Any updates on cat deletes and tunes for the 790?
Discussion in 'Parallel World (790/890)' started by doctorblanco, Aug 20, 2019.
  1. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,016
    SC
    My guess on the Arrow pipes bulge is that it's a solution that more closely mimicks the converter to eliminate tuning issues. The limitation that piggyback tuners have is that they have defined blocks and values of adjustment, at least all the ones I've fooled with. So say the factory exhaust setup requires a lean spot or bump in timing at a defined spot in the map due to it's design, then you change the exhaust (or any other hypothetical mod) that changes the dynamics so that lean spot/ timing bump is no longer required, it now needs a smooth fuel curve in that spot. So with a cracked or directly tunable ECM you can do exactly what you need but with a piggyback tuner you can only adjust the area contained in that particular cell by a positive or nagative value, so your basically taking a predefined segment containing the lean Spike and moving the entire thing toward the rich side which fixes part of it but makes other parts richer than they should be. Now it's not some massive section of the map in each cell but it can create difficulties, flat spots/hesitations in some situations that can't be entirely fixed. And that's all considering your in closed loop running off the map directly. Hopefully that makes sense... Open loop using the ECM's "auto tune" is a little different.
    I contacted Bren tuning to see if the 790 was on their radar and they said it wasn't but that they may look into it. They did offer flash tunes for the 1290. They are a top notch tuner, I had their tune in my 1299 and it turned a very refined bike into near perfection.
    #41
  2. TrailTrauma
    TrailTrauma Nemophilist
    Jan 17, 2012
    4,687
    Ontario .. Superior
    Thanks for the explanation. This is why I keep going back to Rottweiler's mid pipe - we should know that before we chose a new mid pipe IF we are to fully appreciate the tunes/performance he achieved with decat'ing. IOW's if he used an Arrow mid pipe which I suspect he did, and we use a straight pipe, perhaps we shouldn't share the same confidence in how well our bike will run, or whether we'll avoid lean areas here and there. I'm not a tuner, so I don't know if mid pipe differences make a bikes performance apples and oranges or golden delicious and granny smith ;)
    #42
    Toddv likes this.
  3. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,402
    Cremona, Italy
    My guess on the Arrow cat delete pipe is much simpler: I'm italian and so they are :D
    I mean, IMHO they made the pipe so that it looks like the cat is still there.
    A straight pipe would not pass our biannual inspection.
    #43
    Toddv likes this.
  4. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,016
    SC
    Good thought! It might be enough to fool them?
    #44
  5. Salzig
    Salzig Long timer
    Oct 17, 2008
    1,402
    Cremona, Italy
    I guess so.
    They also do exhaust fume analisys, but it's far from accurate.
    Last year my dirt bike passed the inspection despite me forgetting the choke engaged :lol3
    #45
  6. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    1,771
    Denver, CO
    All ECUs use cells to set fueling whether piggyback or stock. It's not a limitation it's standard
    #46
  7. amschnellsten
    amschnellsten Been here awhile
    Jun 20, 2011
    181
    Cincinnati
    Toddy is referring to blocked cells and the inability of some piggybacks to segment.
    #47
    Toddv likes this.
  8. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,016
    SC
    Sorta... Stacking cells on top of cells that are not the same size does not give you full control of the map. I've seen factory maps and have spend a fair amount of time fooling with piggyback maps, they are not the same. All the factory/original maps that I've seen in comparison to piggyback controllers are adjustable on a much more precise (higher cell count) scale. So with an aftermarket controller you are probably adjusting 4 or 5 cells (just a guess) of the factory map at a time up or down, so if there is a feature on there that you really need to change or smooth out you can't, you can only move it around along with the section of map around it. It's rarely a big deal unless you are trying to work out a flat spot under a specific condition. I'm not a pro ECM tuner and my observations may not tell the whole story, but that's my experience.
    I've had to tune out factory flat spots with piggyback controllers using fuel and ignition maps and it can be tricky and requires some compromise. Especially when they do funky stuff with the timing to keep NOx at bay during tip in... Again, they will normally get the job done ok, but it's just not the ideal way to go at it. Not to mention the other things you can adjust once the ECM is cracked.
