Arts and Crafts for old guys; boat build
Discussion in 'Shiny Things' started by blues, Feb 18, 2019.
  1. blues
    blues Long timer
    Feb 29, 2004
    2,098
    Burlington VT
    Time to build a boat, I must be right out of my mind but hey.
    Been retired 3 years and suddenly felt the need. After lots of discussion with a buddy decided to give it a go.
    Me, on and around the water for most of my life, generalist engineer, with a bit of wood working, buddy Stu, perfectionist, machinist, expert at digging out the obscure, and knows everyone.
    The boat. A lap strake, planing day sailor. I took an adventure sailing course last summer and the bug bit hard. A lot like adventure riding except to be a member of the ‘club’ you need to build your own. Lots and lots of work but mostly fun and interesting. And some really interesting characters. That and you can justify buying lots of tools. And beer.
    So ride along for the good, the bad, and the ugly. Will attempt to post pics as we go.
    The calm before the storm.
    xrmattaz, ausfahrt, 42 and 13 others like this.
  2. blues
    blues Long timer
    Feb 29, 2004
    2,098
    Burlington VT
    Apparently they do plane, time will tell. Light boat, lots of sail.
    nomiles likes this.
  3. thumpism
    thumpism Between bikes
    Dec 16, 2005
    3,697
    Richmond, Virginia
    You're doing this in the basement, right? That's the only way to build a boat.
  4. 9mm
    9mm Been here awhile
    Apr 18, 2006
    453
    "Southeast of Disorder"
    Make sure you build the boat slightly larger than you exit door. Got to keep those traditions alive.
    j8tg, Doggedly, TNWillie and 8 others like this.
  5. toolfooldan
    toolfooldan Need a witty/profound phrase to put here...
    Sep 5, 2018
    74
    Temple, TX
    Make sure you build a place to stow those bongos on the boat. When there's no wind for the sails you'll then have something to do.
    I'm a hobbiest woodworker and I've always wanted to build a small boat or canoe, even though I know zip about boating. I'll be following your progress.
  6. Solaros1
    Solaros1 Long timer
    Dec 20, 2005
    1,905
    Roswell, GA
    One very important tip for boat building - Pointy End Toward Door.
    A good friend of mine has built three boats in his basement a little 16' rowboat, a 17' Coquina sailboat and a 23 foot boat with a small forward cabin and a two cylinder diesel powerplant.
    When it came time for us to extract boat #3 from his basement I observed that it would have been a lot easier to get it on a trailer if the stern wasn't pointed toward the french doors that opened out toward his patio.
    As it was we had to remove the door and casing, replace the header and enlarge the opening in the brick wall by three inches and the boat barely cleared.
    I asked him why he hadn't thought this through a little better and his reply was "I built the other two boats that way".
    The other two boats could be carried up the sidewalk to his front yard - we had to get creative with the big boat.
    It involved taking down the fence into his neighbors back yard, disassembling a major part of the trailer, two winches and a Land Rover Defender to drag the whole thing down a steep wooded hill in his neighbors back yard.
    wee-twin, xrmattaz, Amphib and 9 others like this.
  7. Solaros1
    Solaros1 Long timer
    Dec 20, 2005
    1,905
    Roswell, GA
    Getting it out of the basement was only part of the adventure - that was day one. Day two involved more insanity.
    wee-twin, Amphib, BOBaloo22 and 11 others like this.
  8. UtahGuido
    UtahGuido Long timer Supporter
    Nov 29, 2007
    9,566
    Spine 'O the Wasatch
    You’ve also got to have a “moaning chair” in the shop - a comfy chair you can retire to when things go horribly wrong, or in which to have a nice cup of tea when things go really well.
    #8
  9. neppi
    neppi Been here awhile
    Mar 9, 2017
    382
    Tauranga, New Zealand
    My grandfather used to build boats in his living room. They were sized so that he could fit them out the window in the end. But just. Grandma told him in some point that its either the boats or her. He had to ponder about it for a while, but he chose well. The downside of it was that there were no new boats coming out of that window anymore...
    Another Finn, Pertti Duncker, just decided to build himself a steel boat and then ended up spending six years sailing it all over the world, for instance being the first Finn to sail to Antarctica and stuff...
