    Dismiss Notice
Aussie Husky 701 owners thread
Discussion in 'Australia' started by jardine, Jan 29, 2016.
  1. Cyclic Hotline
    Cyclic Hotline Adventurer
    Apr 9, 2020
    18
    Australia
    I have the same screen as Tori on the 701 and it looks da bomb. I rode it briefly a few days ago and definitely moves the airflow in the direction you need it. Fiddly as all buggery to fit and needs a bunch of extra finger joints installed and a whole bunch of new swear words.
    Kiwirich likes this.
  2. ToriMish
    ToriMish Long timer
    May 13, 2015
    1,962
    Grampians National Park, Australia
    I concur, it was a PITA to fit for sure. But it's just the right size screen. Takes the airflow off the body, but doesn't send it to the face and spoil the clean air. I've learned over time that shorter screens work better.
  3. DougW
    DougW Been here awhile
    Jun 30, 2011
    129
    Thanks. I will try the starter motor fix. When you said you "pulled the starter out and pushed it back in" - what exactly did you do? For example did you have to remove the exhaust to get enough access? I can loosen the two starter bolts and then "rotate" the starter back and forth about 5 degrees each way, but there seems to be no "in and out" until I remove the 2 bolts completely (and then Im wondering how hard they are to reinstall without good access).
  4. BygDaddee
    BygDaddee Where do I get a pie
    Oct 26, 2012
    11,425
    Brisbane Northside, OZ
    Boxa and wass like this.
  5. Marma
    Marma Been here awhile
    Jun 19, 2014
    143
    Doug, yes you need to remove the two bolts completely and the starter motor will move slightly, you should be able to pull it out and push it back in. But if you really want to see what's going on then removing the exhaust header is super easy and will provide the access you need. If you want to take out the starter motor, you will need to undo the EFI/carby bolts (don't remove it) as it just needs to go up a little to get the starter motor out. There are some other little obstructions (cables etc) but easy enough to work out.
  6. UncleGra
    UncleGra Road Grime
    Jan 16, 2008
    6,953
    'neath the Southern Cross
    As Marma said, I just took the 2 mounting bolts out hoping that the starter would come out. It only came loose a little bit. I looked over the other side of the starter motor and I thought it looked like a big jobto remove all the stuff. So I just wiggled the starter back in place and secured the 2 bolts. Seems that the o ring seated itself and the leak stopped, so I decided leave it at that and see what happens...all good , no more leak.
    Hoots and Kiwirich like this.
  7. KIZ
    KIZ Marty
    Oct 7, 2011
    997
    Gawler South Australia
    My starter got worse unbolting and wiggling. The O ring was replaced subsequently under warranty . Good as new.
  8. dirtdevo
    dirtdevo Adventurer
    May 13, 2007
    54
    sunshine coast
  9. KiwiPewe
    KiwiPewe Coddiwomple Supporter
    Oct 10, 2016
    7,947
    New Zealand
    Had one of my clutch bolts backing itself out and chewing into the clutch cover. Thankfully still covered under warranty but not a good look
  10. outbackflyer
    outbackflyer Of.
    Sep 18, 2007
    635
    Alice Springs.Australia.
    I ordered and paid for one of these Puig screens , then 2 weeks later received an email notification that they’re no longer trading and they actioned a full refund into my PayPal account.
  11. DougW
    Jun 30, 2011
    129
    Thanks Marma
    I removed the header and pulled the starter motor out just enough to clear, cleaned as best I could and then replaced and wriggled it around. While the oil leak was reduced, unfortunately it did not fix it completely. So now I will see if I can change the O ring. Which side of the bike does the starter motor come out of? When you said undo the EFI/Carby bolts, Im assuming you are referring to the two clamps. Do you rotate te EFI or do you actually have to push it upwards? And any other helpful hints would be very much appreciated.
  12. Marma
    Jun 19, 2014
    143
    Yeah my o-ring looked ok, but didn't want to redo the install for a $1 o-ring. So once you've removed the exhaust and undo the starter motor, you should be able to twist it out towards the rear of the bike below the EFI (yes loosened the EFI and wires just allow the starter motor to be pushed up against it). But you could keep the starter motor in the bike, and just rotate it so you can remove and replace the o-ring. I removed the starter motor completely only because I wanted to clean the area, but you really don't have to take it all the way out.
