Anybody have pictures of the MAM hand guards installed ?
Discussion in 'GS Boxers' started by Massabusa, Jun 4, 2019.
  1. Massabusa
    Massabusa Been here awhile Supporter
    May 14, 2009
    259
    MA USA
    Looking to see how they fit, especially how they might look on black handlebars like mine.
    Looks like there would be a gap at the mirror mounting point after removing the stock hand guards.
  2. Massabusa
    May 14, 2009
    259
    MA USA
    side-burn likes this.
  3. side-burn
    side-burn Been here awhile
    Apr 28, 2019
    584
    Colorado
    Hah, no problem’o. I love those things. Easy to install and look fantastic. I’m not sure where you think there would be a gap. The OEM guards leave no trace and the MAMs fit perfectly. Just follow their YouTube vid for install and keep things snug but not tight until full fit.
  4. Massabusa
    May 14, 2009
    259
    MA USA
    My bike: 2019 R1250GS LOW.
    Read the instructions, watched the video.
    As is usual with any install for me lately- it's not going to be as easy as I thought...
    Installed loosely, and there is no way that the guards will NOT hit the windshield well before full lock.
    No risers, stock handlebar- the issue seems to be my GSA windshield...
    Below 1/2 way down the windshield is clear-does not hit- at lock.
    I like the GSA windshield, great for me on the highway/high speed stuff, my helmet is in a nice pocket of quiet air with the screen full up.
    Don't think I want to use the standard screen...
    Now I guess I need to try bar risers and see if I can make the two work together,
    I have a set of ROX 1.5 BarBack risers- so 1.25 up, and 1 inch back- may work?
    Anybody have a similar set up?
    May have to start anew thread...
  5. side-burn
    Apr 28, 2019
    584
    Colorado
    Gotcha. First, did you order the GSA or GS kit? The $10 difference is that the GSA kit provides longer bar end weights. This is, presumably, to give you better clearance for the windscreen. I thought it was more than that, but as best I can tell, that's the only difference. I ordered the GSA kit but didn't end up using the longer bar end weights because I do, in fact, have Wunderlich risers. They have a very similar profile as the BarBack's you have. With those risers, I liked the narrower overall width so I went with OEM bar end weights and it is impossible to hit the windscreen on my GSA.
    I've got the extra bar end weights you're welcome to if you need them, but as mentioned if you use the risers you won't need them.
  6. Massabusa
    May 14, 2009
    259
    MA USA
    I ordered the GS kit.
    I think you are exactly right- the longer bar end weights move the guard out just far enough to clear the wider lower section of the GSA screen...
    I have only put 3000 miles on this bike so far- I ordered the risers based on my last bike, a 2014 GS...
    So far on the various types of riding I have done- I haven't felt the need for the risers...
    I will take you up on the offer for the longer bar end weights and believe that will work for me- I'll PM you-
  7. side-burn
    Apr 28, 2019
    584
    Colorado
    You're welcome to them. PM me your address and I'll ship them out.
  8. Ccieurzo
    Ccieurzo Been here awhile
    May 11, 2015
    132
    Cornfields of the Midwest
    Pic with painted insert: 1217EBD6-83EE-4580-A9C5-C434BC4E9DC3_jpeg.jpg
    #8
    Toshticles, Callisto224 and Massabusa like this.
  9. jpbadonk
    jpbadonk Been here awhile Supporter
    Mar 16, 2015
    283
    denver, co
    I have the GSA kit with the longer bar end weights. It will still hit the windshield at full lock when it is in the high position. It doesn't hit in the low position...somewhere between high and low it stops hitting. I'm ok with the slight interference in the high position. Also a pic compared to the barkbusters that were on my old bike...
    #9
    Massabusa likes this.
  10. Massabusa
    May 14, 2009
    259
    MA USA
    Awesome, thank you.
    It looks like you also don't have any bar risers installed...
    So I may end up having to install risers to get to a point where there is NO contact at full screen height with the MAM guards...
    #10
  11. side-burn
    Apr 28, 2019
    584
    Colorado
    I think it depends on where you like them when the shield is down. I prefer to have the guards somewhat barely above my knuckles when the shield is down. This gives good Colorado weather breathing for my gloved hands in 80% of my riding. When the shield is fully raised it is still enough to fully shield me, tested in 32 degree weather, not including wind chill! Everyone's mileage and preference may vary.
    #11
  12. Fosters
    Fosters Been here awhile
    Nov 6, 2010
    333
    florida
    0BD83184-22E4-4509-AACC-7978B357DD9E.jpeg A01B3006-0688-4811-A688-244CB7C20596.jpeg
    #12
  13. _Gir_
    _Gir_ Adventurer
    Mar 14, 2019
    92
    US
    Wait, what....I was about to order the MAM for my GSA...it'll hit the windshield? Were these bars originally designed around a different bike?
    I also lanesplit and the last thing I'd want to do is make it any wider so the idea of the "long" weights is going to be a problem.
    Massabusa, I'll def keep an eye out for your thread if you decide to make one.
    #13
  14. side-burn
    Apr 28, 2019
    584
    Colorado
    These are the extended weights you'll get with the GSA option which is $10 more. I think you should be able to adjust them so they do not hit. I have risers so I have gobs of space.
    #14
  15. wabtklr
    wabtklr Land of the Free Because of the Brave! Supporter
    Apr 21, 2012
    101
    Gallup,NM, Land of Entrapment
    Hey Inmates, anyone mount MAMO handguards on Fasst Co Handlebars on a GS LC? I can't be the only one ...
    #15
  16. Massabusa
    May 14, 2009
    259
    MA USA
    #16
  17. Fosters
    Nov 6, 2010
    333
    florida
    No contact lock to lock...it’s a puig touring shield...
    #17
  18. Massabusa
    May 14, 2009
    259
    MA USA
    OK-
    So wanting to keep my GSA wind screen-
    and not have any contact at full lock with the MAM guards-
    and not wanting to install risers at this time-
    AND because side-burn has very graciously donated his unused wider bar ends to me-
    I am going to wait to get the bar end weights and try to mount the MAM guards and see if there is a way to mount them without causing interference with the wider ends that works for me.
    I'll post here, with some pictures when I get the time to try= hopefully this weekend.
    Stay tuned.
    I really like the MAM hand guards!
    Look great, well made.
    Just need them to fit!
    #18
    Fosters and side-burn like this.
  19. side-burn
    Apr 28, 2019
    584
    Colorado
    You'll get them to fit, I promise! They are well worth it. I thought the "adjustabiltiy" was somewhat of a gimmick, until I had to take my bike in for the first service and my bad luck we got a cold front and it was 33 bloody degrees that day. No joke, raised the shield up and turned on the heated grips...hands stayed toasty. Later that day I rode home and it was 72 degrees, so shield down, nice and cool. Plus the look cool as hell!!
    #19
  20. Massabusa
    May 14, 2009
    259
    MA USA
    Thank you side-burn.
    I finally got around to installing the MAM Advance hand guards:
    I also added the ROX risers at the same time-
    I found that as side-burn said- with the risers you don't need the longer bar end weights.
    No contact between the ADVance guards and the ADV windscreen.
    I tried with and without, liked the placement/angle of the bars without the longer weights.
    I also added Grip-Puppies at the same time...
    I went for a 2 day VT ride Monday and Tuesday, doing about 750 miles in total and I love my new ergonomics!
    So if anybody needs the longer bar end weights I can send them on to you.
    #20