    #48
  9. brianbrannon
    Dec 15, 2009
    1,771
    Denver, CO
    Dynojet software has cells every 250 rpm. Do you actually think you need more resolution? You aren't riding an F1 engine
    #49
  10. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,016
    SC
    Sometimes it takes more control than a open loop only piggyback controller can provide if you want a properly running and efficient bike.
    If you're okay with either disabling closed loop and loosing the a self tuning ability of the ECM and the fuel economy/efficiency/flexibility that goes with it, or are only concerned with correcting the fueling above 80% throttle where the bike defaults to open loop (or wherever this bike does) and aren't concerned with tweaking anything else on the bike, a piggyback controller is where you should go. I'm waiting to see what else comes along before I go that route.
    #50
    braaap! likes this.
  11. brianbrannon
    Dec 15, 2009
    1,771
    Denver, CO
    I'm not putting either on mine it runs fine. Just pointing out your incorrect information and unfounded prejudice against piggyback ECUs
    #51
  12. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,016
    SC
    lol ok. A bit combative over the limitationss of piggyback controllers for some reason? What exactly did I say that was false? I missed that part... I'm not going to argue with someone that just wants to be right because they said so but if you have something to add I'm all ears. If not I'm done and you're free to have the last word...
    #52
    1coolbanana and kzeb like this.
  13. Orfeas
    Orfeas Been here awhile
    Sep 7, 2014
    138
    Arrow Decat is here:
    #53
    macaw1us, kzeb, Toddv and 2 others like this.
  14. kubcat
    kubcat Been here awhile Supporter
    Sep 22, 2016
    593
    Upstate NY
    That's the first pic I've seen of the inside of one of those bulges on a decat pipe. I had previously assumed that it was all smooth walled, with a diameter increase at the bulge, but now I see that there is a baffle in there. Clearly this is actually a "muffler" - maybe more accurately a "tuner" - since I would guess the primary purpose is to tune the sound of the output, rather than muffle it. Come to think of it, these days all mufflers should really be called tuners, because the OEMs really pay attention to the sound of the exhaust during the build process.
    #54
  15. Toddv
    Toddv Long timer
    Oct 17, 2013
    1,016
    SC
    It does definitely look like it could fool the emissions inspectors...
    #55
  16. TrailTrauma
    Jan 17, 2012
    4,687
    Ontario .. Superior
    Is there a sound clip circulating anywhere which has the stock can but the Arrow decat? I suspect the sound is not as robust as a straight decat pipe with the OEM muffler, but if it's a phatter sound it would still be nice.
    #56
    CaseyB likes this.
  17. Bamboo Baby
    Bamboo Baby Been here awhile
    Aug 4, 2010
    304
    Port Elizabeth South Africa.
    Any Dongles available for the O2 sensors like on the 1290?
    My Rade exhaust will be here tomorrow.
    #57
  18. ramirin
    ramirin Ready to push
    Mar 25, 2008
    623
    FIN
    I haven't seen any. 790 would need smarter dongles to somehow keep it on the open loop all the time - not sure if it's even possible.
    #58
  19. Bamboo Baby
    Aug 4, 2010
    304
    Thought so, thanks!
    #59
  20. BobcatSig
    BobcatSig They call me... Huckajawea
    Aug 15, 2014
    2,618
    Protestlandia, OR
    I've read through this thread and the related cat/tune thread and I'm not quite clear. If I opt to decat my 790 and add a different silencer (WINGS, Arrow, Akro, et al), will I need a Power Commander? Further, when implementing this tune, will the OEM cruise control now be non-functional?
    If it's of consequence, my thought process for removing the cat is mainly heat and weight. Though I've read that the OEM cat isn't all that heavy. Therefore, it's mainly about heat radiating off the cat. Is that the case with the OEM unit, it's nuclear reactor hot?
    On my 690, the cat was the silencer and it about melted the plastics so I swapped it for a WINGS with great success. On my Ducati Multistrada, the cat was partly responsible for absolutely destroying the rear brake fluid and rendering the rear brake near useless. A full Termignoni system remedied that.
    For that that made the swap(s), what say you?
    #60
