Any Honda Dominator NX650 owners out there ?
Discussion in 'Thumpers' started by KeithDommirider, Jul 31, 2007.
  1. 59kahuna
    59kahuna Adventurer
    Jul 23, 2018
    18
    AU
    What's everyone doing for footpegs ? They're tiny ! Cant seem to find any aftermarket options
  2. Bounder
    Bounder Typing...
    Mar 2, 2011
    2,045
    West Cork, Ireland
  3. Lajbi
    Lajbi Been here awhile
    Mar 11, 2016
    121
    Budapest, Hungary
    Anakee wild: started with 8mm depth, after 2500km it had 6.6mm, but after 8400 it has still 5.5mm... If it goes 14k, good for two rear mitas e09.
    Well, I found something I think. The "rubber" in the choke plug was destroyed. Cut other rubber to the place. The idle is better too. I'm don't know the consumption yet, just 100km test ride was done.
    Air filter: changed just pefore lockdown, not too much km in it (HFA 1612). There is some oil moisture evn in the air box...
    The oil consumption is good for me, usualy 2-4dl for change to change, depend on usage (for example hot weather highway).
    Thanks for the cleaning tip.
    Bye,
    Lajbi
  4. 59kahuna
    59kahuna Adventurer
    Jul 23, 2018
    18
    AU
  5. grease pants
    grease pants Been here awhile
    Jul 31, 2013
    151
    oceanside
    I posted this earlier an here's my fix, not as wide as I like but way better than before
    Works Connection 1" Footpeg Widener and a stock 950/990 KTM Adventure brake lever pad, the KTM bit needs a little massaging to sit right before you weld it, but really not much.
    [​IMG] [​IMG] [​IMG] [​IMG]
  6. 59kahuna
    59kahuna Adventurer
    Jul 23, 2018
    18
    AU
    Ta . Will do same although welding wont be as neat
  7. 59kahuna
    59kahuna Adventurer
    Jul 23, 2018
    18
    AU
    Also , I've been trying to find "Dave's mods" . anyone know the link , because the link I found on 4strokes.com wont load up . Cheers
  8. 59kahuna
    59kahuna Adventurer
    Jul 23, 2018
    18
    AU
    Another question . Do the xl650 engine parts fit the nx650 ? To do an engine rebuild , can you use xl650 parts ?
  9. Lajbi
    Mar 11, 2016
    121
    Budapest, Hungary
    59kahuna likes this.
  10. Lajbi
    Mar 11, 2016
    121
    Budapest, Hungary
    Mostly. AFAIK the xr650l stroke is 0.6mm longer than nx650. Different gear ratios, but xr650l owners often swap to domi's 2nd and 5th gear.
  11. 59kahuna
    59kahuna Adventurer
    Jul 23, 2018
    18
    AU
  12. TCBronson
    TCBronson Been here awhile
    Sep 16, 2007
    242
    Arkansas
    Will the lower front fender fit on a 2018 XR650L with some modifications? Where can I buy one?
  13. Lajbi
    Mar 11, 2016
    121
    Budapest, Hungary
    Hard way I think. First, very difficoult to get plastics for this old bikes. For example, If I convert my nx650 high-fender, even then don't sell the fender and other front plastisc.
    Second, there is not just the fender. There is a metal brace between fork legs (6 on picture), and quite special screws to hold the other plastisc too. So, you need to fabricate a special fork brace. But thus must be quite thin, becouse nx650 bolt on the fork...
    https://images.cmsnl.com/img/partsl...r-front-disk-cover_bigecy2n41f__0700_147c.gif
    But why do you want low fender on xr650l ?
  14. TCBronson
    Sep 16, 2007
    242
    Arkansas
    I like the look of the lower fender. The XR650l looks too much like a motocross racer wanna be bike.
    Thanks for your response!
  15. Bounder
    Bounder Typing...
    Mar 2, 2011
    2,045
    West Cork, Ireland
    The new yamaha T700 has a low mount front fender, it would be a lot easier to get than a NX650 version. It will require some work though as that bike has USD forks
    TCBronson likes this.
  16. Bounder
    Bounder Typing...
    Mar 2, 2011
    2,045
    West Cork, Ireland
    If you want to look around other bikes from that era that had low front guards were the Kawasaki Tengai. Suzuki DR650RS and the Yamaha XT600z and latterly xt660z
  17. Kolb Driver
    Kolb Driver Been here awhile
    Oct 21, 2016
    175
    Kingsport, TN
    I also like the lower fender look, here is my Kawasaki KLR650 from years ago, took off the rubber fork gaiters added an aftermarket front fender. P1020705.JPG
  18. Undercover Poe
    Undercover Poe Been here awhile
    Sep 26, 2013
    800
    Southern New England
    Wanted to buy a nx650. Please contact me if you have one for sale in the Northern mid Atlantic region or New England region. Thanks
  19. TCBronson
    Sep 16, 2007
    242
    Arkansas
    Thanks for the suggestions, I will check in to it, but I don't think any of those bikes were sold in the US.
  20. 59kahuna
    59kahuna Adventurer
    Jul 23, 2018
    18
    AU
    Ive broken the bottom right pinch bolt off the front forks . About 5mm inside . Does this stud come out ? Easyout job ? Anyone done this before ?
