Auxiliary Fan kit for KTM 950/990 Adventures
Discussion in 'Vendors' started by KTMforget, Feb 24, 2012.
  1. KTMforget
    KTMforget Long timer
    Oct 29, 2003
    1,031
    Sandpoint, ID
    [​IMG] [​IMG]
    The Black Dog Cycle Works Auxiliary Fan kit for the KTM 950/990 Adventures is a great way to keep your bike cool while running hard, which these bikes obviously like to do. After testing for 1-1/2 years on several different bikes in extreme climates, we are confident that this product will produce impressive results and be durable to the punishment of off-road use.
    This kit is a complete plug and play kit, using factory style connectors so no splicing is required. The fan comes pre-assembled and our custom wiring harness makes installation a snap. While the right tank needs to be removed to install the kit (and in our opinion, the installation is made slightly easier by removing the left tank as well), the rest of the install is quick. Perfect for when you are servicing the bike for maintenance.
    This system allows the bike to COOL DOWN 39% FASTER when compared to the performance of the single stock fan. Great for riding in hotter climates, traffic or when riding the bike hard off-road at low speeds.
    The 950 & 990 Adventures come with a single fan on the left side of the bike. Our auxiliary fan kit puts a second fan on the right side of the bike which pulls air through the radiator, just like the stock single fan. Our fan shroud is designed to have a minimal impact on air flow when the fan is not activated, unlike other systems.
    Like our other products that wear the BDCW brand, the fan shoud and wiring harness are MADE in the U.S.A.
    Get yours here
  2. traveltoad
    traveltoad Aaron S
    May 8, 2002
    6,785
    San Fernando Valley
    Will this also work on the Super Enduro?
  3. KTMforget
    Oct 29, 2003
    1,031
    Sandpoint, ID
    The Super Enduro has dual fans already :freaky
