Any Honda Dominator NX650 owners out there ?
Discussion in 'Thumpers' started by KeithDommirider, Jul 31, 2007.
  1. mas335
    mas335 xendurist
    Jun 17, 2006
    2,760
    Advance, NC
    Kingsport is a easy drive here! I just posted it, details can be found in the FM. Thanks,
  2. Kolb Driver
    Kolb Driver Been here awhile
    Oct 21, 2016
    206
    Kingsport, TN
    I have been looking and can't find it. Can you send me a link?
  3. marret
    marret Transient Supporter
    Jul 7, 2009
    843
    FL and VA
  4. mas335
    mas335 xendurist
    Jun 17, 2006
    2,760
    Advance, NC
    My NX is has sold to a fine gentleman. Soon I will be posting a large list of used and NOS parts for a NX in the flea market
    DSC00708.JPG . Thanks,
    scrambler66 likes this.
  5. scrambler66
    scrambler66 Been here awhile
    Oct 5, 2011
    789
    Germany
    Lajbi, run and mas335 like this.
  6. Kolb Driver
    Oct 21, 2016
    206
    Kingsport, TN
  7. 2manyrides
    2manyrides shifty charactor
    Aug 17, 2008
    2,858
    Citrus Heights Ca.
    Current bid $775... I wonder how high it will go? At a glance in the distant pictures it looks to be in pristine shape. When you get a chance to see the different components close up you see how there are scratches everywhere and rust.
  8. mas335
    mas335 xendurist
    Jun 17, 2006
    2,760
    Advance, NC
    FWIW, it appears to have a steel braided brake line, changed handle bar, missing seat strap, and fork reflectors. I think the rear chain ring has also been changed to one much smaller than the original.
  9. Rockman
    Rockman Been here awhile
    Jan 26, 2007
    750
    Inverell, NSW Australia
    Anybody know a source for the connector between the carbie and the airbox (no. 20 on parts diagrams)? Mine has split and they seem NA on the searches I've done.
  10. PistonPants
    PistonPants Crankcase Scavenger
    Jun 11, 2008
    895
    Cantwell, AK
    Is the same part for an XR 650L compatible?
  11. Griff2
    Griff2 Griff
    Jul 17, 2010
    2,324
    Wicklow Ireland
  12. scrambler66
    Oct 5, 2011
    789
    Germany
  13. Griff2
    Griff2 Griff
    Jul 17, 2010
    2,324
    Wicklow Ireland
  14. Rockman
    Jan 26, 2007
    750
    yes it is the no. 20 on the diagram above that I am looking for. looks like i'll have to repair the one i have.
  15. Oudaios
    Oudaios n00b
    Apr 11, 2021
    2
    Middle England
    Hi Folks
    I'm new to the forum and have recently bought a nx650 that has been part way converted to a flat tracker / scrambler.
    The forum has already been a source of great advice and inspiration, and now I'm looking for some collective wisdom. I have completely stripped the bike back to the frame in prep for powder coating and have found that the previous owner has moved the head breather pipe that connects to the oil tank in the frame.
    The new pipe has a very small diameter and has been sealed in place with epoxy. The old position is welded over and also sealed. He did this to fit a CG125 tank - note the welded on threaded lug, which is a tank mount. The small pipe has got to go - as does the epoxy!
    Here are the questions: I'm considering reinstating the breather tube (drilling and brazing a new pipe in place); however, I have seen some other conversions that have moved the position elsewhere on the oil tank to help fit a new petrol tank. Does anyone know what other positions work? Does the breather pipe just need to go into the top of the oil tank above the resting oil level as indicated by the dip stick?
    Any help is gratefully received. The Dommie is a 1989 bike. Thanks
  16. scrambler66
    Oct 5, 2011
    789
    Germany
    hi,
    welcome to the club.
    The breather pipe (überlaufstutzen) should be a bit above max oil level (ölstand max)
    The frame is made of very thin sheet metal with reinforcements inside - maybe the filler neck (thicker steel) would be a good place for the breather pipe. This way you could also enlarge the oil capacity a bit.
    Lajbi likes this.
  17. Oudaios
    Oudaios n00b
    Apr 11, 2021
    2
    Middle England
    Thank you so much. That is incredibly helpful and the picture is brilliant!
    I was wondering what the inside of the oil tank looked like. I think the original position is likely to be the best but I can see that higher up is also an option. Much appreciated Scrambler66.
  18. wakiem
    wakiem n00b
    Apr 18, 2021
    1
    Belgium
    Hi everyone, might be joining this club very soon! Going to check this one out this week. Don't have any experience with working on motorcycles yet but I wanna learn to customize bikes, so I like that this one already has the scrambler look but is not exactly how I want it to look. Should allow me to start doing some modifications without having to start from scratch. Only thing I'm worried a bit about is the drum brake. Have never had a bike with a drum brake but been reading this thread and seems like a lot of people want to get rid of it. Is it really that bad?
  19. 2manyrides
    Aug 17, 2008
    2,858
    Citrus Heights Ca.
    It is fine. Don’t worry.
    wakiem likes this.
  20. Rockman
    Jan 26, 2007
    750
    Any suggestions for a front master cylinder sight glass? Mine has disintegrated.
