Any Honda Dominator NX650 owners out there ?
Discussion in 'Thumpers' started by KeithDommirider, Jul 31, 2007.
  1. Minidragon
    Minidragon Long timer
    Feb 10, 2014
    1,331
    Overthere
    The reason for you wanting the XRL exhaust system is because you have a leak between the header/mid pipe right ? What did you do to prevent the leak ?
    Your looking for double or single exhaust system ?
  2. Citronodlaren
    Citronodlaren Adventurer
    May 24, 2018
    19
    Sweden
    It seems to me that most people choose to keep the crankcase breather system as it is. It do no harm I suppose, but it is in the way and looks ugly. Saw a kit somewhere for removing it. May I ask fellow inmates for opinions on this issue?
  3. Bounder
    Bounder Typing...
    Mar 2, 2011
    1,988
    West Cork, Ireland
    Are you referring to the Crankcase vent on top of the case to the airbox or the system that runs from the front of engine to the pump at the side and then upwards?
    Its easy to do away with the pump and block the two outlets in front of the engine. You have to block all the little ports as well, on the carb.
    The crankcase top to airbox is not that bad I think, it stops dirt getting into the crankcase, you have to use a small unifilter to stop dirt entering but water is also a consideration if you decide to remove that part of the system.
  4. rexelstar
    rexelstar Been here awhile
    Jul 5, 2014
    108
    Netherlands
    The crankcase breather system's made by Honda are mostly made for emission regulations in those day's.
    I remove these and use a small unifilter on the crankcase.
    The air filter box some rebuild/adjustment.
    The (older) Honda breather system.. it's some sort of 'drinking your own piss'.
  5. rexelstar
    Jul 5, 2014
    108
    Netherlands
    Bought a 1990 with 15.000 km. Will clean it up and restore necessary parts.
    Would not run properly under 2500 rpm.
    Carb given a clean and revision. Same problem so changed the CDI with a 12 euro China replacement, and now running perfectly.
    Have a xr650r carb which will be tested on this bike.
    Install the later -MAN- manifold and airbox tube to make it fit properly. The carb is 8mm longer then the stock carb, so removed these 8mm at the cilinder side.
    Spend a lot of hours polishing, repair etc. on the plastics.. but like new again;)
    mitsosvl likes this.
  6. bikerjim197
    bikerjim197 n00b
    Jan 12, 2015
    2
    This thing is great, I know this is an old post but do you have any more details of your fairings and side panels? Are your side panels home made?
  7. PPleven
    PPleven Adventurer
    Feb 4, 2014
    35
    Bulgaria
    Anyone with experience with ride to Nordkap?
  8. Griff2
    Griff2 Griff
    Jul 17, 2010
    1,665
    Wicklow Ireland
    I think there is at least one member on here from those parts. I rode Norway years ago but only made it as far as Bodo when my back tyre on a Z1000ST started to wear prematurely and I was unable to get a replacement so the Nortkapp was never reached.
    PPleven likes this.
  9. mattmacklind
    mattmacklind Adventurer
    Jul 4, 2019
    14
    Kansas City, MO
    I just picked this up to go with my NX250...
    Kolb Driver likes this.
  10. kylkim
    kylkim Adventurer
    Jun 17, 2016
    34
    Oulu, Finland
    The only thing I know from our shop in Finland, is that the roads in the north of Norway are rougher than in most places, so you might need a tire replacement afterwards. Also, it costs something like 50 euros to go to the very top.
    PPleven likes this.
  11. Griff2
    Griff2 Griff
    Jul 17, 2010
    1,665
    Wicklow Ireland
    Some very nice specimens still available in the US obviously. Good ones are rare over here nowadays.
  12. PPleven
    PPleven Adventurer
    Feb 4, 2014
    35
    Bulgaria
    About the handlebar risers: How is the maximum height without any additional changes of the clutch cable, the brake cable and etc.?
    Please, suggest me product in Europe.
    Thank you!
  13. MartiniUp
    MartiniUp Long timer
    Jul 14, 2010
    3,337
    TX
    My nephew has one just like that in TX he is thinking of selling. Only thing missing is the little windshield. Less than 6000 miles I think.
  14. Knobby-by-nature
    Knobby-by-nature Adventurer
    Mar 13, 2018
    11
    Richmond VA
    I just did a '07 dl650/vstrom shock swap on my '88 nx650. Very disappointed with how weak the spring is. No preload the bike is bottomed out by its own weight. Preload and dampening maxed out i have 2" static sag and 4-3/4" race sag. Im about 180lbs with gear and tools.
    Does anyone else have this setup? Trying to decide if i want to change spring rate or just start over with a different shock
  15. Griff2
    Griff2 Griff
    Jul 17, 2010
    1,665
    Wicklow Ireland
    First pic of 2020 taken yesterday. The Dominator normally hibernates at this time of year especially because of the salty roads, but yesterday I needed to run the X-Adv to dry it after a wash. The roads were dried out and salt free for a few days after unseasonably warm weather so I took the opportunity to take the Dom out for a short spin also to keep it fresh. Quite a contrast in style between two bikes from the same manufacturer almost 30 years apart.......
    rexelstar and jethrocephus like this.
  16. Bounder
    Bounder Typing...
    Mar 2, 2011
    1,988
    West Cork, Ireland
    Looking good Griff!
    Back to work today, I was thinking about a spin but just didn't get time.
    I did see a good few guys about though no doubt blowing off cobwebs, a ZZR1400 and a Deauville 700 both passed me yesterday.
    I can't believe how well your engine looks, mine is much patchier then yours.
    Griff2 likes this.
  17. Griff2
    Griff2 Griff
    Jul 17, 2010
    1,665
    Wicklow Ireland
    Hmmmm work. Fortunately I'm retired and don't miss work a bit :)
    The motors not bad as You say, but not perfect either. Very difficult to keep that original paint in place over the years. The previous 2 owners did a good job and I'm doing my best albeit it has had more use in the few years I have had it than in the previous 25 on average.
  18. Kolb Driver
    Kolb Driver Been here awhile
    Oct 21, 2016
    159
    Kingsport, TN
  19. Bounder
    Bounder Typing...
    Mar 2, 2011
    1,988
    West Cork, Ireland
    I got mine from IGNITECH.cz they have a reasonable website . Mine has been working for the last 5 years no issues.
    Bell driver likes this.
