1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
Bajaworx KTM Enduro windshield
Discussion in 'Thumpers' started by Bikedude987, Jan 3, 2018.
  1. Bikedude987
    Bikedude987 Been here awhile
    Jul 7, 2011
    589
    I’ve had one of these windscreens leading the charge on Katya, my trusty ’14 KTM 450 for about three months now. We’ve slayed singletrack together, climbed mountains, and gobbled up the miles at full chat. Here’s the low down on the Bajaworx enduro windscreen.
    A few days after hooking up with the Bajaworx crew, I received a neat, tidy package in the mail. Like the proverbial porridge, the box was not too big, not too small, but juuust right. Maybe it’s just me, but it really irks me when I get a pair of gloves shipped in a box you could live out of. No, Amazon, I did not like your packaging.
    Tear open the box here, though, and you get a carefully and correctly wrapped screen, complete with a bag of hardware taped in place (nice!) and a clear set of installation and care directions. The screen comes out clean and free from blemishes, and they even used high quality Makrolon polycarbonate in its construction. These guys obviously care about what they make and sell.
    Next up will have you tearing down your bike (ok just the headlight mask) to install the screen. You’ll have to punch a few holes in the stock shroud, but luckily this part is only about 20 clams if you need to ‘rework’ it for any reason. Removing the headlight assembly is as simple as disconnecting the wiring, removing the brake hose guide, and pulling the two rubber mounting straps.
    Here’s my first gripe: I’m a klutz and I want a template, darn it! I’m also borderline OCD, so I needed to get it straight. Out come the calipers and the sharpie and I scribe some lines of reasonable accuracy. A paper template that I can lay over the plastic mask and mark out the drill holes would be oh so nice, and save me about 15 minutes of fiddling.
    Hold your breath, get the drill centered and pull the trigger. If you’re lucky (who needs skill?) you’ll have replaced the sharpie mark with a nice, round hole. If you’re unlucky, you learn that it’s much easier to remove material than it is to add it. I cut it once and it was too short. I cut it again – still too short!
    One of the more refined features that are included with this piece of kit is the stiffening brackets that help reduce movement of the shield whilst out and about. Sadly, they stopped short of the mark on my particular steed. It should be noted that I’m attempting install on a model year this was NOT designed for, so no fault to Bajaworx.
    Yet again, the attention to detail surprises me, in this case the appropriate hardware has come pre-assembled; no digging through a bag of hardware looking for the “#4: 6mm screw – 30mm”, or some such nonsense. Just select long or short, and assemble one at a time being careful not to overtighten.
    Gotcha number 2 – Handguards. No self-respecting offroader would be caught dead without the sturdiest handguards that modern science and manufacturing can provide. Ok, so perhaps I’m being over the top, but in this case I run a set of aluminum guards in a mount of my own creation. This is really a worst case scenario as I’m running the bar all the way forward and I added some extra reach to the guards to clear my controls, so the bars mount extra far forward. A small issue that was solved with some ‘encouragement’ during install. Luckily this was a willing stand-in for the missing braces mentioned earlier and kept the shield very well supported.
    Ok, enough drivel. We can all find our way around a spanner, and who gives a rat’s arse about the box, right? How’s it ride?! I suppose the answer to that depends on your expectations. It’s a sheet of plastic after all. However, it’s a well designed piece of plastic; not only does this crew care, but they know what they’re doing. There’s a particular rider that this piece caters to, and that’s the rider who is maintaining high speeds over long distances, and who needs to mitigate some fatigue. This shield extends your personal range and increases your comfort.
    As I mentioned, I took this shield into some properly hairy scenarios, and I never noticed it; with one exception. I bottomed out hard in a G-out and let myself get pulled too far forward over the bars. My chest kissed the top of the shield, but that’s all. No harm, no foul. Otherwise, it’s utterly imperceptible until you get up in speed. Once you’re looking to cover some miles, you will notice well, nothing. And that’s the point. The shield takes all that wind pressure that would normally be pushing you over backwards and diverts it around you. When sitting, you will have practically no wind from the neck down. Unlike other products, this piece accomplishes this in such a way as to maintain smooth, laminar airflow across your helmet. This means that while your head is still in the wind, it’s not bobbling around and creating a roar. There’s some noise for sure, but it’s all quite tolerable.
    Last but not least is durability. Unfortunately (or fortunately?) I did not get the opportunity to crash test this shield, so I cannot speak to its performance in that arena. I would posit that this screen is the least of your worries in a crash, and that because the headlight assembly is essentially rubber mounted, it would likely survive any encounter with the earth. One area of improvement I would suggest is the brake line routing. The brake hose on my bike would rub constantly on the two ridges on the back of the screen, quickly developing a ‘smeared’ section. It’s a non-issue since the screen in nowhere near your sight line, but it’s kinda ugly nonetheless. Granted, it’s still the best looking plastic on my bike, so who’s to argue?
    All said, this is a well thought out, well made, and domestically sourced farkle that can provide some real world relief on those long stretches. Whether you’re headed to Dead Horse, or you’re in search of some fish tacos and a cold cerveza, the Bajaworx enduro screen is a welcome riding partner. Check them out at bajaworx.com
    Oceandiving954 and rvsparky like this.
