AUS Scrapheap Builders Thread
Discussion in 'Australia' started by Pezz_gs, Nov 4, 2014.
  1. WILL_S
    WILL_S OUTLAW POSTIE 001
    Feb 16, 2009
    3,390
    goodly satisfactory place, qld
    Klr650c ran 41mm also
    OldDog and Roofchop like this.
  2. buckscreek
    buckscreek AUTODIDACTIC
    Apr 10, 2007
    3,584
    Vacy
    Anybody got a pair of mufflers to suit a honda cb200 or similar lying about? 1&3/8" (35mm) inlet and about 2' (600mm) long.
    Thanks,
    Joe
  3. tomrux
    tomrux Been here awhile
    Sep 18, 2010
    937
    northside Briswegia
    I haz a couple but they are pretty rough. Get ya a pic whoncet I'm home
    Cheers
    Tom R
    buckscreek likes this.
  4. Pezz_gs
    Pezz_gs Cant ride for crap
    Nov 13, 2004
    5,266
    Sydney Skunkworks
    JagLite likes this.
  5. OzCRU
    OzCRU Been here awhile
    Feb 16, 2015
    922
    Sydney Australia
    WILL_S likes this.
  6. Pezz_gs
    Nov 13, 2004
    5,266
    Sydney Skunkworks
    Part 3 is a good watch too. . . . . .
    Part 2
    Part 3
    JagLite and OzCRU like this.
  7. Roofchop
    Roofchop Hands up mother stickers, this is a f**k up!
    Jan 9, 2016
    682
    Carool, NSW
    I saw that yesterday and thought of you Pezz :lol3
    Pezz_gs likes this.
  8. Pezz_gs
    Nov 13, 2004
    5,266
    Sydney Skunkworks
    He had some great fab skills
    Like his home made shaper to make splines too
    Roofchop and OzCRU like this.
  9. Pezz_gs
    Nov 13, 2004
    5,266
    Sydney Skunkworks
    Part 4
    Roofchop likes this.
  10. troy safari carpente
    troy safari carpente Team f5oolery
    Nov 21, 2005
    34,898
    "Swednavia" - f5ederation of Scandwegia
    mrsdnf likes this.
  11. OldDog
    OldDog non impediti ratione cogitationis
    Feb 20, 2005
    7,034
    Gunnedah, New South Wales
    Oh my god........I'm not ashamed to say....i cried watching that
  12. buckscreek
    Apr 10, 2007
    3,584
    Vacy
    You cried because he was using such a small hammer. What kinda man uses a puny knockometer like that, hey @OldDog ?
    OldDog likes this.
  13. Pezz_gs
    Nov 13, 2004
    5,266
    Sydney Skunkworks
    Big wheel bike. . . .
    JagLite likes this.
  14. OldDog
    Feb 20, 2005
    7,034
    Hipsters, thats who! Some people should never be left unsupervised! I blame youtube for it!
    JagLite likes this.
  15. OzCRU
    Feb 16, 2015
    922
    Sydney Australia
    Hey Guys,
    Little bit of help please ... to install my refurbished Ohlins shock (Originally from a TT belgarda, converted & set up by Paul Rooney) on my XT, I'll need to move the rear brake resevoir. I've got a location that I think will work, tucked up out of the way - but the original tube/pipe running from the resevoir to the rear master cylinder won't work. So here's my question:
    What flexible pipe should I use that is suitable for brake fluid, & where can I buy it?
    Thanks Heaps!
  16. tomrux
    Sep 18, 2010
    937
    northside Briswegia
    Supershit and get fuel hose of an appropriate diameter.
    Can always do what the racers do and just use a length of hose, no reservoir , just means you have to check the level more often. Usually a clear hose, generally silicone. Again super shit or bunnings. Bit of cork in the end.
    Cheers
    Tom R
    OzCRU likes this.
  17. OzCRU
    Feb 16, 2015
    922
    Sydney Australia
    Thanks Tom,
    So any fuel hose or silicone hose will be sufficient - OK, just checking then - It doesn't have to be any special material, nor take any pressure cause its just delivering the brake fluid to the reservoir. (I think I thought that because brake fluid eats paint etc that it must have needed something to contain it)
    That sounds like a cool trick with the clear hose too. Might think about that as an alternative if the other option ends up getting tricky.
    Thanks again for the help!
  18. Roofchop
    Jan 9, 2016
    682
    Carool, NSW
    El cheapo hose will do but the real deal is called Tygon, it is ultra chemical resistant (won't sweat brake fluid) and it's what all the GP bikes use (probably)
    Google Tygon, you can buy it on Ebay Amazon etc, also medical suppliers.
    Cheers
    Dave
    OzCRU likes this.
  19. OzCRU
    Feb 16, 2015
    922
    Sydney Australia
    Thanks for that tip @Roofchop spot on.
    Cheers
  20. Pezz_gs
    Nov 13, 2004
    5,266
    Sydney Skunkworks
    Well progress is a little slow with the lockdown. . . . :norton
    My design book has lots of drawings as I keep contemplating this build.
    Anyhow did a rough design of the oil tank and side cover. As usual this is most likely to change before manufacture
    Oil tank would hold approximately 1.541437258 litres
    Then a mock up of the X5 left sidecover. The X5 sidecovers are mirrored so that will make it a bit easier to build. I am planning on a couple of creases with the bead roller to break up the slabbiness of the sidecover.
    Seems I used the same CAD program on Reg :hmmmmm
    mrsdnf, Roofchop, JagLite and 4 others like this.
