Aussie KLR650 Adv Riders Sign in Here
Discussion in 'Australia' started by Tagati, Jun 22, 2008.
  1. ACT Adv Rider
    ACT Adv Rider Blunderer
    Jun 29, 2006
    62
    Canberra
    Hey Phil - you should post this info on the Australian KLR Riders Facebook page. I know a couple of guys are considering sidecars who hang out on that site.
    Barry - Canberra
  2. Rockman
    Rockman Been here awhile
    Jan 26, 2007
    630
    Inverell, NSW Australia
    G'day Barry.
    I dont do facebook so could you do me a favor and post to there for me or refer them to this ADV thread.
    Good to see you got yours up and running.
    Phil
  3. 3legs
    3legs Real men ride sidecars
    Oct 3, 2007
    1,528
    Adelaide,South Oz
    Ok any auto electricians amongst the KLR crowd?
    I went to an auto electrician toady to see if he could work out how many watts of power available to me. I told him the standard stator is around 180-200 watts and I want to run a Waeco fridge that the specs says uses 3.5 amps per hour. His response, don't know, you need to bring it in.
    Oooooooooookkkkkkkkkkkkkkkk. So I ask do you think a motorcycle charging system with said stator would charge a car battery? His response, don't know, you need to bring it in.
    Now I'm no electrician but I would have thought even with basic questions as above he at the very least could give me a rough answer. I told him I only want a guide to see if it's possible so he was under no obligation.
    I know we sort of covered this recently but I would really like some more info other than above.
    Also anyone used one of the Race Tech 280 watt stators? If so your opinions please.
    I'm still considering using the bike battery and a car battery as a dual battery setup but i'm open to all other ideas.
    Cheers
    3legs
  4. slowbike smallpenis
    slowbike smallpenis Tester of Tooheys Old
    Mar 9, 2003
    21,778
    Just above Tasmania
    I = E/R
  5. Toy Rolex
    Toy Rolex Been here awhile
    Feb 14, 2013
    291
    3 legs I doubt that guy could answer your questions anyway.
    I don't know the KLR so my first question is will your headlight work with the motor not running ?
    Measure the voltage at the bikes battery when the motor is hot at idle, 3000 rpm & 5000 rpm hook up the fridge and do the same tests. (post here)
    Then someone may have the answer or you will need to spend some online working out the bikes requirements eg; headlight most likely 35w, tail light 20w, ignition ? any added loads like the fridge (you should measure this yourself as waeco are ambitious with their facts) GPS or heated grips, then subtract that all from the 180w you quoted earlier, that will give you the spare power you have. (changing to LED globes will help)
    Then you need to determine how long you will want to run the fridge for without boosting the battery, it is best to do a real life test of battery and fridge (don't believe what you read) , the longer the waeco runs the more power it will need to keep things cool.
    How far down are you prepared to drain the marine battery (12.3v is 50% flat and causing battery damage)
    Then how far are prepared to ride to get the battery back to full ( above 12.8v) longer travel times will help as will over sized power wires.
    The marine batteries are popular because they are cheap and can handle some punishment like being pulled too far down and not given enough time to recover but don't expect a long life from a battery under these conditions.
    The fact that they make a bigger stator tells me you don't have a great deal of spare power but it also tells me you have options.
    If it were me and the volts test was OK I would give it a go, start with small test rides, fit a digital volt meter to the bike battery and the fridge battery then keep a close eye on things, be prepared to buy the bigger stator as this would shorten the travel time required to get the battery back to full thus improving the life of the battery, the better you maintain the battery between rides the better your whole system will work.
    3legs likes this.
  6. 3legs
    Oct 3, 2007
    1,528
    Adelaide,South Oz
    Ok KLR guru's. Pros and cons of ditching the airbox and just have a air filter direct to carby.
    The reason I ask is I'm trying to figure out a good way to make a top rear mount to rear bike frame for a sidecar and the best way that transfers the load evenly across both sides of the rear bike frame is right where the airbox is.
    If I go with just an air filter any recommendations for a air filter.
    Note I have an aftermarket exhaust but I
  7. 3legs
    Oct 3, 2007
    1,528
    Adelaide,South Oz
    OOPS I pressed the wrong button. I was going to finish with I haven't done anything to the carby yet.