  2. RideFreak
    RideFreak Torque Junky
    Apr 17, 2009
    15,584
    Out in the NM Dez somewhere
    I agree 100%. It's the only screen that looks decent on the smaller KTMs IMO. I have no doubt it'd look and work just as good on any bike with a similar number plate inc a 690.
  3. renogeorge
    renogeorge Let's ride!!
    Apr 7, 2007
    6,518
    Reno
    Funny you would say this. I had just contacted Bajaworx about fit for a 690.....Anybody try one on a 690 yet?
  4. RideFreak
    Apr 17, 2009
    15,584
    If you look at the way it mounts I don't see how it wouldn't work great on the 690. That's the first bike I thought of when I saw this. The angle of the headlight mask is very similar to the 500 and all it take is 4 bolts. Allowing it to rest against the ends of the hand guards actually helps stabilize it but even if it doesn't rest against the hand guards that doesn't really matter, you can't actually look through it, the windscreen is too low. It does really help with the wind force, on the 500 the air hit just below the helmet and it was smooth air, not turbulent.
    Magus likes this.
  5. renogeorge
    Apr 7, 2007
    6,518
    Reno
    It does look like it would work. Would you be able to take a measurement for me? Top of light insert to top of screen? Much appreciated?
  6. RideFreak
    Apr 17, 2009
    15,584
    no problem, it's 12 5/8" from that little point at the top of the HL to the top. The screen is pre drilled so those bolt locations are locked in but it obviously could be adjusted upward or downward depending on where you drill the mask.
    Fast1 and renogeorge like this.
  7. renogeorge
    Apr 7, 2007
    6,518
    Reno
    Thanks much!! For any 690 guys considering this shield, it is 3.5 " taller than the KTM "Touring" screen that a lot of guys, me included, are using. So a significant difference. Think I'll order one up and see how it works....
  8. Bikedude987
    Jul 7, 2011
    589
    Well, what the hell...looking at this from another computer only one of my pictures worked...lame. Will try to fix tonight.
    #8
  9. Navin
    Navin Long timer
    Sep 22, 2009
    29,080
    Looks about as effective as the Hardparts 690 touring screens we bolted on headlight shrouds ten years ago.
    #9
  10. renogeorge
    Apr 7, 2007
    6,518
    Reno
    Seems to me they are all coming through....
    #10
  11. renogeorge
    Apr 7, 2007
    6,518
    Reno
    About 3.5" taller....
    #11
    Navin likes this.
  12. Bikedude987
    Jul 7, 2011
    589
    well, cool. Guess I'll leave it then.
    #12
  13. silverdog
    silverdog Been here awhile
    Nov 20, 2003
    769
    Looks like it would feel good on your Adam’s apple....
    #13
  14. RideFreak
    Apr 17, 2009
    15,584
    Are you talking about hitting the shield with your neck or the wind? It gives a nice breeze upward toward into the bottom of the helmet, it's constant and not buffeting. As far as hitting your neck or head, that not an issue under normal circumstances, it's still down pretty far. Didn't give me a problem what so ever and I tested allot harder than I ride dualsporting. I switch back over to another mask if I'm using the bike normally, I use the shield is for long rides where wind protection helps.
    #14
  15. Bikedude987
    Jul 7, 2011
    589
    Yeah, crashing into your neck would not be ideal, but at least it's only the rubber straps holding the assembly on, so it's somewhat 'breakaway'
    #15
  16. TipsyMcStagger
    TipsyMcStagger Long timer
    Oct 28, 2006
    1,634
    NYC & NPR, FL
    Anyone got a picture of the brackets mounted?
    There is only one picture of the rear of the shield on the Bajaworx site, and I don't see the brackets. This is RideFreaks bike, maybe?
    The included instruction sheet has very tiny, B&W pictures that are nearly impossible to decipher.
    I'm mounting it on a 2014 headlight mask.
    #16
  17. TipsyMcStagger
    Oct 28, 2006
    1,634
    NYC & NPR, FL
    Well, I'm pretty sure this is how it's supposed to be :)
    #17
    Fast1 and Teeszy like this.
  18. Teeszy
    Teeszy Been here awhile
    Mar 29, 2015
    139
    95531
    Tell us more @TipsyMcStagger
    & for anyone who has tried both this screen and the ktm touring screen pn 76508065000, how do they compare? I think for hardcore riding I like the shorter and less expensive option which is the ktm screen but for roadtrips the bajaworx with its 3.5" height advantage stands out i bet... is mounting either of these screens going to be a problem on a MY16 FE501 headlight mask? Trying to figure out whish is more sano. Think i may shop around for the best deal on one or the other this summer/fall to use in the winter months. Peace
    #18
  19. TipsyMcStagger
    Oct 28, 2006
    1,634
    NYC & NPR, FL
    I'm not sure what more I can tell you. I just installed it on the mask three hours ago. :dunno
    #19
  20. Teeszy
    Mar 29, 2015
    139
    95531
    Feelings after riding offroad and on with that thing for a while?
    #20
