At It Again....Thinstrom 650
Discussion in 'Japanese polycylindered adventure bikes' started by glitch_oz, Jul 26, 2007.
  1. glitch_oz
    glitch_oz Long timer
    Apr 23, 2006
    4,046
    Melbourne/AUS
    Jay had the wrong crashbars delivered for his new KLR650....tried to make 'em fit, but without success. No amount of abuse would bring those Hepco-bars into a mountable shape...so I finished up with them.
    The right/ left sides are shaped differently, apparently to go around some engine/ chassis protrusions of the KLR...still, something to play with.
    The original KLR left bar up top....the "re-arranged" right bar on the bottom....near all of the tubing is re-used.:so:so
    The tubing is 22mm (7/8")....and by chance the same diameter as the stock handlebars, more on that later.:cool:
    Making spacers out of 16mm Alum rod....
    The old Strom handlebar....bent as on the first day the 650 came into the joint :bs Do you see what I see??
    Cutting it down the centre gives 2 nicely cranked pieces for the crashbar-crossbrace
    The short alum rod semi-modded to fit into the tubing....it'll be drilled out 8mm down the centre, leaving a piece of thick-walled alum-tubing as a centre-connector which ties the 2 halves of the crossbrace together via a couple of set-bolts.
    Getting there....slowly
    Left side, after the welding.
    And YES, cutting the tubing to get all those angles right was a bitch!!
    Still to go: the crossbrace.... then bead-blasting/plating/ powdercoating.
    Weight so far...~1.6kg
  2. Weekend_warrior
    Weekend_warrior Been here awhile
    Feb 18, 2006
    538
    Nice work Oz!
  3. glitch_oz
    Apr 23, 2006
    4,046
    Melbourne/AUS
    I'm trying...:D
  4. glitch_oz
    Apr 23, 2006
    4,046
    Melbourne/AUS
    Crash bars came out fine ...THANKS to Jay (Stookie) for the "raw materials" (originally Hepco/Becker bars for an '08 KLR650)....supplemented by an old, slightly bent set of stock-handlebars for the crossbrace :idea: :idea:
    As usual, the camera turn's the paintjob to shit...:D:D
    And pinching one of Adrian's shots that day...
    On another note:
    There won't be further updates to this thread (not from this corner anyway)....time to enjoy this jigger now and ride the wheels off it. :wink:
    Sure, there will be some minor tweaks and changes here and there.... but nothing substantial anymore.
    Thanks to all who've been looking in again and again over the past 18mths or so...been a pleasure to have you along.
    :clap :clap
    Argus16 and gravityisnotmyfriend like this.
  5. OldDog
    OldDog non impediti ratione cogitationis
    Feb 20, 2005
    7,181
    Gunnedah, New South Wales
    Thats looking bloody good Glitch, well done!
    Do you do your own carbon fibre work?
  6. Joe Bar
    Joe Bar Middle England
    Nov 23, 2005
    1,394
    Thank you for sharing, it's been a pleasure to come along for the ride. Love how your bikes turned out. :D :D
  7. markbvt
    markbvt Long timer
    Sep 26, 2007
    4,178
    Georgia, Vermont (that's one town, not two states)
    Thanks for posting all of this, Glitch. Gives me lots of inspiration and ideas about what I could do with my Wee-Strom!
    --mark
  8. yellowbirdrs
    yellowbirdrs Been here awhile
    Jan 1, 2009
    966
    Ags. MX
    OMG! that is a cool Wee, all you need to do now is replace the OME wheels for spokes. I know is hard but after this thread I know you can do it.
  9. glitch_oz
    Apr 23, 2006
    4,046
    Melbourne/AUS
    Hi mate
    there ain't a piece of carbon on those bikes.
  10. glitch_oz
    Apr 23, 2006
    4,046
    Melbourne/AUS
    Looked into that...but dimissed it as too expensive for the little gain achieved.
    $3k for a set of wheels is beyond the envelope of this built.
