Antigravity Batteries Labor Day Weekend Specials!
Discussion in 'Vendors' started by Antigravity, Aug 29, 2019.
  1. Antigravity
    Antigravity Been here awhile
    Sep 6, 2010
    363
    Los Angeles
    Hi everyone. Just wanted to be sure to let you all know about the great specials we'll be running this weekend. Whether you're on the hunt for a new battery for your bike or maybe even your car or if you've been looking to get a Micro-Start jump starter for a little added security we've got you covered. Coupon codes listed below. As always thanks for being our customers and have a great weekend of riding!
  2. diverjim
    diverjim Adventurer
    Jan 28, 2019
    12
    Florida
    Thank You so much for the Discount
    I received the XP-3 and it is exactly what I wanted.
    I put the quick connect cables on the battery today.
    I can hardly wait to have a dead battery.
    I also wanted to thank you for the free gift.
    Excellent products and great service.
  3. Antigravity
    Sep 6, 2010
    363
    Los Angeles
    Glad you like it.... thanks for the comments!
  4. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    15,906
    Tucson, AZ
    @Antigravity, any plans to offer a battery suitable for the 2018+ Africa Twin?
  5. Antigravity
    Sep 6, 2010
    363
    Los Angeles
  6. swimmer
    Oct 9, 2007
    15,906
    Tucson, AZ
    The 2018+ comes with an OEM Lithium battery and it's not a standard case size. Nobody offers a non-OEM replacement that I have been able to find. The information about the OEM battery is linked below.
    https://www.eliiypower.co.jp/english/vc-files/pdf/pdf_eng/20180308_Release.pdf
  7. Antigravity
    Sep 6, 2010
    363
    Los Angeles
    Ok I see what they are doing... they did that for the MX bikes as well, use a non-standard size... The battery for the CR450 is like $400 dollars. Its total boloney to make these proprietary sizes.. but many companies do this as another revenue stream. Let me double check that sizing and see if we offer anything close.
  8. swimmer
    Oct 9, 2007
    15,906
    Tucson, AZ
    Yes, in order to save their customers some money, the local Honda dealership has been stearing owners of Honda dirt bikes with the OEM lithium battery to aftermarket options that while they may not be the same case size, they do fit. This option doesn't seem possible for the '18+ Africa Twin. Once owners of these bikes start needing replacement batteries there is an opportunity for someone in the aftermarket battery business as the new OEM battery will cost someone between $500-$600 bucks depending on if they get it local or online.
    #8
  9. Antigravity
    Sep 6, 2010
    363
    Los Angeles
    Yes, and the fact is they are only giving 6 real Amp Hours.... for $500-600 bucks. That is crazy costs. You can buy our Automotive Battery with 24Amp Hours and WIRELESS built-in Jump Starting for just over $600 dollars, and it has a Keyfob that wirelessly will control the Battery if you over-discharge it. So we'll look into this. If we can find they use this battery in several models it makes it more worthwhile for us since the tooling is very expensive to make a new Battery size. But I assume they will be using this Battery across many models in the future so that is good and give us more incentive to make it.
    #9
  10. Antigravity
    Sep 6, 2010
    363
    Los Angeles
    Is there any chance you can get me a picture of the how tight the fit is with the current ATwin battery?
    #10
  11. swimmer
    Oct 9, 2007
    15,906
    Tucson, AZ
    I can try to do that this evening. I know there isn't much space on any side of the battery.
    #11
  12. swimmer
    Oct 9, 2007
    15,906
    Tucson, AZ
    Here is a picture. Whether the picture is clear enough to portray it or not, the fit is pretty close. Maybe 3mm of movement in each direction.
    #12
  13. RailwayRog
    RailwayRog Been here awhile
    Jan 30, 2011
    194
    St George, UT
    Friday The 13th/Full Moon sale?
    Didn't think so.
    #13
