Anybody used these LED lights on the bike?
Discussion in 'Australia' started by Happy Snapper, Sep 21, 2012.
  1. BoomerE30
    BoomerE30 Been here awhile
    Dec 20, 2014
    635
    Howdy! Bringing the thread from the dead.
    How do you like these lights and what pattern is this driving/flood/combo? I've been meaning to buy the Rigid industries 6 Inch LED light but also looking for alternatives.
    I read on forums that Aurora is a solid brand.
    #61
  2. richo360
    richo360 Long timer
    Sep 5, 2011
    3,393
    Melb Bayside
    Rigid and Aurora are both excellent brands.
    I had a 6" Aurora on that front of the 690 Hard kit bike, fantastic.
    #62
    BoomerE30 likes this.
  3. Toe - Cutter
    Toe - Cutter 666
    Sep 3, 2010
    884
    S/Coast NSW Oz Planet of the apes.
    #63
  4. bigborett
    bigborett Hipster Supporter
    Nov 29, 2014
    5,789
    Narre Warren Victoria
    From memory the two brands were made in the same factory and shared some technology. Perhaps without Rigids permission, as they sued Aurora.
    Have had a couple of Aurora LED's and they have been top notch.
    #64
  5. AUSSIEADV
    AUSSIEADV 2wo left foots
    Sep 5, 2006
    9,653
    Ned and Wild’s fight site
    Aurora 6” Lumens = 2950, $110
    Rigid 6” Lumens = 4750, $275
    ADV Monster 50mm round model 30 Lumens = 1500, $40
    ADV Monster 50mm round model 60 Lumens = 3600, $80
    The Aurora and Rigid are very heavy cast.
    I modified a couple of these with XHP70.2 LED’s. 4300 Lumens each for a total of 8600 Lumens.
    https://www.aliexpress.com/item/32625866621.html?spm=a2g0s.9042311.0.0.27424c4dNjwzVE
    I have the Aurora 6” and im not particularly impressed with it.
    #65
    Suncoaster and BoomerE30 like this.
  6. bigborett
    Nov 29, 2014
    5,789
    This is an Aurora 30w 6" lightbar with a led insert in my 690 headlight.
    I have found it fairly good for the price.
    Fairly sure the Rigids are higher wattage also. Could be wrong.
    #66
  7. AUSSIEADV
    Sep 5, 2006
    9,653
    Lets punch some distance!
    1C36273E-F73F-4EA4-B72E-1E1005FFA20B.jpeg 9F07F3A5-820C-4652-976C-EC11110FFFAC.jpeg
    #67
    flinders_72 and Suncoaster like this.
  8. Hoots
    Hoots Long timer
    May 16, 2011
    4,734
    I've been shopping lights for the new car - have been impressed with Stedi - well priced, and look like good products
    Aside from the light bars and vehicle spotties, they make this 6.4" llight - at least one of the reviews comes from an ADV rider
    6300 lumens - 160mm diam
    #68
    AUSSIEADV likes this.
  9. AUSSIEADV
    Sep 5, 2006
    9,653
    Too much wasted light with light bars. The projection is all over the place.
    #69
  10. Dukehunt
    Dukehunt Lost in Translation Nev 2.0 Super Moderator
    Feb 20, 2007
    3,459
    Melbourne North
    A bit like my riding hey mate :D
    #70
    AUSSIEADV and a2zworks like this.
  11. AUSSIEADV
    Sep 5, 2006
    9,653
    you ride alright mate.
    #71
  12. Hoots
    Hoots Long timer
    May 16, 2011
    4,734
    I thought the same, and have gone with LightForce spotties for the new ute
    But was surprised by how far some of the light bars have now come - Stedi's SuperDrive and ST3303 series, and UltraVision's Nitro Maxx series, in particular - both good Aust companies
    Beam from Stedi's ST3303 below - 1 lux out at 600m, and a lot in between - light itself less than $400, with a 5-year warranty
    #72
    AUSSIEADV and bigborett like this.
  13. AUSSIEADV
    Sep 5, 2006
    9,653
    Good light Sam. Punching up the road.
    LED’s are difficult to reflect hence why lightbars have average projection with their small reflectors. The lightbars that use higher output LED’s with larger single row reflectors are better. I have a couple of cheap 4WD Supercentre 7” LED driving lights and they arent bad for the money @ $120 a pair, still they dont punch up the road. Lean forward looking through the windscreen up in the trees and i dont need light up there. Wasted output. The two blue lights i posted earlier, compare the size of the reflector compared to the likes of the Aurora lightbar. Compare the difference in output. Better use of light out of the AliExpress lights than the Aurora.
    For those not wanting to stuff around modifying, id go with two ADV Monsters. A combined 7,200 lumens with more controlled output @ $160 for the pair compared to the Aurora @ $110 for 2,950 Lumens.
    http://stores.advmonster.com/model-60-led-off-road-flood-light/
    #73
    Hoots likes this.
  14. richo360
    richo360 Long timer
    Sep 5, 2011
    3,393
    Melb Bayside
    #74
  15. rossguzzi
    rossguzzi 990 Adv.
    Oct 21, 2012
    2,659
    Bottom left hand side of OZ
    I have thought about getting a couple led lights for the Camel. The stock headlight is 12v but even riding around at night with high beam on it barley lights up the road. 1981 technology.
    Headlights run off the generator only. Tails and indicators run on 6v. Battery is 6v. Could 2 led`s mounted just above the front indicators work from the power feed to the headlight ?
    Only asking as I know LED`s use very little power.
    #75
  16. richo360
    richo360 Long timer
    Sep 5, 2011
    3,393
    Melb Bayside
    Nope.
    Depends if it's spot or spread.
    Never had an issue.
    #76
  17. Warin
    Warin Retired
    Aug 30, 2012
    9,198
    Short answer .. No.
    a) LEDs are very efficient, but you won't get much more light under 20 watts.
    b) The headlight probably runs off AC from the generator? LEDs require DC.
    c) How much extra power is available from the generator? This is the $64 question.
    d) You could run a torch light off the 6v dc ..ebay search on XHP70-2 torch.. fair amount of work to get that going. That assumes you don't use the indicators/stop light much when on hi beam.
    #77
  18. AUSSIEADV
    Sep 5, 2006
    9,653
    You can get 6v drivers for LED’s so its doable. Id just get some cheap lamps off AliExpress, 6v drivers and LED’s if the lamps dont have reasonable ones.
    They arent hard to mod. Easy if you can use a soldering iron.
    https://www.aliexpress.com/item/330...chweb0_0,searchweb201602_1,searchweb201603_55
    https://www.aliexpress.com/item/329...chweb0_0,searchweb201602_1,searchweb201603_55
    #78
    rossguzzi and Hoots like this.
  19. flinders_72
    flinders_72 Long timer
    Apr 21, 2008
    2,486
    Murtoa, Australia
    If you'll only be using the light for an hour or so you could just run a high powered LED torch without connecting it to the bike's system. There are some bloody powerful torches around these days that put out more light than any 'driving' lights.
    BTW I run a 4.2V LED torch converted to run from my bike's power but the power needs to be availabe.
    #79
    rossguzzi likes this.
  20. AUSSIEADV
    Sep 5, 2006
    9,653
    Sorry but its a yep.
    Refer to my comment about single against multi row.
    And no, nothing to do with spread or spot. The larger the reflector the better.
    #80
