I had thought that one of the benefits of the 701 over the 690 was that they had got the suspension sorted Was the conversion to RB and Comp on both legs a costly exercise?
The major "changes" that were made to the 701 to transform it from the 690, had to do with some Changes to steering head and fork Crown geometry. As far as "suspension" goes... the 701 got the same 4CS series WP forks that the other orange sibblings were fitted with, and these have recieved very "mixed" (read: poor) reviews from a lot of people in the game. seem's like "open chamber" surgery is the accepted fix for them.
Darren and Kiwi, how much ballpark did the fork conversion cost? Never really messed with suspension beyond the basics. Also I'm in for the Feb rally, so keen!
Done the 10k service, all clearances within spec, a reminder if you’re running the Radegarage system , do put some adhesive foam along the supplied rear mounting bracket and also along the front white frame cross tube where tank seats, also remove or rotate any zip tie ends that might eat a hole through your six fuel tank.
By fabricating a simple alloy plate to secure the lower door section, the two vulnerable and unnecessary attachment lugs can be removed .
I re drilled the two “R” clip holes lower/flush with the door lid to make the whole assembly more secure.
Best advantage in retaining the Original velocity stack is the correct fitting position is guaranteed, unlike the first model which (could be) clamped incorrectly onto the intake manifold , don’t stress about the modest size of the twinair filter, it is designed to (filter and supply) more than max required volume/ velocity for the 701 at full tilt in dust. Rade did his homework and pre tested the design in South Africa ( bull dust there too.)
I’ve not modified mine, but I found by winding off the compression (anticlockwise),out to 22 clicks,and leave the rebound around 12 clicks it handles the corrigations and heavy hits quite well, many owners are reporting that they dislike the front suspension, I’m happy with mine.
Good to hear it working ok then. I was thinking about getting just the airbox off him, as recently upgraded my storage compartment from Tupperware ver 1 to cut down old 690 airbox ver 2
I have a set of haan wheels which are fitted with Dunlop 908/906, but for this trip consisting 280 kms road and just 20 kms creek bed, I ran the hedenau tyres on the standard wheel set,which are great on hard dirt/ highway but bad for sand/ mud or loose rock.
That’s a great looking setup, do you intend to fit a steering damper?, with 40 plus kilos over the front end it would help maintain control in soft conditions and higher speeds .
Ta, not pretty but practical. Was nearly going to get a rade tank and use as a water tank for desert trips but went this way. Can stuff some water bladders in if needed for desert trips or just for general storage for light gear not used too often for other rides. Haven't bothered with a Damper for a couple of reasons, I don't like lifting the bars and haven't had a need for it. (Well it hasn't scared the beejesus out of me yet in 20 odd thousand km so in no hurry to spend the money). Handles sweet. Suspension is pretty sorted.
Hey mate Im probably missing something looking at it on my phone but what are the two aluminum things on the frame rails on each side
