Anybody used these LED lights on the bike?
Discussion in 'Australia' started by Happy Snapper, Sep 21, 2012.
  1. BoomerE30
    BoomerE30 Been here awhile
    Dec 20, 2014
    639
    So a 6 inch bar with 6 LEDs (larger reflectors) is better than a 6 inch bar with 9 LEDs(smaller reflectors)?
    #81
    AUSSIEADV likes this.
  2. Warin
    Warin Retired
    Aug 30, 2012
    9,214
    #82
    BoomerE30 likes this.
  3. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    12,274
    GodSowncountry Australia
    Do you want distance (spot) or spread (wide)?
    9 led's with 3 spots and 6 wides could well be better than 6 wides or 9 spots (or vice-versa). It comes down to what you are trying to achieve
    My own ute has a 40" double-row LED bar with a combo of wides and spots, and I've never had such good skippy-spotting lights, the distance is good for night and the spread is excellent for skippy-spotting.
    Too big for a bike at 40", but just an illustration that combo lights can deliver good results too.
    Seeing a bright cone of light directly in front of you just makes it harder to detect that skippy who decides to start running 20 metres in front of you in the darkness to the side. That's where the wide spread LED's come into their own, you can see the roadside quite broadly and clearly even up close. I find that more useful than penetration, I'm not doing 160kph so I don't need to see 900 metres.
    #83
  4. AUSSIEADV
    AUSSIEADV 2wo left foots
    Sep 5, 2006
    9,659
    Ned and Wild’s fight site
    originally light bars only had low output LED’s so theyd use a heap of them in to small reflectors. You can now get high output LED’s up to 30w so you dont need as many and can fit some decent reflectors. Richo’s lightbar runs 10w LED’s with a larger reflectorin a single row. Lightbars used to run 3w LED’s. Have a look at the round lamps Hoots posted. Have a look at the distance those cheapies i modded with 30w LED’s. Heat sink is the biggest issue with the higher wattage LED’s. I have an Aurora 6” here but im running different lamps. Those AliExpress lamps with the XHP70.2 LEDs are the ticket. Another thing is some of the lightbars are ridiculously priced with LEDs being so cheap.
    #84
    BoomerE30 and Hoots like this.
  5. Hoots
    Hoots Long timer
    May 16, 2011
    4,735
    The design of the new Stedi Super Drive is interesting: "The unconventional use of 12 x 15W rearward facing high powered LEDs allows us to achieve new levels of beam intensity & control that simply isn’t possible with traditional reflector designs"
    UltraVision are also using unconventional designs in their reflectors: "Featuring the Widr® optic for width and a Contrl® optic for distance, the Nitro Light Bar takes performance to another level - Widr® Optic – This unique reflector delivers increased light output, achieving huge distance with excellent spread"
    #85
    BoomerE30 and AUSSIEADV like this.
  6. AUSSIEADV
    Sep 5, 2006
    9,659
    once again with so many LEDs its pointless having wide lenses for the LEDs. Just have some LEDs pointing out a little. If they are going to run a spread, it should be an oval shaped reflector, 30 deg vertically, 70 deg horizontally. Pointless wasting light lighting up the possums. If a couple of the units i modded showing the distance above, run a couple 5w/10w lamps out to the side or spread the spots a little. I need more distance than the likes of these bars can provide.
    #86
  7. AUSSIEADV
    Sep 5, 2006
    9,659
    interesting
    #87
  8. Hoots
    Hoots Long timer
    May 16, 2011
    4,735
    You're right about the importance of the reflector
    I looked hard at the light bars - didn't want some sort of metre-wide monstrosity - nor the chunky multi-row units - they're definitely getting better / smarter, but not there yet IMO
    If you can take a deep breath re' price tag, this little spottie from Light Force beats the light bars hands down - 1 lux out at 850m - only 150mm wide and 60mm depth - and just 1.2kg
    I do a lot of driving through western NSW - need a long distance beam - these will be good
    #88
  9. GodSilla
    Sep 21, 2006
    12,274
    Looking at that photo it illustrates the thing I wrote about in my last post.
    While the road is well lit up in a small bright circle, the verges are pretty much dark, and that's where the skippies come from.
    Focussing on the bright cone of light means your eyes aren't adapted to the dark verges, a recipe for collecting a skippy.
    #89
    bigborett likes this.
  10. Redback
    Redback Average aussie bloke
    Feb 20, 2006
    1,569
    Helensburgh NSW Australia
    I'm assuming that's $160 USD not Aussie dollars??
    #90
  11. Hoots
    Hoots Long timer
    May 16, 2011
    4,735
    Don't forget that pic is just the driving light - ie not including the vehicle headlights, which pad out the sides
    Some vehicle headlights are ok - if not, can either replace with LEDs (or replace the whole headlight unit) or replace the little foglights / running lights with something like the UltraVision smart light (below)
    #91
  12. AUSSIEADV
    Sep 5, 2006
    9,659
    yep youre right. Ive had mine for a couple of years now.
    i just read a thread on bad dealings with ADVMonster so may pay to steer clear. I dint have probs with them but plenty look to have done.
    https://www.aliexpress.com/item/32919077724.html?spm=a2g0o.detail.1000023.11.157b333eHZ5uRw
    https://www.aliexpress.com/item/329...chweb0_0,searchweb201602_1,searchweb201603_55
    Some good little lamps for side filling.
    #92
    Redback likes this.
  13. AUSSIEADV
    Sep 5, 2006
    9,659
    Tom, you are right, but having played around with some lamps and LED’s, personally i need both distance and some side fill. You do need some Skip light which can be achieved with a couple of tiny 10w lamps. @Camel 640 runs a couple with his Bajadesigns cluster. I find you can achieve required light fill without so much wasted scattered light from so called spread LEDs by using spots strategically placed. Have a look at the output of the Aurora above and you can see so much wasted light. A bit more effort into the reflectors would have produced a much better light pattern. Another silly thing is the lens on some of these clusters ie Bajadesigns having a wave pattern on two of the four LEDs to create a spread when the spread should have been achieved by reflector shape.
    #93
    GodSilla likes this.
  14. AUSSIEADV
    Sep 5, 2006
    9,659
    Great output for a lightbar!
    #94
  15. Redback
    Feb 20, 2006
    1,569
    I'm thinking I might have a crack at this, so, which one do I pick, 10w or 15w spottie and which colour range for the emitter/drivers do I pick??
    #95
  16. AUSSIEADV
    Sep 5, 2006
    9,659
    Are you going to change the LEDs or run as is? If as is get the higher wattage. Get the 6000k and get the brackets.
    #96
  17. AUSSIEADV
    Sep 5, 2006
    9,659
  18. AUSSIEADV
    Sep 5, 2006
    9,659
  19. Redback
    Feb 20, 2006
    1,569
    So this is the one.
    1PCSX CREE XHP70 .2 6V LED Emitter with 20MM PCB+1PCS XHP70.2 LED Driver and I've picked cool white, it gives me 3 choices, so which one 16/20/26mm.
    Sorry if I seem a bit dim, electrics are not my thing, clearly.
    #99
  20. Warin
    Warin Retired
    Aug 30, 2012
    9,214
    3 choices ;
    LED colour: Cool white -best efficiency
    Wattage: ??? 20 or 16 mm .. I would assume this is the outside diameter of the board .. and it should match the housing. So .. depends on the housing you get. Looks like the housing od is 47 mm .. but you need the inside diameter where the board sits...
    Driver: 1 mode - so 26mm - you don't want to be arssed with 5 modes .. well I don't.
    Redback likes this.
