    Make sure you don't rely on just looking at the coolant is the overflow tank to check your coolant. Mine was fine in the tank, but the radiator was half full! So do your self a favor once in a while and look into the radiator.
  5. Doug Matson
    Aug 25, 2003
    3,226
    Torrance, Ca.
    Why did this just post three times?
  6. Doug Matson
    Aug 25, 2003
    3,226
    Torrance, Ca.
    Sorry for wate of space, (the rest of the story will be finished in a month I hope)
  7. kkug
    kkug Been here awhile
    Feb 9, 2004
    981
    Escondido Ca .USA
    I 100% agree with Doug. My bike was the same way.
    Pull the covers of and look in the radiator. TRUST ME!
  8. eugeneorange
    Nov 3, 2003
    306
    Thanks for the replies.
    What type/brand of coolant can I use?
    #8
  9. Greg Minor
    Greg Minor The Trespasser
    Oct 19, 2003
    2,322
    Escondido Ca
    Hey Ken how did you like your M21's on the street
    #9
  10. woodsrider
    Nov 22, 2003
    587
    Colorful Colorado
    I like Engine Ice. I've always used it in my 450EXC, a hot-running motor. It is used "full strength"; no 50/50 dilution.
    #10
  11. eugeneorange
    Nov 3, 2003
    306
    Can Engine Ice be just added to the "stock" coolant, or do I need to flush the system when switching brands? The coolant in the overflow tank is now on or below the "MIN" mark. I have only 80 more miles to go before my 600mi service. Is it safe to ride it the 80 miles, then I'll have it done by the dealer.
    #11
  12. Doug Matson
    Aug 25, 2003
    3,226
    Torrance, Ca.
    No don't just add Engine Ice, just add some water and if I was you I would have a look inside the radiator. When you switch to Ice they have to drain and flush the system. Have them agree to follow the instructions. If you have the time you should ask to watch the 600 mi service to learn about the bike.
    #12
