Balancing Tyres
Discussion in 'Australia' started by grumpyoldbstrd, Jun 9, 2018.
  1. grumpyoldbstrd
    grumpyoldbstrd Been here awhile
    Sep 16, 2007
    592
    Melbourne, Australia
    For over 45 years I’ve been changing my own tyres and balancing my wheels. Always installed the tyre with the valve spot at the valve, and then added weights to achieve a reasonable result.
    Just for laughs, I recently checked the balance of a wheel without the tyre and tube, and was surprised at how out of balance it was.
    My question for the collective wisdom: Is it worthwhile trying to balance the wheel before the tyre and tube are installed, and then fine tuning? I’m using a high quality static balancer.
    Always willingly to learn new stuff.
    Cheers,
    GOB
  2. wassie
    wassie Life is too short for traffic.
    Apr 21, 2011
    838
    Brisbane QLD
    The same goes for balancing.
    DustyWheels likes this.
  3. MJSfoto1956
    MJSfoto1956 Been here awhile
    May 12, 2017
    139
    Boston, MA
    Recently added a new 140/60-13 Kenda tire to my scooter. Aligned the tire to the white dot, but notwithstanding, the new tire caused nasty vibration at 40+ mph. Yesterday I added 3oz of Counteract Balancing Beads. Took a total of less than ten minutes to install. While hopeful, I was surprised just how smooth the ride became on the first trip out. I'm a believer now. YMMV.
  4. rvt
    rvt Big Fat Trail Bikes
    Feb 20, 2011
    1,979
    Western Australia
    I used to use sticky weights to balance the rim with rimlock. Then fit the tyre and use clamp on weights to balance the whole assembly. Mainly because sticky weights were cheaper.
    Now I seem to have enough clamp on weights that I do it all in one go.
    I put the dot near the rimlock.
    GodSilla likes this.
  5. fayeslane
    fayeslane Rankest of amateurs
    Oct 16, 2009
    3,762
    Albury, NSW
    Did this on my DR rear wheel recently and it was spot on. The rim, tyre, tube combo needs to be balanced as a unit IMO because thats what will cause vibes.
  6. GodSilla
    GodSilla I did that.
    Sep 21, 2006
    10,898
    GodSowncountry Australia
    I subscribe to the theory (and practice, where practical) of balancing the wheel without the tyre, but with the rimlock and tape. Stick-on weights are good for this. Then use the ballard's-style spoke clamp weights to balance the tyre, as they are infinitely adjustable.
    You only ever have to balance the tyre after that.
    Anecdote : I took a rim to get the tyre changed to Mick Cole m/cycles (after Mick had sold it) and they couldn't balance the front rim 'cos they don't keep the skinny stick-on weights to suit a 1.6 rim.
    Wodger63 likes this.
  7. rvt
    Feb 20, 2011
    1,979
    Western Australia
    The sticky weight strips can go crosswise, between the spokes. Bit of a tap with the hammer molds them into shape.
  8. abhibeckert
    abhibeckert Long timer
    Feb 15, 2010
    1,957
    Cairns, Australia
    How fast are you riding?
    My feeling is our highway speed limits are so low it's not important to get balance absolutely perfect, just reasonably close.
    Up here in cairns most of our roads are pretty rough anyway though, so perhaps a balance issue would be more noticeable down south on your fancy smooth highways.
    Whenever I get a tyre fitted by a shop they balance it, and I expect them to do a good job (try to find a trustworthy workshop/etc), but doing tyre changes myself I don't bother with balancing unless I've made a major change (like adding/removing a rim lock).
    #8
  9. Not the Messiah
    Not the Messiah Old enough to know better, but slow learnin'
    Jan 19, 2013
    943
    Melb'n, 'Straya
    GOB,
    I've been paying "professionals" for tyre fitting and balancing lately, so I've never done stuff like this myself. But if I did: I'd be trying the balancing of the wheel without tyre & tube. Do an extra careful jobbie of it. Then fit the tyre & tube and see what the difference is. I'd be thinking that the difference should be an indicator of the quality of build of the tyre.
    It might be optimistic, but if the tyres are quite consistent then balancing of the wheel might be enough. Or at least good enough to leave out a re-balance if you get caught short of time (you know, the occasion when you find you've got to change a tyre the night before a ride......).