    #9
    blues and double_entendre like this.
  10. scootac
    scootac Just a Traveler
    Feb 18, 2008
    9,394
    Northcentral PA
    Any picture of what it SHOULD look like when done?
    Good luck!!!
    #10
  11. blues
    blues Long timer
    Feb 29, 2004
    2,098
    Burlington VT
    Moaning chair ready to go. Right now I’m contemplating the piece on the band saw which arcs about 80 degrees, tapers from 2 inches at one end to 6 at the other, with both sides beveled the whole way.
    #11
  12. blues
    blues Long timer
    Feb 29, 2004
    2,098
    Burlington VT
    The plan is to do most of the woodworking in my basement cause that’s where the wood working equipment is and I have ( had) lots of room. We’re going to build the strong back and plank it in my buddy’s heated garage. Then we’ll flip it over onto a trailer and fit it out in my garage.
    Here I am clamping epoxied planks together after carefully alignment. This morning I found that any imperfections in the clamping surface will emboss themselves into the epoxy. I spent some effort accordingly so we’ll see how this one looks tomorrow.
    #12
  13. blues
    blues Long timer
    Feb 29, 2004
    2,098
    Burlington VT
    Video of the boat in action.
    #13
  14. UtahGuido
    Nov 29, 2007
    9,566
    Well you know you're going to make screw-ups, and leave evidence of it behind, and only you are going to really notice them. But you will. The boat will be fine (as long as they aren't too egregious).
    You'd enjoy this place if you haven't been. It's the Viking Museum in Roskilde Denmark where they craft viking ships by hand using the old methods & tools.
    They even forge the rivets onsite.
    #14
    vtwin and blues like this.
  15. MrBob
    MrBob Mystical Supporter
    Oct 27, 2005
    16,692
    Boulder county, Colorado
    Will your boat be stitch and glue or plank on frame?
    #15
  16. blues
    blues Long timer
    Feb 29, 2004
    2,098
    Burlington VT
    It’s lapstrake made from a special, $$, plywood, held together with epoxy. You bevel each plank to provide appropriate 3/4” bonding surface between planks. Epoxy is really slippery stuff so the trick is to get it positioned exactly where it needs to go and clamp it down. A composite nailer really helps here.
    #16
  17. Grreatdog
    Grreatdog Long timer Supporter
    Apr 6, 2007
    28,900
    Annapolis, MD
    It is good fun starting with plans, teaching yourself to read them, lofting the hull the way it used to be done and building a boat. Life and epoxy allergy developing got in the way of completely finishing it. But I will get back to it in the near future.
    I never actually planned to build a boat. I just wanted to teach myself to read old plans relative to lofting a hull. But, once I got that far, putting a marine plywood skin on it was easy enough. I decided not use okuume since it will be hard used if I ever finish it.
    So, I have a boat that just needs final bottom fiberglass and paint.
    Have fun, it's a trip building from plans rather than a kit..............
    #17
    xrmattaz, ausfahrt and Hadricus like this.
  18. ArcticaMT6
    ArcticaMT6 Been here awhile
    May 24, 2010
    887
    Seattle
    Sprinkle a tiny bit of sand on the epoxy in the joint before clamping. Will prevent it from slipping as you tighten the clamps.
    This is a fantastic channel to watch videos from about the building process.
    https://www.youtube.com/user/TipsfromaShipWright
    I'm a Naval Architect, so a boat is on my way too long list of things to build. I figure it's only proper. The boats I work on are quite a bit larger and rustier, though.
    For anyone else here, the boat in question is a Gannet designed by Ian Oughtred. http://www.oughtredboats.com/
    The one I've had my eye on the past few years has been the Phoenix III by Ross Lillistone.
    https://www.duckworks.com/product-p/ross-phoenix3-id.htm
    #18
    Amphib and Hadricus like this.
  19. Roam
    Roam If you want to
    Jul 25, 2006
    1,573
    NoVA
    Where did you take the adventure sailing course and what did it entail?
    Good luck with the build. It'll likely be a horrible yet somehow addicting experience.
    #19
  20. emerson.biguns
    emerson.biguns All idiot, no savant
    Apr 17, 2007
    11,417
    The Old Pueblo
    +1
    :ear
    #20
