Aussie 950/990 Owners Thread
Discussion in 'Australia' started by ADVJake, Jun 22, 2008.
  1. snarley
    snarley Long timer
    May 24, 2008
    1,033
    No not in Sydney. Just really wanted to know whether you can just remove the small clutch cover? Gaskets? Special tools required?
    I just want to replace the plates both fibre and steel along with springs.
    Cheers
  2. LC8TY
    LC8TY must......find........fuel
    Dec 25, 2006
    2,338
    Carnarvon, Australia
    No special tools required Snarley, just lay it down and remove the cover and take out the clutch stack bolts.
    Remove the steel and fibre plates with a hook tool, from memory there is a wave washer in there that has to go back in the right spot.
    Reassemble with Loctite and a torque wrench to specks
    I reused the gasket
    job done
    snarley likes this.
  3. BLU_FZ1
    BLU_FZ1 Been here awhile
    Sep 6, 2013
    426
    Newcastle
    On the side stand is all you require, but if you dont mind picking it up that is also an option
    The last fibre plate is smaller (inner)
    1coolbanana likes this.
  4. Pete640
    Pete640 Long timer
    Nov 23, 2008
    2,127
    Earth
    Pretty sure it’s an O ring seal so you can remove it time and time again - no gaskets to worry about
  5. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    10,898
    GodSowncountry Australia
    A question for the collective.
    I am looking at a triple clamp from a 950/990 KTM, what I need to know is are they the same as the 640A (where I intend to fit it)? I understand the forks are the same diameter, but what I don't know is if the fork centres are the same distance apart, their offset from the steering axis centre, and the angle they are in degrees. I'd be thrilled if it's a straight swap, but I just don't know.
    So, has anyone ever looked into this previously? :ear
    Thanks.
  6. DOREY76
    DOREY76 Been here awhile
    Jun 24, 2015
    186
    Over here
    Double Simpson here I come!! This time I can transfer on the run from the rear bladder setup.
  7. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    5,284
    NW Sydney, Australia
    That looks interesting, got more pics or info on your setup?
    OzRider64 and rider911 like this.
  8. Aussie Steve
    Aussie Steve Long timer
    Apr 9, 2007
    1,478
    Maitland
    Whats with the interlopers in the 950 thread?
    Presume its for the BRP triple setup I saw for sale somewhere, see their 950 triple here https://www.shopbrp.com/ktm/product...triple-clamp-03-13-ktm-adventure-950-990.html and triple for later 640 with twin disc here https://www.shopbrp.com/ktm/product...triple-clamp-05-08-ktm-adventure-640-690.html
    Note the part number is similar but not the same, also see that there is a different handlebar position listed for each so obviously not identical but may still work.
    950 top triple fiche shows x & d dimesions http://www.ktmonlineparts.com.au/pa...e-black-low/front-fork-triple-clamp#ficheZone 640 fiche shows same dimensions http://www.ktmonlineparts.com.au/pa...adventure-r/front-fork-triple-clamp#ficheZone
    So I've run out of interest but if the front hubs, spacers and fork stubs are the same for 640 and 950 then the only question you've asked left unanswered is the angle, maybe do some trawling of parts catalogues to see if you can find a listing of the 950 or 990 lower triple x and d to answer that as its listed for the 640.
    Oz Nutter and GodSilla like this.
  9. GodSilla
    Sep 21, 2006
    10,898
    Thanks for that reply.
    Where else would I ask for expert advice on 950/990 parts? :-) And you have delivered in spades, thank you very much. :thumb
  10. rossguzzi
    rossguzzi 990 Adv.
    Oct 21, 2012
    2,285
    Bottom left hand side of OZ
    Good luck AL.
    If anyone can do it, I'm sure you can.
    Just remember, It's Not a Race :lol3
    anydavenow and DOREY76 like this.
  11. Mouse
    Mouse I'm only smelly
    Nov 1, 2005
    14,926
    Byron Bay
    If emig are still trading maybe drop Paige an email as she may well know.
  12. DOREY76
    Jun 24, 2015
    186
    Over here
    Especially when you don't win ;-)
    anydavenow likes this.
  13. Duketr4
    Duketr4 Adventurer
    Oct 9, 2011
    11
    Sydney
    DSCN4255.jpg DSCN4252.jpg After many months of owning the bike, I finally managed a weekend of getting to know the bike. I elected to go on an organized ride and part of this ride was sand. What a fantastic weekend and just how capable these bike are. I must confess there is 'technique' required to ride in the sand as i found out, but i refused to give up. Puts a new dimension on hard work but I try sand again.
  14. rossguzzi
    rossguzzi 990 Adv.
    Oct 21, 2012
    2,285
    Very cool !
    I really want to take my 990 up to Lancelin to ride beach/dunes.
  15. seancampbell
    seancampbell Been here awhile
    May 28, 2006
    778
    Gosford, NSW. Australia
    Stockton Beach?
  16. rider911
    rider911 Shortcut Navigator
    Sep 18, 2009
    1,224
    Australia
    Hey @1coolbanana on your shim stack recipe, what are you referring to with 2.40-2.45?
    Do you think the 2 stage cross over shim you have put in the base has done anything? Or have you done the cardinal sin all us impatient people do and changed too many things at once to give a definitive answer :lol3
    I was going to put a fraction more float on the mid valve but I might do something similar to the 2012 EXC just for shits and giggles
  17. 1coolbanana
    Aug 25, 2009
    5,284
    2.40 and 2.45 are the total float gap above the mid piston with no shims LHS and RHS
    I use that to work out the final float I want in case I need dummy shims to make the difference.
    No idea if its an improvement yet, I havent ridden it since, my hand is still rooted.
    Let me know :lol3
    rider911 likes this.
  18. anydavenow
    anydavenow Been here awhile
    Nov 30, 2011
    986
    Sydney, Australia
    Att: Aussies. I've put up a thread for my bike prep for Africa so if you're interested in following you can subscribe -> here. Would be great to get your input as I go!
  19. anydavenow
    Nov 30, 2011
    986
    Sydney, Australia
    Have tried to take photos of the light throw for you (finally, sorry) but as I can't control the fstop on the iPhone camera it's not a great comparison of low/high and with the light bar on. Hopefully you get an idea of the pattern, at least. I'll try and remember to try with my proper camera at some point!
    Low Beam
    Hi Beam
    Light Bar
    (Light bar is sitting a bit high at the moment I think. Needs adjustment.)
    DOREY76 and OzCRU like this.
  20. LivingdeadCamo
    LivingdeadCamo Long timer
    Feb 6, 2016
    1,155
    Woongarrah, NSW, Australia.
    Light bar looks like it will burn the fur off anything within range!
    OzCRU likes this.
