Bar Mounted MC Upgrade, Question On Throttle Cables
Discussion in 'Airheads' started by jchussey, Dec 4, 2018.
  1. jchussey
    jchussey Adventurer
    Aug 25, 2017
    48
    Centennial, CO
    Although I'm a stickler for originality when it comes to my '75 R90/6, I have finally decided to do a bar-mounted master cylinder. I'm going with the 12mm unit, part number 32722302367, but it appears to be built for just one throttle cable while the /6 has 2. Is it simply a matter of swapping the cover to accommodate the second cable? (I have the later, squarish cover and the larger diameter, 2-cable 33 throttle cam disc). Thanks.
  2. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    5,998
    Longmont, CO
    Dubious.. You will have to go with the single cable setup and the cable splitter (2 into 1) under the frame backbone. The fitting on the chain end is different for one vs. two cables and fits a different groove in the lower handlebar housing AND the cover. But I don't have an old dual cable setup to compare anymore. I'm willing to bet the cam has a different rate but I kinda think that will work out, just a different feel. I think I have a spare single setup around if you want to come up here some WARM day and play with it. I'm in Longmont.
  3. craydds
    craydds Long timer
    Aug 3, 2010
    1,179
    Las Cruces, NM
    Not sure of the part number (will research my past posts) but I got a bar-mounted MC with a dual throttle cable for my '75 R90s; so, no changes to my dual cable set-up. I have another MC at the house, brand new in the box, ready to go on my son's '76 R90s; I'm sure it's the same one I used, so same part number. I do recall that I had to get a new throttle grip and cam to fit with the MC; most likely have those new parts for my son's bike at the house. Will get part numbers for you if you need them.
  4. beemerphile
    beemerphile Unreconstructed Southerner Supporter
    Jan 31, 2006
    3,607
    Danielsville, GA USA
    I have a factory new bar mounted 13mm master cylinder that has dual throttle slots. It is part number 32 72 2 310 746. Available if you are interested.
  5. 2WheelTraveler
    2WheelTraveler backinthesaddleagain Supporter
    May 29, 2013
    497
    Tahoe
    If you want to use a single cable throttle/MC unit then a splitter will be needed. Or, you could use a dual throttle MC unit. All parts needed are available from BMW, or you can find them on ebay. A little searching on Max BMW's website (fiche) will yield part numbers.
  6. jchussey
    jchussey Adventurer
    Aug 25, 2017
    48
    Centennial, CO
    Thanks guys. I have tried a 13mm MC. It is too hard and not progressive enough with the single ATE for my tastes, so I am set on going with the 12mm size. But my searches on Max have not turned up anything in the two cable variety. I'm not opposed to go into a splitter, but would like to avoid it if possible due to added expense.
  7. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    10,828
    Shoreline, WA
    I think that Tiggum has a NOS two-cable perch that he might part with...
  8. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    6,463
    The easiest way out is a set of cables and junction box, along with the throttle cam for an R80S/T, or an '84-'85 R65.
    #8
  9. AntonLargiader
    AntonLargiader Long timer
    Aug 28, 2003
    6,131
    Charlottesville, VA
    #9
  10. Tiggum
    Tiggum Retired
    Mar 2, 2015
    338
    Nashvegas
    Nope, Solo, I am going to use the entire 2 cable unit, and I am going to use 2 new throttle cables from a R100RS. I have a complete single throttle cable, splitter and two carb cables which came off my R65LS which I will be happy to sell (and remember, while it's 35 years old, it only has 789 miles use). And Anton, thank you for all your super informational postings. Really a great resource.
    #10
  11. nobbylon
    nobbylon Been here awhile
    Aug 13, 2012
    872
    I nearly went bar mount mc a couple of years ago on my 90s. Happy I didn’t and bought a new under tank mc. It just looks cleaner. Granted mines a double disc and it’s always had superb stopping power with the goodridge lines. My 75/6 is a single disc and really could use some more brakes.
    #11
  12. jchussey
    jchussey Adventurer
    Aug 25, 2017
    48
    Centennial, CO
    #12
  13. Kiwiabbo
    Kiwiabbo Been here awhile
    Apr 16, 2014
    480
    Well I have both, and from this I can happily report that the handlebar mount makes a lot of difference, however if you haven’t tried it then you won’t know the difference so you’ll be happy with what you have. I’m luck enough to have two of these with my father and can do comparisons with different set ups.
    #13
