Ask your WELDING questions here.
Discussion in 'The Garage' started by KTM640Dakar, Mar 5, 2007.
  1. ABuck99
    ABuck99 0.0
    Feb 21, 2009
    821
    Georgia
    Thank you, appreciate you chiming in. Yeah Im the only one that will ever be working in there and there wont be any other equipment (other than lighting and a fan) running on that subpanel at the same time- basically a hobby set up, I'm not doing professional/regular duty work. I figured I would remove the 6-50 receptacle and pull the breaker out if I ever moved- or at least label it 40A so new owner didn't think it was a 50A circuit.
    NitroAcres likes this.
  2. JGNC
    JGNC Long timer
    Aug 11, 2011
    1,996
    Currently Central CA
    Picked this up a few days ago on CL. It wasn't what I was looking for but for the price I couldn't pass it up. I think I'll keep it forever now that I have it.
    After a couple dozen electrodes here's where I'm at. This is 1/4" material with Lincoln 1/8" 7018 electrodes from Home Depot at 120 amps.
    The top two beads I found myself in an awkward position with my face too close to the work. Is the bead width on the bottom one ok?
  3. David R
    David R I been called a Nut Job..
    Oct 16, 2009
    3,510
    Hamlin NY
    Yes the beads look good.
    David
  4. stormdog
    stormdog Long timer
    Feb 19, 2006
    1,765
    Almost Southern Oregon
    Think dime wide and a nickel high for a bead
  5. Schnurbart
    Schnurbart Been here awhile
    Dec 8, 2010
    114
    P-Top, AZ
    What's the back side look like? Dime width is pretty wide for an 1/8 rod.
  6. JGNC
    JGNC Long timer
    Aug 11, 2011
    1,996
    Backside had a discoloration right where the weld is.
  7. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,158
    SE Denver-ish
    I thought the same but I think he's talking about the ripple spacing not width of weld.
  8. David R
    Oct 16, 2009
    3,510
    Hamlin NY
    3 times the rod diameter. Max of 5/16” according to AWS
    David
    2old2Bbold and ER70S-2 like this.
  9. victor441
    victor441 Long timer
    Jul 27, 2009
    2,758
    Sonoma Co., Calif.
    FWIW I worked in telecom power for awhile and a coworker had a start battery blow up while servicing it, was not seriously hurt fortunately. Anyway after that all start batteries in my area were replaced with Optima Blue units (sometimes as many as 8 for a big diesel) as they are less prone to off gassing...they are pricey though.
    https://www.optimabatteries.com/en-us/support/battery-basics/battery-gas
  10. larryboy
    larryboy Stable genius.
    Jan 9, 2005
    26,159
    Über Alles,California
    Finally set the Miller 350P up for pulsed spray. First time trying it, what fun!! I'll be using pulsed spray MIG as much as possible from now on.
    1/4"
    1/2"
    Strong Bad, ER70S-2, eddyturn and 3 others like this.
  11. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    3,486
    Anyone using magnification in their helmet? I am thinking of getting a good helmet with 2x or 4x options.
  12. dbc
    dbc Adventurer
    Aug 12, 2015
    94
    N. Cal
    I use a 1.5x mag insert for tig welding, works great. The magnifiers are a separate part. they're rectangular pieces that slide into slots inside your helmet.
  13. mb289
    mb289 2 Wheels Welding LLC Supporter
    Jan 2, 2007
    391
    Charleston, SC
    I use 2x mag plus my reading glasses.
    Strong Bad likes this.
  14. small_e_900
    small_e_900 Amanda carried it
    Aug 21, 2007
    3,233
    Map 27 Mudpuddle Maine
    I've tried them in an effort to save damage to my expensive glasses.
    It would also be nice to use safety glasses under my hood.
    I've had metal dug out of my eyes three times. Three times is three times too many.
    The problem that I have is that my eyes need very different corrections. What works for one eye makes the other a blur.
    I don't know if anyone makes custom cheater lenses, but I'd certainly give that a go if it were available.
  15. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,514
    Central Ohio
    You might try a Google search for "stick-on magnifiers". I use them in safety glasses, goggles and even have one on the edge of my helmet face shield to help read small text on my GPS. I have an assortment of cheap readers from +1.00 to +3.00, so I experimented before purchasing the stick-ons. My most-used readers are +2.00, but since the face shield is further from my eye, a +1.25 works better on the shield.
    Mine from Hydrotac work well, but next time I'll look for stick-ons intended for scuba diving masks as they usually are larger.
    mb289 likes this.
  16. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,158
    SE Denver-ish
    The cheater shown above is plastic - in your situation, I'd cut two different corrections in half and make a custom combination.
  17. David R
    Oct 16, 2009
    3,510
    Hamlin NY
    One word. Progressive.
    Cheater does not work for me.
    David
  18. Just4Fun11
    Just4Fun11 Been here awhile
    Aug 5, 2008
    448
    BA3F2D92-95F4-426A-970E-9251EF7F03C5.jpeg 09ED94FC-A423-424A-8B5B-410463D91174.jpeg I needed one of them too. Mom said I’d need glasses, before I needed them... darn her.
    My friends racing my old 91 cr250r out in the desert. She slammed the plastic shark fin into bits, but luckily missed the brake disc. I told her of possible disc damage, so we are making a homemade shark fin. Made the shark fin and gussets from 3/16” & 1/4” T6 aluminum plate. At her work the welder guy says he’s having trouble getting the dis-similar properties to flow together. My limited experience had me cleaning up the caliper carrier of any oil or grease then heating it up with a mapp gas torch to help expel anything below the surface (would have used the oven but chose not to piss off someone else!) , and grinding off the surface to get to the cleaner substrait below.
    Preheating the carrier would that help get the puddle flowing? Any suggestions?
  19. larryboy
    Jan 9, 2005
    26,159
    High probability that it isn't 6061. Give up sooner rather than later.
  20. JeffS77
    JeffS77 cheap bastard
    Apr 23, 2006
    3,474
    Riverside , CA
    Ugh..welding some 1x2 .120 rectangle to an unknown thickness 1 1/2" round tube. Guessing it was .090 but I am blowing through it rather easy almost thinking it's .060. Using Lincoln AC stick welder and 3/32 7018 rod at 75amps welding vertical uphill and not going so good. My cheap (surprisingly decent) Vulcan rod blows through and my "colder" Lincoln rod blows through. The Vulcan really doesn't like to start below 75amp. I am also running a very tight arc
    I am pretty good at vert uphill but it has always been with similar thickness metals.
    Any advice? I am trying to focus the heat on the thicker side but still no dice.