    Sorry about that.
    Cheers
    3legs
  8. chromemonkey
    chromemonkey Been here awhile
    Feb 6, 2010
    109
    brisbane
    Wheres a good company in oz to get crash bars and a centerstand from , the places I've tried are all out of stock
  9. Lancelot
    Lancelot why am i here.
    Mar 21, 2013
    15
    Beachmere
    Hey guys,just bought a new klr 650.Just wondering about the doohickey problem..Has that been fixed at all?Dealer recons don't worry about it.
  10. BLU_FZ1
    BLU_FZ1 Been here awhile
    Sep 6, 2013
    426
    Newcastle
    Doohickey itself is no longer the problem, its the poxy spring that fails and dislodges from its mounting post. Eagle Mike it and never worry about it again.
  11. Lancelot
    Mar 21, 2013
    15
    Beachmere
    Crickey,you would think they'd have it sorted by now!
  12. loxsmith
    loxsmith Good ol days my arse
    Apr 10, 2006
    562
    Ex. Little village called Brisbane, Australia
    Don't believe everything the Stealers tell you
    The Eagle Mike kit is still the only way to go
  13. JMick
    JMick Been here awhile
    Feb 23, 2014
    620
    FNQ, Oz
    The newer model lever ("doohickey") is cast (like EM's) rather than the original pressed metal, so is unlikely to snap in two like the earlier ones did. However it is poorly machined and a sloppy fit on the shaft. This causes it to oscillate/vibrate on the shaft, leading to premature spring failure. I have a 2011 model which I bought with less than 7000kms on the clock and a broken spring. Dealers are in denial, pointing to the very low number of replacement OEM levers and springs sold as proof that the problem is solved, but they conveniently ignore the hundreds of aftermarket parts that are sold to fix the problem.
    Mick
  14. Fogo72
    Fogo72 I Bleed Green
    Oct 6, 2009
    1,581
    NSW
    Hi gents
    Just getting started to build the baddest KLR650 OZ has ever seen, I have the donor bike for the engine and electrics which is a 2014 Ninja 650R.
    Guys I'm looking for a 2008 model or later KLR650 rolling frame with a good tittle, even if the engine is missing.
    what's out there? To buy
    Cheers Fogo
    desert dog likes this.
  15. loxsmith
    Apr 10, 2006
    562
    Not a complete roller but about a 10 model, clear title, has swing arm, less engine, wheels etc etc. Not mine but a friends in Toowoomba. Flick me a pm if it sounds remotely like what you are after
  16. Rob_APG
    Rob_APG Adventurer
    Apr 9, 2010
    24
    BrisVegas
    Hi and just for info the KLR Riders Rally is going to be at Stonehenge QLD on the weekend 29th Sept to Oct 1.
    For planning ahead :)
    griffo1962 likes this.
  17. ethics_gradient
    ethics_gradient Adventurer
    Sep 6, 2008
    56
    Quick question on centre stands: is there a such thing as one that fits both Gen 1 and Gen 2 KLRs? I found a cheaper one on eBay that purports to fit all years, but the other ones all specify Gen 1 or Gen 2, which makes me suspicious.
    Also if any of you have a centre stand to fit an '05 you are looking to sell/swap for other Gen 1 parts please let me know! I found one wrecker in Victoria with one but he wanted pretty much the same price as the brand new one linked above.
  18. griffo1962
    griffo1962 Long timer
    Oct 24, 2006
    1,879
    Carrara, Qld, Australia
    I would think the difference is all to do with length, Gen 1 will be slightly longer as they have more ground clearance
  19. mallee
    mallee Been here awhile
    Jan 23, 2012
    136
    Looking at this, planning few days up and back and make a ride of it and not Rush, leaving from nowra, who wants to join in?
    loxsmith and griffo1962 like this.
  20. Scaredofthedirt
    Scaredofthedirt Been here awhile
    Nov 15, 2006
    732
    Added this to the collection on the weekend.
    Life long tar baby. Excluding seat cover and plastic hand guards, all original.
    Desert2202, gfh, Checkmate3 and 2 others like this.
