Anyone use or try the Domio Helmet Audio device?
Discussion in 'Equipment' started by bicyclenut, Apr 24, 2018.
  1. Rick G
    Rick G Ranger Rick Supporter
    May 19, 2004
    4,696
    Euclid, OH
    Thanks for your review. Sounds (pun intended) like this needs active noise cancellation.
    Rick G
    #21
  2. bicyclenut
    bicyclenut Been here awhile
    Sep 14, 2015
    181
    Chicago Suburbs, IL
    Spoke with tech support, suggested I mount on side as should be better. I will try just to see if it helps. Certainly the Sena headphones are located close to ears. Also suggested earplugs but I was already using No Noise earplugs. Figure if I might ask to return I might as well give them the opportunity to troubleshoot issues.
    #22
  3. little foot
    little foot seriously not serious
    Jul 21, 2008
    15,368
    The Springs, Oklahoma
    Nice helmet
    #23
  4. Yellow Pig
    Yellow Pig Allergic to asphalt! Supporter
    Oct 28, 2004
    9,265
    SoCal -T.O.
    I just got done testing mine ....in a nut shell: DON'T GET ONE.
    I just did a test loop using it on my Klim Kiros helmet. I tries mounting it on top and on the side right over my left ear. I tried without earplugs and with my Alpine Moto Safe Earplugs, which are communication system compatible.
    Once you get over 10 --> 15 MPH you can't hear a thing. The Domio device doesn't put out enough volume.
    I've got a cheap dB meter I used to test sound out put, and there is no noticeable difference in sound output when it's un-mounted compared to when it's mounted to the helmet. According to the Domio web site the "Vibro-Audio sound technology turns your helmet into a surround sound experience", but according to my experience putting the device on the helmet did not enhance the sound.
    Now, if you plan on using it on a snow board helmet or bicycle helmet it might just work. Although, the bicycle helmet would have to be more of the skateboard type that the more common Giro type.
    It's too bad because the device is well built, simple to use and actually sounds pretty good when not in motion.
    Now, to see if I can return the device.
    #24
  5. bicyclenut
    Sep 14, 2015
    181
    Chicago Suburbs, IL
    Yellow Pig,
    Thanks for the review, good to hear, well, bad that it didn't work for you also, but now I know it just wasn't something with my set-up that was causing the problem.
    I agree with your points about the build quality and the sound when not on motorcycle.
    They wanted me to test over side by ear, but it sounds like that really isn't going to do anything to help so I'll have to see what they will do for me.
    Thanks,
    #25
    Yellow Pig likes this.
  6. darngood1
    darngood1 I'm DarnGood1. I ride 'n stuff.
    Aug 8, 2018
    42
    Meridian, Idaho
    FYI: another company worked on a product in 2006 called the ShellShocker using the same audio delivery method. It was a failure. It was reviewed by WebBike World as well, and his opinion was great concept, but not great sound delivery at speed whatsoever. I happened to work in powersports comm systems and I checked into this theory with our engineers as well. They told me it was completely inconsistent sound delivery based on the helmet type, padding, shell material, etc and something they decided to steer clear of years ago. Hope that helps. Here's the link to the WebBike World review of the ShellShocker... https://www.webbikeworld.com/temco-shellshocker/
    #26
  7. Ken in Regina
    Ken in Regina Long timer Supporter
    Sep 12, 2010
    1,725
    Regina, SK, Canada
    @bicyclenut, I know this is an old thread but I noticed you thought you might use the Domio for music even though you are already running a Sena and your phone. Two buddies and I use Senas and smartphones of various brands. All three of us occasionally use our phones as music players through the Sena as well as for making/receiving phone calls and texts. One uses his for music almost all the time. Just wondering why you don't use your Sena this way? ... Or perhaps you are by now?
    @darngood1, It stands to reason your engineers gave up on it and why it doesn't work at higher speeds. The airflow over the helmet from road speed and side- and head-winds will completely change the ability of the helmet shell to vibrate the way the designers intend. And I doubt you can compensate for those changes because they will be different from situation to situation (type and shape of helmet shell, pressure from road speed wind, pressure from side- and head-wind, etc.). Heck, even something as simple as how tight or loose the helmet fits will likely have some effect. Also how compressed the foam liner has become over the years as the helmet ages. Etc., etc., etc...
    And I'm not even an engineer. :-)
    ...ken...
    #27
  8. Hoggdoc
    Hoggdoc Adventurer
    Mar 28, 2018
    28
    Longview, WA USA
    So basically for motorcycle use it is a 200.00 Piece of Crap....
    #28
    bicyclenut likes this.
  9. Riderjon
    Riderjon n00b
    Sep 25, 2019
    1
    Florida
    After waiting patiently forever got my Domio, after trying it in different locations on three different helmets I contacted the company and told them my experience was less the stellar, muffled one sided sound at low speed and unit could not be heard at all over 55mph so I wanted to return for a refund. Here is the crazy part, this company (with no posted phone number) has a "No questions asked warranty" advertised in large letters on their order site, after receiving my email I got no reply so after three days I sent a copy of my email to the listed officers of Domio asking for someone to contact me for my "No Questions asked warranty" return. That day I got a email from someone named Sebastian asking if I could be contacted for a discussion, I replied yes with a time and date and he agreed. 20 minutes after the arranged time I called him, he answered and started asking a bunch of questions (see no questions asked policy) after explaining that the unit was not as advertised he told me if I sent back the unit he would send me another, I told him that I would prefer a refund but he insisted we go this route first. I asked him if I experience the same outcome then what? He said let's wait to see. After reading lots of reviews and contacts with other buyers stating that they sent the unit back for a refund and never hearing back from the company and now having no unit or refund I decided to keep my unit so I could let others hear how bad the sound quality is in person.
    Plan on offering it to anyone interested at Biketoberfest next month in Daytona. They sent me a return label so I found a rock the same size and weight (but with better sound when tapped on a helmet) back to them along with the promise to warn others about this product! Buyer Beware!
    #29
    vecchio Lupo likes this.
  10. Hawkan
    Hawkan n00b
    Feb 9, 2019
    1
    Australia
    Thanks everyone for the info. I can stop wondering about this product now.
    #30
  11. kenny61
    kenny61 old and crippled
    Jul 11, 2010
    26,237
    in a drainage ditch
    so it sucks?
    #31
  12. vecchio Lupo
    vecchio Lupo Diplomatico Di Moto
    Jan 3, 2007
    667
    Böblingen, suburb of Stuttgart Germany
    Thank you RiderJon for taking that hit and I was almost tricked into ordering one , but I will wait for
    #32
