Aussie 1090/1190/1290 owners thread.
Discussion in 'Australia' started by ozzieadventure, Jan 29, 2015.
  1. DR Steve
    DR Steve Been here awhile
    Jan 21, 2012
    847
    Melbourne, Australia
    If you just want to hide the evidence this works ok.
    Don't know how it would go in a medium/high speed tar slide but worked well for the few low speed naps my bike has had.
    bigborett likes this.
  2. Weld75
    Weld75 Tour-ist
    Jul 18, 2014
    100
    The Switch
    A question for long term owners of 1190's - a couple of the screws that hold air box lid tight, are starting to strip out the thread. Is there a good solution to fixing the problem? I have always been careful tightening these screws, however after 4 years there is wear and tear in the plastic and I think it won't be long before more of them start to strip out. Bigger diameter screws? Anyone tried studs ? Thanks in advance.
    Shroza likes this.
  3. mcguyver
    mcguyver Long timer
    Dec 24, 2005
    2,142
    STRALIA
    Remove airbox fit Rottweiler..Your welcome
    Briggsy_1 and Wodger63 like this.
  4. wairau
    wairau get in behind!
    Mar 29, 2011
    3,518
    urenui, taranaki
    sticky buttons
    anyone got the up/down buttons on the lefthand switch block getting a bit sticky? if not pushed exactly square on, one of mine stays pushed, causing the menu to continuously scroll thru the different screens.
    just wondering if theres an easy fix before i pull it to bits?
    cheers
  5. Wodger63
    Wodger63 Long timer
    Oct 30, 2011
    3,214
    Hervey Bay
    @wairau I always spray mine with WD40 after I wash the bike and never had a problem in 38K klms with my 1190 and I do the same with the 1090.
    wairau and Dukehunt like this.
  6. wairau
    Mar 29, 2011
    3,518
    urenui, taranaki
    cheers lionel
    that was my first thought too but wondered about it swelling the rubber buttons. obviously not an issue.
    thanks mate.
    Wodger63 likes this.
  7. bigborett
    bigborett Hipster Supporter
    Nov 29, 2014
    5,789
    Narre Warren Victoria
    If it is only one or two screws, a bit off a smallish cable tie in the hole while you screw the screw in will bring it up as tight as new.
    wairau, Weld75 and 1coolbanana like this.
  8. Problem Child
    Problem Child Been here awhile
    Nov 21, 2016
    112
    Lake Macquarie Aus
    At about the 1:30 mark, Nerb1 explains his fix
    Target3 likes this.
  9. grb6372
    grb6372 GRB6372
    Jan 11, 2006
    20
    Sydney Australia
    That looks good. What exactly is that stuff? I will probably install a bracket with a female thread to accommodate an oggy knob. Still internet surfing for solutions. Must say that this bar saved thousands. Hate to replace that plastic tank. Headlight assembly too. Again, that tubing would overcome the cosmetic damage somewhat, so what is it?
    I have seen photos of rescue tow rope wrapped around the crash bars. That would have helped. Just a thought. Anyway, thanks for your feedback.
  10. Weld75
    Weld75 Tour-ist
    Jul 18, 2014
    100
    The Switch
    Thanks for that, something like I had in mind. Cheers.
    Problem Child likes this.
  11. DR Steve
    Jan 21, 2012
    847
    ToyCollectr likes this.
  12. Toejamii
    Toejamii Still Learning
    Jul 31, 2015
    667
    Brisbane
    If you dont want to buy the rotti setup
    I stripped the thread on one air box screw , i used a cable tie and then replaced the screw it then works fine as the extra thickness of the tie lets the screw bite into it , just cut teh cable tie each time you clean the filter and replace.
  13. earlmi
    earlmi Adventurer
    Mar 25, 2017
    39
    Hi guys.
    Does anyone know when the 2019 1090r get released?
    What time of year has been the trend in the past?
    Cheers.
  14. Wodger63
    Wodger63 Long timer
    Oct 30, 2011
    3,214
    Hervey Bay
    Ask your KTM dealer.
  15. wairau
    Mar 29, 2011
    3,518
    urenui, taranaki
    gentlemen
    gear levers
    i want to move mine, but not a whole spline. if i put it in the vice and give it a little tappy tap tap with the thumb finder, will she bend or will she snap?
  16. Wodger63
    Wodger63 Long timer
    Oct 30, 2011
    3,214
    Hervey Bay
    I don't like your chances, those sorts of things always seem to want to bend the wrong way but break being set the right way.
    The 1X90 foot peg mounts are reversible which will raise the peg but you might get the orientation you're looking for.
  17. ktmgeoff
    ktmgeoff Remember it's not a race!
    Jun 16, 2006
    2,477
    Western Creek Tasmania ( sold the farmand moved)
    This is one of those occasions where it's best if you're the guinea pig. Let us know the results.
    Shroza and EkrebDK like this.
  18. wairau
    Mar 29, 2011
    3,518
    urenui, taranaki
    cheers fellas. was sorta hoping to avoid being the lab rat :D
    Shroza likes this.
  19. shaunpoz
    shaunpoz n00b
    Oct 30, 2016
    4
    Hi to all adventure riders,
    Looking at buying a 1090R and would appreciate any feedback on this particular bike.
    My plan for this bike will be to add some fruit I.e exhaust, giant loop bags side and tank, GPS unit, Bash plate,heated grips and a good set of spotlights.
    Type of riding well that goes without saying Adventure stuff.
    Thanks in advance all.
  20. Wodger63
    Wodger63 Long timer
    Oct 30, 2011
    3,214
    Hervey Bay
    Briggsy_1 likes this.
