Any legitimate scientific studies on varying chain lubes?
Discussion in 'Thumpers' started by fishugly, Aug 10, 2018.
  1. fishugly
    fishugly Been here awhile
    Jan 5, 2007
    152
    Everyone has their favorites that they swear are the best.... and there's tons of anecdotal evidence. Not to deride this evidence or other knowledge, but with as many chain lubes on the market, and as many chains are in use around the world on the many different pieces of machinery and equipment, I'd think there'd be some tests to put what seems like a regular debate to rest.
    Good or bad, back in my young MX days, I wired brushed the chain (non o-ring) then spayed copious amounts of blue Bel-Ray on. In recent yrs, I've used diesel to clean my chain then I soaked it in heavy weight motor oil, as per the manual.
    I'd like something less messy though, less time consuming, something that won't fling a bunch of oily gunk on to my riding clothes and gear when touring hundreds of miles from home.
    Maybe at the end of the day, the exact lube matters less then simply keeping the chain clean and lightly lubed with something. The thought of a small can of WD40 doing both sounds awfully tempting considering my minimal luggage on backcountry tours, availability, versatility, and low cost. But it's a "water displacement" and not a "chain lube".... and I know many people think it's a really dumb idea. Others think not. Where's the science to prove it either way.... or any "chain lube" for that matter?
    (I watched one Youtube vid stating WD40 didn't degrade the o-rings but didn't consider it overly scientific).
    Open to suggestions... something that isn't messy that comes in a small container. Dry lube with teflon? A wax based lube? Non-spray lube? ??
  2. 9Realms
    9Realms Drawn in by the complex plot
    Jul 23, 2010
    5,152
    Central Mn
    Bel-Ray Super Clean Chain Lube
    (dries white-ish gray, no fling) It's what I use after a chain cleaning, and then I apply it every several hundred miles or so.
    Once in 500-600 miles probably just fine, but I am a tad fanatical. I get it local to me at Bob's Cycle (see the web) and they offer it in two sizes, or Dennis Kirk, Amazon, etc.
    https://www.denniskirk.com/bel-ray/...XACh3UVwDOEAQYASABEgIiIvD_BwE&ad=244288898343
    :clap
    oldenuf likes this.
  3. oldenuf
    oldenuf Been here awhile
    Mar 16, 2010
    849
    Port Angeles, WA
    No testing here, but for off-road use with lots of dirt, dry and wet, I have gone to the dry formulas. Which don't make as much of a grinding compound out of the dirt and lube. Sprocket and chain wear is way down and staying in good shape. Nice thing is not near as much fling off the chain and a lot cleaner, especially around the cases and counter shaft sprocket. Have mainly gone with the Honda Pro with moly, also the Bel Ray super clean.
    Big Tall Bastard likes this.
  4. Navin
    Navin Long timer
    Sep 22, 2009
    20,176
    No lube is good lube.
  5. longhaul747
    longhaul747 Long timer
    May 17, 2013
    1,187
    Bothell, WA
    Over the years I have used a lot of different brands and types of chain lube from several manufactures. Some were obviously better then others but one brand seems to stick out for lasting the longest plus being the cleanest and easiest to apply. Liquid Performance Premium Chain Lube. Sadly it seems to be discontinued and hard to find. I bought a few cans off ebay last year for to much money!
    In the past it seems like I was always cleaning my chain and reapplying lube which would always fling off making a mess. With this stuff you clean the chain and apply it and then you are good for the next 600 to 800 miles and typically you don't always need to re clean and you can just spray another coating of chain lube on. This is my unscientific observation using many brands over the years!
  6. Bultaco206
    Bultaco206 Back-to-back motos suck Supporter
    Feb 11, 2007
    20,595
    Mineral Point, WI
    Plebeian, Shooter1, sasho and 6 others like this.
  7. Schmokel
    Schmokel In desperate need of a nap.
    Jun 29, 2015
    13,384
    Up. And to the right.
    Spit on it.
    mrgrimm, FoggRider, Bitingdog and 3 others like this.
  8. PineLaneRider
    PineLaneRider Been here awhile
    Dec 25, 2016
    518
    Between Michaux and Tuscarora State Forests
    All very scientific...:deal
    #8
    Plebeian, Beezer, Bitingdog and 2 others like this.
  9. Grreatdog
    Grreatdog Long timer
    Apr 6, 2007
    26,470
    Annapolis, MD
    #9
    Plebeian, GR0NK and Navin like this.
  10. timeOday
    timeOday Long timer
    Jun 20, 2008
    2,163
    New Mexico
    Any studies would probably be in an environment where the chain is not being constantly doused with dirt and sand.
    WD40 works great if you are a fair-weather rider. I don't use anything more than that offroad except on multi-day trips when the bike will be sitting out.
    Even onroad, I don't think anything less than a continuous oiler has any real effect on reducing sprocket wear. But there I use a heavier lube so I can be really lazy about maintaining it.
    #10
  11. Navin
    Navin Long timer
    Sep 22, 2009
    20,176
    Slather grease up n down your exposed male fork leg and go ride around in the dirt.
    Then apply science and get back to us. It is not 1970.
    #11
    Dirtleg, Bultaco206 and GR0NK like this.
  12. GR0NK
    GR0NK Got some screws loose!
    Sep 24, 2006
    10,055
    Stuck in 80s
    Sean :thumb
    #12
  13. flei
    flei cycletherapist
    Apr 1, 2013
    7,898
    Western Mass.
    CHAIN LUBE THREAD? WOW! WE NEEDED MORE OF THESE! I'M IN! :fpalm
    #13
  14. Navin
    Navin Long timer
    Sep 22, 2009
    20,176
    Supposings I dew wanted to changing my chain lube, where can I find a wrench to fit the chain drain bolt and is it some crazy metrical size or what?
    #14
  15. pigjockey
    pigjockey Hognuts the T-bagger
    Jan 25, 2014
    2,518
    Wisconsin A half dozen miles from ROAD AMERICA
    Where did they put the add and full marks at? This shit's confusing.
    #15
    Dirtleg, Bitingdog, Navin and 2 others like this.
  16. Bultaco206
    Feb 11, 2007
    20,595
    Mineral Point, WI
    There are no marks. You just click on a link.
    #16
    Dirtleg, jules083, Bitingdog and 5 others like this.
  17. tHEtREV
    tHEtREV Encouragement award recipient. tEAM iDIOT.
    Apr 14, 2007
    11,304
    Middle Park, Brisbane, Australia
  18. pigjockey
    Jan 25, 2014
    2,518
    EVOO?
    #18
    CDN Rick likes this.
  19. Navin
    Navin Long timer
    Sep 22, 2009
    20,176
    You should use a chain kettle so it audibly whistles when its boiling. Or a microwave.
    #19
    Dirtleg, Bitingdog, FoggRider and 4 others like this.
  20. Navin
    Navin Long timer
    Sep 22, 2009
    20,176