    Cheers
    Brian
    #9
  10. fayeslane
    Oct 16, 2009
    3,762
    Albury, NSW
    Had a Heidenau that required 80gms to balance. Previous tyre needed 15gms.
    #10
  11. UncleGra
    UncleGra Road Grime
    Jan 16, 2008
    5,800
    'neath the Southern Cross
    Flatten your lead bits and stick them to the rim with the wife's nail glue...or use your own..
    #11
    Richarde1605 likes this.
  12. Richarde1605
    Richarde1605 Long timer
    Jan 1, 2015
    1,366
    NSW Australia
    Not only is nail glue good for nails, (doh), it is also excellent for cracked heels, and other split skin.
    And wheel weights
    Sent from my SM-G950F using Tapatalk
    #12
    UncleGra likes this.
  13. tomrux
    tomrux Been here awhile
    Sep 18, 2010
    452
    northside Briswegia
    I would like to see what kind of a static balancer you are using. Look up the meaning of the word static. If you are rotating the wheel then it is no longer static. You are just manually doing what the fancy machine is.
    N yeah balance once the whole shebang is together. Same same as doing it in 2 steps.
    Cheers Tom R
    #13
  14. Richarde1605
    Jan 1, 2015
    1,366
    NSW Australia
    Yes, the wheel/tyre assembly is static when it stops with the heavy part down, then you add some weight about 180 degrees from there. Spin it yes, but only slowly, until it becomes stationary in totally random positions. Then it is balanced. You also get to look at runout which can also cause vibrations.
    Machines do it dynamically using 'vibration' sensors.
    Come the revolution I will still be able to rely on gravity...
    #14
    a2zworks, Big Willy and robmoto like this.
  15. Big Willy
    Big Willy Gen. Italia
    Nov 28, 2008
    4,272
    Sunshine Coast
    Oh come on...:lol3
    Dynamic wheel balancer reads out of balance while it is spinning.
    Static wheel balancer tells you the heavy part of the wheel when it has stopped spinning
    #15
    Wodger63 and Richarde1605 like this.
  16. grumpyoldbstrd
    Sep 16, 2007
    592
    Yes, gravity has always worked for me. Without the tyre and tube I was surprised that the heaviest part was at the valve hole (on both wheels)... kinda counter intuitive. Perhaps that’s where the rim is joined? Wish I knew more about the construction of rims. BTW, this was done with the disc attached (rim locks not used)... could the disc have a heavy spot?
    Anyway, balanced the wheel without the tyre and tube, then installed them and was surprised at how little extra weight was needed to do the final balance. Out in the bush, I used to stress about getting the tyre back in the same spot – not any more. This’ll be my method in the future.
    #16
  17. vagueout
    vagueout Long timer
    Mar 3, 2010
    3,093
    sydney, east
    This topic was raised elsewhere on this forum a few years ago, needless to say some very strong opinions were offered going both ways. I'm inclined to think if you do your own it can't hurt to do wheel first then tyre, but of course there are those that reckon balancing at all is a waste of time!:*sip*
    #17
  18. Big Willy
    Nov 28, 2008
    4,272
    Sunshine Coast
    Nah...they wouldn't drill a hole where the rim joins together.
    I suppose once the rim is balanced, it wouldn't be a bad idea to pump up a tube, place it on the rim (still without a tyre) and see how heavy the valve area is.
    Discs themselves would have a negligible effect on balance as they are close to the centre of the wheel so very little centrifugal effect (imo) and likely to be machined with fine tolerances and even wear in most instances.
    #18
  19. 1coolbanana
    1coolbanana Long timer
    Aug 25, 2009
    5,284
    NW Sydney, Australia
    I recently discovered quite the opposite on a pair of large discs (990).
    Discs made a huge difference to the balance as the mounting holes have a few mm clearance on the screws.
    I ended up clocking the discs on the static balancer to get them within 0.1 TIR and it made a huge difference to the static balance and amount of weight used.
    #19
    Big Willy likes this.
  20. Big Willy
    Nov 28, 2008
    4,272
    Sunshine Coast
    Hmmm...well there goes that theory :lol3
    #20
    1coolbanana likes this.
