Atlas Throttle Lock ?
Discussion in 'Australia' started by Eaglebeak, Sep 13, 2021.
  1. Eaglebeak
    Eaglebeak All roads rider, West Oz.
    Jun 29, 2005
    4,062
    Perth.
    I keep seeing ads in here for one of these, anyone here got one ?
    If so, was it an easy fit, does it work, do you like it . . or is it a waste of money ?
  2. TouringDave
    TouringDave Tri Moto Veritas
    May 17, 2005
    7,406
    Frankston, Vic, Aust.
    Same question. Been looking at these but big bucks just at the moment.
    Has to go on the back burner since my dog destroyed my GS's keys and had to order some more. $$$$$!!!!!!!
  3. Wodger63
    Wodger63 Long timer
    Oct 30, 2011
    4,407
    Homeless
    Personal experience was it was shit, especially when you took the price into account. I ended up with one of those plastic throttle locks that attach the grip and rest against the brake the lever.
    There is no substitute for proper cruise control but it does let you relax your hand on long boring stretches.
  4. Todd157k
    Todd157k Long timer Supporter
    Aug 14, 2012
    3,708
    Ventura, CA
    here's my $0.02 worth..
    I had one on my 701. Worked 'ok' but as it got dust on the friction pad, it lost a little of the 'hold'. Then I dropped the bike once on some rocks and it exploded like a popsicle stick puzzle. I sent the pieces back to Atlas who said.. sorry. That was it.
    I bought another one for my Africa Twin. It works.. 'ok' but still not great. It pushes on the grip for backing and the flex in the grip rubber doesn't give it a solid surface to push against. I put a second pad 180 deg of the required one and stick it on the switch cluster side so it doesn't rotate. That made it work better, but still not great. I have to rest my hand on the throttle to keep my speed. It just takes the fatigue out.
    Kiwirich likes this.
  5. Beet
    Beet adventurer
    Nov 26, 2005
    3,734
    VIC. AUSTRALIA
    Nothing wrong with a 4 inch nail, a worm/hose clamp, a washer and a little welding. Been serving me on all my bikes for some 30plus years. Regards 78C995C7-7028-4429-9D81-1407B2997F66.png
    Haggs, chicky and a2zworks like this.
  6. tripodtiger
    tripodtiger Off riding around on bitumen circles.
    Feb 16, 2006
    6,825
    looking for a smaller house & bigger shed.
    I've had the Vista Cruise Control on the 'bars of my XS11 since the '80s. It's just a cam lock type arrangement but, for those times when I wanted it, it worked well.
    JohnD01 and Beet like this.
  7. Lee Dodge
    Lee Dodge Been here awhile Supporter
    Aug 9, 2002
    763
    Horicon, WI. By da marsh.
    I have an Omni-Cruise and a Kaoko. Both work well. The Omni-Cruise take 30 seconds to install.
  8. szurszewski
    szurszewski Long timer
    May 26, 2010
    4,164
    Olympia, WA
    I’ve had one on my 1200gs for about 10,000 miles and it’s worked as advertised. Obviously not a cruise control, but it keeps the throttle in place like it’s supposed to. I have seen others who had trouble with them because it wasn’t set up just right.
    I have not had to adjust mine on the gs since getting it set the first time. Lots of dust and dirt and no problem.
    I have not been able to get one to mount on another bike I have because there is not enough space to bite on the throttle/twist grip on that bike.
    #8
  9. UTB
    UTB Been here awhile
    May 30, 2019
    110
    Brisbane, 'stralia
    I got an omi cruise rip off from eBay for $10-
    I use it a lot when I'm riding between sections. Best $10 mod you can make.
    #9
  10. NotadenBennettii
    NotadenBennettii Somewhere in the darkness...
    Nov 12, 2020
    45
    Walkabout
    Yes.
    Yes.
    No.
    No.
    Yes.
    :nah With a thin plastic throttle sleeve or whatever it's called it won't hold tight, cuts into the plastic instead, aluminium might be ok.
    #10
  11. Ron50
    Ron50 Long timer
    Oct 12, 2008
    4,443
    Canberra
    I tried the cheap plastic palm rest type. Fine on boring stuff but can catch you out when playing in the twisties - especially with a light bike with heaps of torque.
    A big grab for the front brake and a big grab of throttle mid corner can be very interesting. DAMHIK!
    #11
    GSnovice likes this.
  12. nevgriff64
    nevgriff64 .
    Nov 24, 2005
    20,872
    Melbourne Australia
    I used a bungie strap and palm lock on my lap of Aus on the 950 Adventure.
    Both worked really well but as already mentioned - can't compare to a real Cruise Control.
    #12
  13. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    13,583
    GodSowncountry Australia
    Out west, a $10 plastic palm rest type is as good as anything else. Not recommended for east coast ranges and coasts.
    As noted above, you can apply the brake and be inadvertantly applying throttle too.
    You only do it once (or twice max) and you tend to remember.
    #13
  14. 3legs
    3legs Real men ride sidecars Supporter
    Oct 3, 2007
    3,496
    Adelaide,South Oz
    I've been using one of these for years. Simple however they don't hold it in position forever but does long enough to give your wrist a break plus it's still easy to twist the throttle in a hurry.
    #14
    Kiwirich, JohnD01, Beet and 1 other person like this.
  15. Eaglebeak
    Jun 29, 2005
    4,062
    Perth.
    Thanks one and all.
    I did have doubts about the potential for ‘slip’ with the grip pad arrangement.
    I currently use one of these below and was just idly thinking of something a little easier to adjust.
    I once hit my engine stop switch when using my left hand to tighten the clamp.
    #15
    UTB likes this.
  16. Precis
    Precis Maladroit malcontent
    Oct 13, 2009
    7,388
    Free at last, free at last!
    Ahem: Guzzis have had a friction thumb-screw on the throttle for almost 50 years...
    #16
  17. GSnovice
    GSnovice Beer me up, Scotty!
    Apr 30, 2006
    2,104
    SE Qld
    As do airhead BMWs.....
    #17
    Precis likes this.
  18. Ron50
    Ron50 Long timer
    Oct 12, 2008
    4,443
    Canberra
    And pommy bikes from the fifties and earlier.
    #18
    Spanky McKanky likes this.
  19. Precis
    Oct 13, 2009
    7,388
    Except, with all that oil flying around....
    #19
  20. Spanky McKanky
    Spanky McKanky Spanky
    Jul 10, 2010
    290
    East Gippsland Victoria
    Yes I remember my Father's 1958 James had a friction screw on the throttle.
    Pretty basic in design but it worked.
    #20
