Back Ordered Stator - Advice or Spare?
Discussion in 'Dakar champion (950/990)' started by sakurama, Jul 13, 2008.
  1. TMoore
    TMoore Arai Helmet Test Dummy Supporter
    Jan 8, 2005
    1,467
    OK! (Formerly from The Peoples Republic of Mass)
    Yes mine is an 04 with 18k miles.
    I thought the 05s and up had a starter "clutch" that had a warranty
    issue? 04s have a different design. My starter had started to clack
    but I thought it was "normal". Now I think it was the first sign that these
    bolts were coming loose. The starter drives the crank through this
    assembly. I got the two snapped bolts out without removing the
    rotor.
    Thanks. Advice appreciated.
    Tim
    #41
  2. sakurama
    sakurama on an endless build
    Oct 20, 2004
    1,652
    Portland, OR
    I agree, my charging system was on it's way out but I didn't think it was because my rotor was coming unglued and my shop didn't bother to check (and neither did I to be honest) and I did an entire track day in that condition. I'm guessing I dodged a bullet but there wasn't much in the oil when I changed it - most of the debris was contained in the cover.
    I'm going to say the rotor is fine - it's only galled on that inside and that back part isn't a "precision" fit. As long as it's still nicely round I'd bet you're fine.
    It's not all that hard although it seems daunting - an oil change and about a dozen screws (most of which you've already got out) but I understand if you've got other stuff going on. Goodluck!
    Gregor
    #42
  3. TMoore
    Jan 8, 2005
    1,467
    My stator is actually wrecked. No rewind for me. :(:
    #43
  4. TMoore
    Jan 8, 2005
    1,467
    My stator was wrecked from the bolt heads going round and round.
    Cliffs got me a new one in a week along with the 6 bolts and I sourced
    some Loctite 648 from McMaster. Cliffs also loaned me the factory rotor
    puller. I put it together wrong the first time
    and had to take it all apart and re-do it but it runs now. I did a 410 mile
    day on Saturday and it ran like a top. I still get a big clack out of the
    starter when I shut the motor off. It also clacks a lot if I bungle the
    start (when warm). I will probably do the 05 torque limter upgrade over
    the winter. New left side cover and a gear is all it is Im told.
    Anyway thanks for the help. I would have been up shit creek without this
    site and its inmates :thumb
    Tim
    #44
  5. apeirce
    apeirce Two ears, one mouth.
    Jan 28, 2003
    2,726
    CT USA
    Sorry that the whole thing happened, but glad you are back and running.
    #45
  6. zugy
    zugy My brother wheeling SXC
    Apr 23, 2005
    192
    So. California
    You would think this would be covered under warranty. Mine just went out same deal....bolts loose. Maybe got hot and loosened the lock adhesive. Gary or Germany will be getting a call.
    #46
  7. cpmodem
    cpmodem Orange Caveman
    Nov 29, 2004
    7,130
    masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
    What year? How many miles?
    #47
  8. pops
    pops Long timer
    May 15, 2007
    1,927
    Stirling North South Australia
    Mine to a few years back :cry.
    I Had to ride it over 100km to get home .
    Bit of a mess.
    New stator and fly wheel $$$ and a good clean up, all is good .
    Cheers Ian
    #48
  9. sakurama
    Oct 20, 2004
    1,652
    Portland, OR
    FWIW, my rebuilt one is still going strong with about 56,000 so far. The base gaskets leak like sieves but the stator is doing fine still.
    Gregor
    #49
  10. zugy
    Apr 23, 2005
    192
    So. California
    #50
  11. cpmodem
    Nov 29, 2004
    7,130
    Its amazxing KTM is still sending engines out without the proper loctite 648 application after all these years. That TB was issued Oct 2004. Musta' have been some newbie trolls hired in '05 and '07. Lotsa Mattighofen FUBARs those years.
    #51
  12. MortimerSickle
    MortimerSickle Semi-Adventurer
    Dec 1, 2005
    16,405
    Rainville, Orygun, where moss is a road hazard.
    Zugy, did you mean that your '07 has suffered the loose-bolt problem?
    I ask, because I had thought that my "07 was safe from this.
    #52
  13. MAXVERT
    MAXVERT O.G. on da O.C.
    Jan 19, 2004
    2,764
    Baja Arizona
    Don't count on it !
    I did my '07 after the first summer of riding and a couple of the fasteners
    were hand tight.
    I'm glad I got in there and did the job.
    It's a quick fix, especially if you already have the tanks off.
    Max
    #53
  14. MortimerSickle
    Dec 1, 2005
    16,405
    It is a quick fix if you know it needs to be done: just take out the bolts, clean the threads, refit with the 648, and torque- little or no heat necessary.
    But, I don't see how to check to find whether it is already properly done: To check the torque would not tell me what kind of Loctite had been used. It would tell me whether it had already failed, but it would not tell me whether it was about to fail.
    I would think the only thing to do would be go ahead and do the R&R. But, I'm not too keen on having to heat the assembly to almost 500 degrees (necessary for 648) to remove and refit the bolts just to be sure. That is a lot of heat, and I would worry about damage.
    Someone please tell me all the 990s are safe. :D
    #54
  15. cpmodem
    Nov 29, 2004
    7,130
    If the bolts have been done, there is supposed to be a spot of paint on each one and the adjacent part of the rotor. There will also be a spot of paint on the outside of the ignition cover at the top near the engine mount.
    #55
  16. MortimerSickle
    Dec 1, 2005
    16,405
    Thanks.
    #56
  17. pops
    pops Long timer
    May 15, 2007
    1,927
    Do you mean to say that the new stator i fitted will need to have the bolts taken out and some Loctite put on them?
    Cheers Ian.
    #57
  18. pops
    pops Long timer
    May 15, 2007
    1,927
    Bump
    #58
  19. cpmodem
    Nov 29, 2004
    7,130
    The questionable bolts are on the rotor. No need to remove the stator. My last post should read rotor not stator. Well into cocktail hour.
    #59
  20. pops
    pops Long timer
    May 15, 2007
    1,927
    :thumbThank you.
    #60
