1. eNewsletter Sign Up
Auxiliary sidetank project for BMW Xchallenge
Discussion in 'Vendors' started by Max Kool, Nov 9, 2007.
  1. SteveRed
    SteveRed Adventure Moto
    Oct 1, 2006
    2,794
    Sydney Hills - Australia
    I was riding with Spiros and he probably weighs in at 220 loaded. I immediately questioned the psi in his air shock and he claims he was running 110-120 and I suggested he needs to put in more air and firm the bike up a little. Don't forget that the shock loses pressure.
    Anyway, with the cut-out on Spiros tank I would've thought this would not have been a problem.
  2. Max Kool
    Max Kool Xtankteam™
    Jan 19, 2004
    4,935
    Los Angeles
    So we can conclude two things?
    • There was too little air in the shock, really. 110 psi is too little! at least 135 psi @ 220 lbs and a full X-tank next time please. Remember the X-tank adds some 15 lbs in total when full. This weight is carried further to rear of the bike than where the rider weight is carried. For the shock this can easily be seen as the rider weighing an extra 20 to 25 lbs. This could easily have damaged the airshock.
    • It still should not have happened...
  3. Erik RS
    Erik RS Three Wheel Maniac
    Feb 10, 2008
    467
    Cloggyland
    So did I :cry
  4. Nopork
    Nopork Dickhead Adventurer
    Nov 22, 2001
    347
    Richfield, MN
    Will using the Ohlins BM636 shock on the X-Challenge cause any interference issues with the tank that you know of? Anyone using this setup have any problems hitting the tank?
    Thanks.
  5. Erik RS
    Feb 10, 2008
    467
    Cloggyland
    Afaik just the contrary. Conventional coil-overs don't bottom he way the airshock does. Max Kool and somebody else in the neighbourhood ride around with the first generation tanks (without the recess) on Hyperpro shocks and don't experience any problems.
  6. Max Kool
    Max Kool Xtankteam™
    Jan 19, 2004
    4,935
    Los Angeles
    As shown above, the tank also fits the Xcountry. (Thanks to joncus)
  7. Redbull Addict
    Redbull Addict I need another one...
    Jun 24, 2006
    1,262
    San Jose / Truckee
    I haven't revisited this thread in a while and realized that I never posted the final chapter. :D
    <object width="640" height="360"><param name="movie" value="https://cdn.smugmug.com/ria/ShizVidz-2008120101.swf" /><param name="allowFullScreen" value="true" /><param name="flashVars" value="s=ZT0xJmk9NDMyMzU2NjY2Jms9a0ZVWm4mYT02NTYwOTU1X2pUWGZTJnU9cmVkYnVsbGFkZGljdA==" /><embed src="https://cdn.smugmug.com/ria/ShizVidz-2008120101.swf" flashVars="s=ZT0xJmk9NDMyMzU2NjY2Jms9a0ZVWm4mYT02NTYwOTU1X2pUWGZTJnU9cmVkYnVsbGFkZGljdA==" width="640" height="360" type="application/x-shockwave-flash" allowFullScreen="true"></embed></object>
  8. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    8,724
    Tacoma - ish, WA
    Those vids are pretty good. Thanks for sharing. :clap
    Got a good chuckle from that one guy "pedaling" his F650 Dakar past you at about 60. Very realistic! Also interesting to see how different bikes and riders handle the same difficult chunk.
  9. ducwad
    ducwad Livin' the dash
    Jul 23, 2004
    339
    Duvall,WA USA
    I just wanted to note that the frames for Dirt Bagz fit over this tank just fine. In case anyone was wondering.
  10. Erik RS
    Feb 10, 2008
    467
    Cloggyland
    CHEERS :thumb
  11. GB
    GB . Administrator Super Moderator Super Supporter
    Aug 16, 2002
    67,867
    Thanks! Please post a pic or two if possible :thumb
  12. ducwad
    Jul 23, 2004
    339
    Duvall,WA USA
    As soon as it is upright again. I'm doing a slooooow install of a Rekluse at the moment so it's been napping in the garage the past few days. :)
  13. Max Kool
    Max Kool Xtankteam™
    Jan 19, 2004
    4,935
    Los Angeles
    We made the press!! [​IMG]
    For those of you living in Germany or Austria, check the current issue of Enduro Abenteuer, page 9.
    ( I have to admit, it does make me kind of proud)
  14. ducwad
    Jul 23, 2004
    339
    Duvall,WA USA
    Here you go...
  15. ciropetiro
    ciropetiro Adventurer
    Aug 12, 2008
    14
    Alps
    Today i have been testing my new xtank. After about 140 km side tank was empty and main tank full.
  16. Max Kool
    Max Kool Xtankteam™
    Jan 19, 2004
    4,935
    Los Angeles
    So you can confirm the TT "racing" gascap is as airtight as the stocker (which is a must for the Xtank to work properly).
  17. ciropetiro
    Aug 12, 2008
    14
    Alps
    Yes, it works with both gascap, standard and TT
  18. PaulXC
    PaulXC Adventurer
    Apr 5, 2007
    46
    Cheshire, UK & Charente Maritime, France
    Spot on! - cheers
    Paul
  19. PaulXC
    PaulXC Adventurer
    Apr 5, 2007
    46
    Questions on the XTank ...
    Being a lardy chap and checking in at 120 odd kg kitted up, if I have my dirtbagz packed and a tail bag, and then a full Xtank hanging on my Xchallenge...
    1) would the rear subframe handle the load?
    2) would the airshock handle it?
    3) is the Xtank gonna hit the chain?
    I see that I can put 150 odd psi in the shock and according to the manual the shock would handle 150 kg but would I be pushing my luck?
    Paul
  20. Erik RS
    Feb 10, 2008
    467
    Cloggyland
    Hi Paul,
    I don't know about the airshock, but for the rest we shall have proof in abt 7 months :D
    I prepped Walter's bike for the Sibirsky Extreme Project . If you go through the story you will see that we load quite a lot on the bike, though I must admit that I tried to avoid loading everything at the rear. The luggage rack also has attachments quite low at the subframe to spread the load. Taking 5 litres extra in the XXL-Xtank adds another 4 kgs. Walter weighs over 90 kgs I guess. On my (and other's) advice though the airshock was replaced by a proper coil-over.