    Again, thanks for looking in....and perhaps the one or other mod might find its way into other bikes somewhere around the globe.:wink:
  11. Dorzok
    Dorzok Long timer
    Jun 10, 2008
    6,509
    SoCal
    Hey gltch, why'd you run the exhaust around the swingarm instead of up next to the shock where the headpipe for the rear cylinder runs?
  12. glitch_oz
    Apr 23, 2006
    4,046
    Melbourne/AUS
    Space (or rather the lack of it)....the need to fab another header/ collector, and the need for removal of the battery box were the major problems there.
    Would've been 'cleaner', but brought too many other probs with it.
    All that relates to the shortened rear subframe....which brought the can ~5" closer towards the ctr. of the bike.
  13. War Hammer
    War Hammer Evil Monkey
    Apr 6, 2005
    351
    Ft. Worth, TX
    Beautiful work OZ, but you gotta loose those ugly Emgo mirrors. Aprilia/Guzzi mirrors would look great on there!
  14. glasswave
    glasswave Long timer
    Feb 4, 2007
    6,780
    Wasatch Mtns, UT
    I can't really tell from your photos. Is your exhaust stock going from the engine to the new tube. My main dissappointment with the wee is ground clearance and I had hoped that a good exhaust shop could re-route the pipe along side the engine to get more clearance. I had hoped that this along with a custom bash plate could significantly raise the GC w/o drastically affecting the bike's on road handling or seat height.
    Do you have any other I deas for improving the strom's GC?
  15. glitch_oz
    Apr 23, 2006
    4,046
    Melbourne/AUS
    Don't expect them to last forever....and whatever goes on, has to be fairly cheap....which pretty much knocks out the Priller/ Guzzi stuff :lol3
  16. glitch_oz
    Apr 23, 2006
    4,046
    Melbourne/AUS
    Yep, stock headers/ collector.
    Thought about re-routing the front header pipe along the side....by the time everything else is considered, it'll sit that far "out", that it'll seriously cut into cornering-clearance... or have too many bends to keep things clean and healthy.
    Guess we can't have it all....
    Other ideas? Apart from changing suspension components drastically and expensively? NO
  17. glasswave
    Feb 4, 2007
    6,780
    Wasatch Mtns, UT
    I have always thought that the Leo Vince system seems to jut out to the right and tuck up under the peg a little higher but have never found a picture good enough to tell. It seems as if the pipe routed directly under the peg that cornering clearnce wouldn't be affected much, but I'm just an "ideas man" not an engineer or customizer. Sounds like you're more of a "real thinker," so I'll have to defer to your judgement. :D
    Leo Vince system:
    Another angle
  18. glitch_oz
    Apr 23, 2006
    4,046
    Melbourne/AUS
    Looked at the LV as well....they've got the "run" sorted pretty well, of course that'll include a new set of headers/ joiners to match.
    From all that transpired along the way since it's launch in '04, the stock system (and the headers in particular) have proven to be pretty much the perfect match for the 650engine in that particular tune...many aftermarket systems (and even some cans) created some sweet sound for sure....at the expense of losing a few ponies or causing other hiccups i.e. fueling.
    Haven't come across a dyno sheet of a 650/ LV combo yet...and even if it comes out pretty close, it doesn't mean that it's got the same set of characteristics as the stock item.
    Didn't want to try and re-invent the wheel....when the existing one is pretty much bullseye. (well...there's that GC thing :lol3 :lol3 )
    In the end it always comes down to input ($/ effort/time) versus result.
  19. bk brkr baker
    bk brkr baker Long timer Supporter
    Jul 19, 2006
    10,916
    The Bluegrass
    Well glitch you certainly have reason to be pleased with your bike! Great job, and very well executed.
    So a year or more down the road when you have a hankering to get after something different.How about one of these?
  20. Dorzok
    Dorzok Long timer
    Jun 10, 2008
    6,509
    SoCal
    The Aprillia mirrors are right around $20 U.S. for the pair and fit right onto the Suzuki mounts. don't know what the transfer rate is down under but that ought to be cheap enough.
