Baja Designs: General Discussion Thread
Discussion in 'Vendors' started by Baja Designs, Mar 3, 2015.
  1. Baja Designs
    Baja Designs Enter: "BDForums" for 10% ADV Discount!
    Jan 6, 2012
    1,419
    san marcos, ca
    It's time for some Tuesday fun!
    Our lights can handle almost anything you throw at them from dirt to street and everything in between.
    Light up your adventure today:
    Baja Designs
    ^ Team BD driver (IG) Justinlofton41 laying down a serious roost ^
    waylongway likes this.
  2. Baja Designs
    Jan 6, 2012
    1,419
    san marcos, ca
    Baja Designs offers Vehicle Specific Kits for Trucks, Bikes, UTVs, SUVs, and more. These are designed to plug directly into the factory wiring and provide a significant performance increase. Some replace the factory fog lights and others replace headlights.
    Note: We do offer a few kits that require some extra wiring
    Order a kit today!
    www.bajadesigns.com
  3. ZIEN BARON VON SUPERDUKEN
    ZIEN BARON VON SUPERDUKEN Been here awhile
    Aug 27, 2016
    340
    Tent Town, OR.
  4. Baja Designs
    Jan 6, 2012
    1,419
    san marcos, ca
    We don't have any plug and play taillight replacements for that bike
    These two are very popular:
    https://www.bajadesigns.com/products/taillight-bd-led-dropdown.asp
    https://www.bajadesigns.com/products/taillight-efi-dual-sport-kit.asp
  5. Baja Designs
    Jan 6, 2012
    1,419
    san marcos, ca
  6. JmanC
    JmanC n00b
    Sep 5, 2019
    2
    Aus
    I have some questions about the LP9 pro LED which I'm considering buying to replace my current LED setup.
    In the instructions it says don't wire both Low & High beam & on other forums people say not to run both low & high as it can overheat board.
    What I'm confused about is where does the 11,000Lumen figure come from if both high & low can't be ran at same time?
    There are videos showing high beam switched on and all 9 front leds are one. So does this mean they are running both low & high in a risky way?
    Can anyone say how much lux for a pair each pro & racer have? My current leds which I find good for close & far have 1 lux for 1km. And I'm trying to know which LP9 to swing to.
    thanks
  7. Baja Designs
    Jan 6, 2012
    1,419
    san marcos, ca
    We're releasing a few NEW products that are extremely cool! I'm personally very excited about ONE of them...
    Details posted during the show. Stop by to check out the new goodies in person
    www.bajadesigns.com
  8. Baja Designs
    Jan 6, 2012
    1,419
    san marcos, ca
    High Beam activates the entire light. This includes the same LEDs that fire when Low Beam is on. If you turned on Low Beam when High Beam is already ON, it wouldn't change the output of the light.
    I unfortunately don't have the lux reading for these lights. If you're only running one light, I'm a fan of the LP9 Pro. The LP9 Racer might be a little too focused for a single light application. Or are you running two lights?
  9. JmanC
    JmanC n00b
    Sep 5, 2019
    2
    Aus
    Thanks for reply. So I don't understand why the warning to not run both low & high beam. Something about damaging the circuit board.
    I'm running two, sounds like racer is too tight for me.
  10. Baja Designs
    Jan 6, 2012
    1,419
    san marcos, ca
  11. Queen of Spades
    Queen of Spades tall drink of water
    Mar 20, 2009
    1,944
    Decatur, GA
    Just bought a 2016 KTM 500 EXC with 25hrs on the clock. I had a Squadron Pro in my old KTM 640 LC4 however that was a chore to install along with the dimmer.
    Do any of your products have a true plug & play installation with the '16 KTM 500 EXC?
  12. Baja Designs
    Jan 6, 2012
    1,419
    san marcos, ca
    If you install an XL Pro, or XL80, it will be a true plug and play system. Both lights have a built in dimming feature and can be used with the hi/lo harness
    Let me know if you'd like links to everything we offer for that bike
  13. Baja Designs
    Jan 6, 2012
    1,419
    san marcos, ca
    Designed from the ground up our new S1 fills the shoes of a large light in a small package! The S1 utilizes a highly specialized reflector and LED combination to outshine the competition. With the 2.1" length, width, and height the S1 is highly versatile for any application that is in need of light. Whether you're looking for a light to drive off of, or something to light up a campsite the S1 will exceed your expectations!
    Specifications:
    Lumens: 2,375 Utilizing 1 LED
    Wattage/Amps: 20W / 1.45A
    Dimensions: 2.1" x 2.1" x 2.1"
    Weight: 0.4 lbs
    LED Life Expectancy: 49,930 Hours
    Front Lens: Hard Coated Polycarbonate
    Housing: Hard Anodized & Powder Coated Cast Aluminum
    Bezel: Billet Machined Aluminum
    Hardware & Bracket Material: Stainless Steel
    Exceeds MIL-STD810G (Mil-Spec Testing)
    Built-In Overvoltage Protection
    IP69K (Waterproof up to 9ft & Pressure Washable)
    IK10 Compliant (Mechanical Impact Testing)
    CLICK HERE
  14. Queen of Spades
    Mar 20, 2009
    1,944
    Decatur, GA
    Which is the better system? XL Pro or XL 80? Will I also need a dimmer module or is it all built in? Links please additionally.
  15. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    3,310
    North of North Plains
    This is pretty exiting new light design!!! I was bugging you guys about 4 years ago to build a S1, and you finally did. Thank you! Looks like I need to figure out I want to start mounting theses little guys.
    That helmet mount will be sweet for us moto guys.
    Will there also be a “flush mount” version of the aluminum bezel?
    dino702 likes this.
  16. Baja Designs
    Jan 6, 2012
    1,419
    san marcos, ca
    The XL Pro puts out 4,900 Lumens while the XL80 puts out 9,500
    Here is the hi/lo harness that plugs inline between the light and factory headlight connector. You use your factory switch, low beam will be the reduced output.
    https://www.bajadesigns.com/products/xl-ktm-hi-low-harness.asp
    XL Pro, 2016 KTM
    https://www.bajadesigns.com/products/XL-Pro-LED-KTM-2014-2016-Kits.asp
    XL80, 2016 KTM
    https://www.bajadesigns.com/products/XL80-LED-KTM-2014-2016-Kit.asp
  17. Baja Designs
    Jan 6, 2012
    1,419
    san marcos, ca
    No flush mount planned right now. That could always change down the road if there is enough demand
    Whodatschrome likes this.
  18. Queen of Spades
    Mar 20, 2009
    1,944
    Decatur, GA
    Are these going to work with a '16 KTM 500 EXC-F? KTM updated their other models in '16 to use different bodywork/tank/ect.
  19. a_ron
    a_ron Adventurer
    Aug 3, 2015
    74
    White Salmon, WA
    Big question before ordering:
    I have a 2009 KTM 690 (orange frame). I am looking to install the baja design Squadron Sport or Pro light.
    The website says the Pro fits the KTM 690 from 2008-2013. The sport does note say this but its the exact same light besides the size of reflectors. I can't find ANY info anywhere online. Has anyone installed a Sport or Pro 2008-2013 light kit on there 2009 ktm 690? I can't find any info on how to install it or anything. Please help!!
  20. Baja Designs
    Jan 6, 2012
    1,419
    san marcos, ca
    Please give our team a call on Monday
    800-422-5292
    I believe it will work but some of our bike specialists can confirm
