Baja Designs: General Discussion Thread
Discussion in 'Vendors' started by Baja Designs, Mar 3, 2015.
  1. Baja Designs
    Baja Designs Enter: "BDForums" for 10% ADV Discount!
    Jan 6, 2012
    1,363
    san marcos, ca
  2. GR8ADV
    GR8ADV Safety Second!
    Mar 7, 2007
    1,384
    Bellevue
    Hi guys. Looking to add a couple vertically mounted squadron pro’s to my 701. Do you recommend two driving combo’s (high and low). Or should the high be something else. Thanks.
  3. outbackflyer
    outbackflyer Of.
    Sep 18, 2007
    534
    Alice Springs.Australia.
  4. Baja Designs
    Jan 6, 2012
    1,363
    san marcos, ca
    A very common setup is Spot for High Beam and Driving/Combo or Wide Cornering for Low Beam.
    The Pros will need to be dimmed on Low Beam
  5. Baja Designs
    Jan 6, 2012
    1,363
    san marcos, ca
    Thank You!
  6. GR8ADV
    Mar 7, 2007
    1,384
    Bellevue
    Hmmm well I may have messed up that order. Lol. Maybe I will return one for a spot. do you think I would be better off with a sport on low beam then?
    Ordered too quickly. If it was not for impatience I would have no patience at all.
  7. waylongway
    waylongway madmax Supporter
    Dec 16, 2009
    3,975
    NorCal
    I just got the pro and the SAE squadron form you for high and low beam. Is this the harness I need to run both lights?
    Squadron/S2 Motorcycle Skene Dimmer Kit
    • $89.99
  8. Baja Designs
    Jan 6, 2012
    1,363
    san marcos, ca
    A sport would be better suited for the low beam
    Contact us at 800-422-5292 if you need any assistance
  9. Baja Designs
    Jan 6, 2012
    1,363
    san marcos, ca
    That harness will certainly work for dimming the pair of lights. Thanks for checking with us
  10. Baja Designs
    Jan 6, 2012
    1,363
    san marcos, ca
    A few (of many) BD equipped rides at Rocky Mountain Overland Rally
    Baja Designs
    www.bajadesigns.com
    waylongway likes this.
  11. GR8ADV
    Mar 7, 2007
    1,384
    Bellevue
    Good info. As others may have similar thoughts, I assume with a dimmer I can emulate the sport with the pro? I ask because I can dim the pro but can ‘enlighten’ the sport offroad.
    Fwiw I have a pair of amber sports on runner and they are crazy bright.
  12. Baja Designs
    Jan 6, 2012
    1,363
    san marcos, ca
    With a dimmer, you can certainly run the Pro on a lower output like the Sport. You can lower the Pro output to match the Sport
  13. Baja Designs
    Jan 6, 2012
    1,363
    san marcos, ca
    Baja Designs 10" Hybrid Laser Light - On Board Racing With Branden Sims!
    VIDEO:
    Above is an onboard, uncut view of Branden Sims ripping across Laughlin Desert Classic UTV Night Race equipped with our 10" Hybrid Laser Light! Our Hybrid Laser Light is capable of projecting light 350% further than the most advanced LEDs on the market today.
    Check out all of the Baja Designs Laser Lights below!
    Baja Designs | Laser Lighting
  14. Baja Designs
    Jan 6, 2012
    1,363
    san marcos, ca
    New products! XL, LED KTM 690 (2019-On) Kits
    Starting at $424.95
    Specifically designed for those riders who are looking for more than just your average headlight. The XL Pro, LED KTM 690 (19-on) kit is in a league of its own, producing 4,900 lumens and 40 watts giving you the perfect mix of power and performance, and offers a 20% dimming feature. The XL Pro, LED KTM 690 (19-on) kit Kit has been meticulously designed by our engineers to give our riders an extremely light weight (2.45 lbs) race light, while presenting a unique style and appearance that you will only find from Baja Designs. The XL Pro, LED KTM 690 (19-on) kit Kit is plug and play making for an easy install. An industry first 30 Day Satisfaction Guarantee & Limited Lifetime Warranty is included for the ultimate in purchase protection.
    This is also available in the XL80! Experience 9,500 lumens in an 80W Light
    Check it out:
    https://www.bajadesigns.com/products/XL-LED-KTM-690-2019-On-Kits.asp
  15. Jur1
    Jur1 Adventurer
    Jan 27, 2017
    54
    Do you offer shipping to Finland? I didn't see it listed on your website.
  16. Baja Designs
    Jan 6, 2012
    1,363
    san marcos, ca
    Give us a call or email info@bajadesigns.com if you don't see shipping
    800-422-5292
    We can ship to most places
  17. Baja Designs
    Jan 6, 2012
    1,363
    san marcos, ca
    @mr.franklopez knows how to properly light up the camp!
    Who else has Baja Designs lighting up their campsite?
    Shaggie and waylongway like this.
  18. Baja Designs
    Jan 6, 2012
    1,363
    san marcos, ca
    Are you a fan of ALL Amber or ALL White light?
    OR do you like a mixture of both?
    Baja Designs Lights feature replaceable Lenses and Optics thanks to uService Technology. You're not stuck with the pattern or color you buy!
    Order today with your forum discount (Code: BDForums)
    Baja Designs | Replacement Lens Kits
  19. tkdcol
    tkdcol Been here awhile
    Nov 7, 2016
    137
    Medellín, Colombia
    Hi, so I have a Squadron pro with a flood pattern, if I want to change it to a WC pattern can I just change the lense, or do I need to change anything else too?
  20. Baja Designs
    Jan 6, 2012
    1,363
    san marcos, ca
    You will also need Spot reflectors for behind the lens. Our Work/Scene/Flood pattern uses different optics compared to Spot, Driving/Combo, and Wide Cornering
    Call us and we'll get you setup with the correct parts
    800-422-5292
    tkdcol likes this.
