arrghh - i've been zundapped.
Discussion in '2 smokers' started by stainlesscycle, Aug 12, 2014.
  1. stainlesscycle
    stainlesscycle Long timer
    Jun 6, 2008
    2,329
    morgantown, wv
    picked up a 1972 gs125 this weekend - trying to get it running - missing some parts - searching etc...
    i have it running and idling pretty good, but the damn shift shaft/selector is goofy. i took it apart, and saw the shift pawls are in backwards - i fixed that, now i can't figure out the return spring. i have the workshop manual and it's no help...
    anyone ever rebuild the shift shaft on a rickman zundapp, or ks100-125-175/gs125/mc125? or maybe someone here has a bottom end laying in the corner of their shop, that they'd like to get rid of - i know it makes a good door stop, but i need it.. or if anyone has a seat/brake pedal/shift lever/shift shaft assembly/some other little parts from a gs125/mc125 i'm buying..
  2. Foot dragger
    Foot dragger singletracker
    Dec 27, 2006
    27,926
    chico,just below rag dump(nor-cal)
    Those motors may make good door stops,but Ive sold one in parts for over 1000.00,shift parts are very hard to find in the US at times.
    Some 2 stroke hotrod guys used to make a living off trying to make Zundapps and Sachs engines shift better.
  3. stainlesscycle
    Jun 6, 2008
    2,329
    morgantown, wv
    i wish i could find one of those guys right now :)
  4. Mr. Carts
    Mr. Carts Been here awhile
    Jan 14, 2010
    411
    Cahuilla Mountian
  5. stainlesscycle
    Jun 6, 2008
    2,329
    morgantown, wv
    unfortunately my shifting shaft works perfectly fine. it's the selector that is giving me fits. i think i found someone in belgium that i believe can help..
    this is the puzzle..
    and here is where i am at.
    return spring
    i believe i have the return spring wrong, but i can't fit any other way that i can see. and it's the way the manual says...... and the selector setup the way it is will not turn..
  6. stainlesscycle
    Jun 6, 2008
    2,329
    morgantown, wv
    YAY! patrick.wargee in beligium got me all straightened up. it is back together and now i am in business! and back to the parts searching..
  7. Scootern29
    Scootern29 Long timer
    Sep 4, 2012
    1,073
    In the hot, hot, dezert
    Check and search out Terry Davis on Mark's vintage swapmeet. He is a Zundappaholic.
  8. stainlesscycle
    Jun 6, 2008
    2,329
    morgantown, wv
    yeah, i have corresponded with him a bit..
    #8
  9. Scootern29
    Sep 4, 2012
    1,073
    Cool, I've talked with Terry a couple of times over different stuff, good guy.
    #9
  10. stainlesscycle
    Jun 6, 2008
    2,329
    morgantown, wv
    mechanicals are coming along. seat is wrong. whatever. put a mikuni on it, might switch back to the bing..
    #10
  11. stainlesscycle
    Jun 6, 2008
    2,329
    morgantown, wv
    bing carb fixed all issues. put a husky rear brake lever on it (can't find a stock one..) - took a spin, and it moves right along. quicker than i expected...
    #11
  12. erkmania
    erkmania I'll take better everytime
    Mar 19, 2004
    2,847
    San Diego, CA
    What does "moves right along" mean? Can you compare it with something more contemporary? My memories aren't scaled very well.
    BTW, I really like the snapped on airbox cover. It's as if the bike says that it needs you as much as you need it. :deal
    #12
  13. stainlesscycle
    Jun 6, 2008
    2,329
    morgantown, wv
    it's an air cooled piston port. so i would have to say it's faster than many other 125cc air cooled piston ports of the era i.e. penton/dkw (sachs 6a/6b), and yamaha at1.. it handles better than both. it would give a yamaha mx125 and other reed 125 air coolers from the early 70's a run for their money. it handles better than most too. by handling i mean turning. the suspension is not great. i've ridden most of the 125's of the era... a well tuned hodaka super combat would probably beat it to 30mph though. it's surprisingly fast. they did advertise 18hp, i dunno, hard to tell, but seat of the pants says probably. it has a nice top end. shifter throw is obnoxiously long...
    of course this is only after riding it for a short time - have not got all the bugs worked out, but the motor is strong. the rear brakes and suspension need work.
    overall it's a really nice rider, friendly power delivery (linear with a nice high mid hit), and ergonomically very nice. short wheelbase makes it very nimble. there's some issues: footpegs suck, shifter throw is bad as mentioned, gs125/mc125 specific parts are especially hard to source (almost no interchange with rickman and ks125), although motor parts interchange with other models. steel wheels suck. clutch pull is a little hard, but a cable change might fix that. i tried rerouting, and it helped slightly. it doesn't feel heavy when riding, but i'm guessing it is.. rubber mounted motor is neato.
    #13
  14. erkmania
    Mar 19, 2004
    2,847
    San Diego, CA
    Thank you.
    #14
  15. stainlesscycle
    Jun 6, 2008
    2,329
    morgantown, wv
    i played with timing today, retarded it to 080" - easy starting, no pinging, and very nice overrev. i had set it at .100" and it pinged a bit on the top (and that's on 112 octane...) and gave me a very slight kickback if i wasn't firm with the kicker...
    #15
  16. stainlesscycle
    Jun 6, 2008
    2,329
    morgantown, wv
    got myself another one. cleaned carb and changed plug. went for a spin. runs pretty good, needs some air the tires... and a serious tank cleanout.
    this one is more correct, but skid plate, front fender and street tires are wrong..
    #16
  17. Scootern29
    Sep 4, 2012
    1,073
    Stainless, walk away from the Zundapp's, you are out of control. :eek1
    #17
  18. stainlesscycle
    Jun 6, 2008
    2,329
    morgantown, wv
    2 is more than enough. i may trade one off for something ugly i can race.
    #18
  19. Foot dragger
    Dec 27, 2006
    27,926
    As long as your binging on the Z bikes........Ive got a nice Zundapp Rickman frame here with your name on it.
    Those are booth really cool looking bikes you'
    ve got now though.
    #19
  20. stainlesscycle
    Jun 6, 2008
    2,329
    morgantown, wv
    i have been looking for a rickman zundapp roller with no motor... i've passed on a couple over the years, when i should have at least picked up one.
    #20
