ANYONE THAT IS RUNNING THE MIKUNI FUEL PUMP ON A 950....
Discussion in 'Dakar champion (950/990)' started by D-man, Oct 20, 2016.
  1. D-man
    D-man SALLGOOD
    Sep 20, 2006
    958
    Spud country, SE IDAHO
    probably a good Idea, shouldn't need it, not that sharp of a bend but I think I will do it anyway. I replaced the hose with one that is stiffer too.
    #21
  2. MultiDoc
    MultiDoc Been here awhile
    Mar 26, 2016
    282
    Wales, UK
    Thanks for the link! Unfortunately they have every rebuild kit for all Mikuni pumps... except the one I need.
    Anyone has any of source? Otherwise the only (silly) alternative would be to buy the whole pump as a spare.
    #22
  3. twobarb
    twobarb Adventurer
    Jan 22, 2013
    90
    Wheat Ridge CO, Garden City KS
    Go to sudco.com and look in their catalog (click on the catalog image, it's kinda confusing ) if it's in there hit up a local shop, most have an account with sudco.
    #23
  4. twobarb
    twobarb Adventurer
    Jan 22, 2013
    90
    Which pump is raid using? I just assumed it was the DF52-73.
    #24
  5. MultiDoc
    Mar 26, 2016
    282
    Wales, UK
    It's the DF52-136. Emailed them and asked if they have a rebuild kit I could get through them. Dave from Raid Designs responded just earlier and seems they d have it.
    #25
  6. Corsica101
    Corsica101 Been here awhile
    Jan 5, 2013
    572
    Valencia
    This is how I got it setup, runs fine!
    #26
  7. SE Steve
    SE Steve Been here awhile Supporter
    May 18, 2011
    352
    So Cal
    I installed the Raid pump on my bike after the stock pump crapped out. Worked great forgot to turn the fuel taps off on a trip with the bike in the back of my truck. Flooded the engine. Ran into a problem with the pump vapor locking in high temperatures over 100 degrees. Rebuilt my stock pump with the dr bean kit no problems since.
    #27
  8. veetwo _tls
    veetwo _tls RENOVATIO:
    Nov 14, 2005
    2,798
    THE MALLEE OUT BUSH IN Sth Oz
    Back when i had the CV carbs & airbox
    Never had a problem since with fueling
    Inline tap & filter setup With the FCR's Now
    #28
    MaineDrummer likes this.
  9. beemer boy
    beemer boy Oh no, he's gone Asian
    Jul 18, 2003
    898
    Southern Oregon
    The original pump was crap as everyone knows by now. The facet pump is a bit
    better. But the real solution, which everyone should use , is to put in a
    Carter solenoid electric pump. Cost is about 45 bucks, dead silent, and worked perfectly on all
    the bikes I put it on. Three Africa Twins and a KTM 950. It actually slips into
    the exact same stock rubber mount.
    http://www.jegs.com/i/Carter/180/P7...9WD85ejiqw-sBfT7nhvlLUkBmUiG6AloaApW3EALw_wcB
    #29
  10. veetwo _tls
    Nov 14, 2005
    2,798
    I ran the mikuni vacuum pump since late 2007 i NEVER had a problem with it & it's one less electrical problem to deal with & it's fixable if had too replace a gasket on side road or out middle of Australia. electrics worth shit compared to mechanical pumps here out bush
    #30
  11. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    8,080
    West of the West, Oregon
    The Carter pump looks good, but output is 6-9 psi. That's way too high, you'd have to add a fuel pressure regulator and set it down to 3-4 psi. It may work on the highway, but it would probably stall out if you hit a jump.
    #31
  12. darkstarmoto
    darkstarmoto Am I evil? Yes I am
    May 24, 2009
    835
    SEPA
    Check out Winderosa Fuel Pump Repair Kit 45145, Amazon has them for $4.85. Supposed to be the right one for the DF52-136.
    #32
  13. beemer boy
    Jul 18, 2003
    898
    Southern Oregon
    Carter makes models of this pump with different pressures . I just looked up the link quickly so this may not be the exact one. I installed these pumps on my KTM 950, as well as the Africa Twins. They worked flawlessly on all the bikes .
    #33
  14. Zuber
    Sep 28, 2004
    8,080
    #34
  15. Zuber
    Sep 28, 2004
    8,080
    A couple of odd vacuum pump installs -
    I worked on an old KTM LC4 single that had a vacuum pump. It was producing too much pressure for this worn out carb, not normal for these pumps. Someone had lowered the pressure by running a line from the pump output back to the input. There was a Tee from this line to the carb. So, it pumped in a circle with just enough left over pressure to feed the carb.
    The early Husabergs had an odd shaped tank that extended below the carb on one side, the other side ended above the carb. The carb was gravity fed from the upper side of the tank and a vacuum pump pulled from the low side and re-filled the upper side. Don't know why they didn't just feed the carb directly?
    When these systems run out of fuel, it can take a lot of engine cranking to prime them again. Unless the pump is gravity fed below the fuel level.
    #35
  16. Bearded Hooligan
    Bearded Hooligan Moto Addict
    Mar 30, 2004
    1,291
    Flat, Hot & Humid South GA
    This is what I am using for the last 10k miles. Mine stock pump with the DR. Beans kit died on a 6 week /14k mile trip at about the 5k mile mark, in the middle of nowhere. Found this pump at a Napa and installed, been there since. Picked up a spare in Fairbanks before making the run to Prudhoe Bay as insurance, its still in the box, now on my work bench. Simple, available just about anywhere and has been reliable so far.
    #36
    beemer boy likes this.
  17. Corsica101
    Jan 5, 2013
    572
    Valencia
    Had a Mikuni pump and used it for the MDC '17. Got airlocked every time the fuel started boiling in the Morrocon heat. Not good in a rally! this one been working fine so far
    #37
  18. bigborett
    bigborett Hipster Supporter
    Nov 29, 2014
    7,444
    Melbourne, Australia
    Ok, I have read most of the stuff on fuel pumps and am looking at swapping to a vacuum pump. I like the ultra reliability and easy fixibility.
    Now here's the thing there seem to be a couple of inherent problems with Mikuni options. Namely, over pressure and siphoning leading to hydraulic lock.
    I've found this Dellorto pump which is run on some karts and Sherco bikes.
    https://sharkshifter.com/zc/index.php?main_page=product_info&products_id=1388
    It is a little more expensive than the Mikuni but has an inbuilt 0.1 bar(about 1.5psi) pressure relief valve so no need for a regulator, it also has internal one way valves so siphoning should not be an issue. It runs at 55lph, way more than required but should not be an issue with internal regulator.
    Those couple of problems with the Mikuni should be null and void.
    What do you think?
    P.S. I don't want to hear about Dr Beans or other electric options.
    #38
    overlander and veetwo _tls like this.
  19. syky27
    syky27 Owner of Muller Motorsport
    Jun 6, 2017
    80
    Vancouver BC or Prague Czech republic
    Hi, do you by any chance have a picture of the bracket you made? I just bought the same pump and I am figuring out how I should mount it....
    #39
  20. alon mad dog
    alon mad dog n00b
    Aug 26, 2019
    2
    israel
    can you tall me wich psi i shuld looking for when i order the carter pump? thanks.
    #40
