Barbershop 7/11
Discussion in 'Some Assembly Required' started by Wildebeest90210, Nov 3, 2017.
  1. Wildebeest90210
    Wildebeest90210 Long timer Supporter
    May 24, 2013
    2,908
    So whilst transiting from pub to pub down the Cowley road in Oxford I found this in a barbershop. Being quite a few beers in I decided to investigate and was sent to a nearby guitar shop where I was treated to a twenty minute soliloquy from the owner on the merits of the K series BMW, he did though take my number and promise to pass it to the owner. A week later and a phone call and I met up this morning with the owner and shook on £2200. I'm very happy with that. It whispered to me that it has always really wanted to be a mid 80's endurance replica.
    So, I figure the winter won't be much fun just sending off the Banshee parts to get the frame made so I'm going to do this instead and sell it in the spring leaving the Banshee motor and radiator in the spare bedroom for now.
    It is a 7/11, a very early 1985 750 frame and a 91 1127cc motor. I'm sure this period conversion will eventually be thought of as a kind of Triton of its day?? It does have a Spondon swing arm and an Ohlins shock, TL1000 front end.
    Plenty to do to make it black and gold...
    I had a ride out on it, the motor is strong and runs clean, very torquey. Front discs are warped which made me a little cross eyed and the steering is so steep with the TL front end you are trying to pull the thing back out of corners where the front end is falling in. Not a relaxing ride but ok for 100mph+ straight. I got loads of boring specs coming up as it comes apart... :hmmmmm
    Like this a little maybe??
  2. Wildebeest90210
    May 24, 2013
    2,908
    I've been struggling a little with the concept of building something to sell rather than building it for me but the plan is to sell in the spring so rather than an outlandish Japanese Bōsōzoku or something in primer grey with sharks teeth I'm going for the slabside bodywork and black and gold which was the 1988 GSX-R1100J limited edition. Decals purchased and paint only has to be gloss black, simple.
    I measured up and have close to stock wheelbase 56", 1100 was 57.7 I did wonder if the Spondon arm had been lengthened but it would seem not.
    Weight is 420lb wet , the 750 was 410lb and the 1100 529lb. An extra 30-40Hp with the 1100 motor over the 750.
    The motor is prefixed V711 which is a 1991M, should have 40mm carbs but I only have 36mm, runs just fine though.
    The rake though is another matter. It comes in at 23.2 degrees, lethal.
    So if I drop the forks as far as I can in the lower triple
    I then get a more respectable 25.1 degrees and 3/4" reduction in trail, would have to make a new top triple though. The stock was originally 25.5 degrees but they soon sharpened it to 24.5 but lengthened the wheelbase an inch at the same time.
    So to overcome this....I already have an R6 front wheel and lower triple. Forks are 43mm and cheap on Ebay so back to a conventional fork and sell the TL1000 front end complete.
  3. 11motos
    11motos Feral Rider
    Oct 27, 2017
    1,485
    On the Road
    Cool project. Thanks for sharing.
    How is the engine bolted at the bottom? Are those custom brackets? Hard to say.
  4. JCool
    JCool Long timer
    Oct 15, 2016
    3,686
    Increasing rake increases trail.
  5. Wildebeest90210
    May 24, 2013
    2,908
    That's what I meant :doh
    JCool likes this.
  6. Joezeph
    Joezeph Been here awhile
    Jun 18, 2017
    735
    AR
    Do you still drink too much???
    :hide
  7. Wildebeest90210
    May 24, 2013
    2,908
    I think they are factory, the reason this conversion was popular was the fact the 1100 motor goes straight in the 750 chassis. Most people at the time didn't change brakes or suspension though leading to an 'interesting' ride.
    Nemosengineer and 11motos like this.
  8. Wildebeest90210
    May 24, 2013
    2,908
    Wrote that sober!! Going to pub in minute though :drinkI am in part doing this project to keep me out the pub (weekdays only!), it's only 50 yards away and I've got in to the habit of going for a couple after work..... The logic is that my Banshee project is mainly getting parts made and waiting whereas this I can really get stuck in to and work in to the night. I am really enjoying tearing this apart.
    #8
  9. Wildebeest90210
    May 24, 2013
    2,908
    Definitely time for a beer.... :beer
    Stuff ordered today. I know the exhaust that was on there is more practical and probably better suited but I've wanted a bike with one of these for about 30 years.
    Decals.
    #9
  10. 11motos
    11motos Feral Rider
    Oct 27, 2017
    1,485
    On the Road
    oh ok. That is very convenient. I had a 750 at some point but didn't realize they were the same dimensions.
    The 750 had good power so the 1100 should pull like a mule.
    Love projects like this. Keep up the good work.
    Thanks.
    #10
    Wildebeest90210 likes this.
  11. wombataus
    wombataus wombat
    Jan 11, 2014
    38
    mary valley
    here ya go mate not a 7/11 but close 100_0428.jpg
    #11
  12. Wildebeest90210
    May 24, 2013
    2,908
    I believe this is what's known as 'artisanal metal craft in a modern café style'.
    Lock stops removed a'la 'acksaw and oil cooler mount screws used instead.
    Nickel town customs battery box.
    Not the first time it's been fitted :fpalm A selection of holes, and not in a WLW style! This is the worst bits I've found so not too bad really, the bike has been looked after, moly on all the threads and everything greased. There was zero swarf on the drain plug magnet so the motor should be fine, I hope there'll be no more surprises.....
    #12
    Nemosengineer, waylongway and 11motos like this.
  13. Joezeph
    Jun 18, 2017
    735
    AR
    Oh how l miss the English pub on every street corner.....as well as a chippy on the way home!!!!
    #13
    Velocipede likes this.
  14. 11motos
    11motos Feral Rider
    Oct 27, 2017
    1,485
    On the Road
    sure someone liked the dremel and drill thrills way too much. lol
    thanks for keeping us posted.
    #14
  15. Wildebeest90210
    May 24, 2013
    2,908
    Oil cooler removed and it's clear to see the frame and engine were painted in one lump, I heard that people do things like this :dunno
    What a beautiful arm :viking
    All ready for engine out tomorrow then get the frame off for vapour blasting.
    #15
  16. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    10,961
    Orange County, CA
    you're really kicking this thing in the ass aren't ya!
    #16
  17. Wildebeest90210
    May 24, 2013
    2,908
    A tight fit indeed, no wonder the later frames had one removable side. The breather cover on top had to be removed along with the sump, pick up, and the oil filter got a screwdriver hammered through it. Messy but it's out :-)
    Not so great, number two pot has been running lean. A careful investigation required, I'll need to know why before it goes back in....
    #17
    Nemosengineer, Te Hopo and nuggets like this.
  18. 11motos
    11motos Feral Rider
    Oct 27, 2017
    1,485
    On the Road
    hopefully is just the carb and/or simple valve adjustment.
    #18
  19. larryboy
    larryboy Stable genius.
    Jan 9, 2005
    24,426
    Über Alles,California
    I zoomed in to see if the frame had the removable section before I got to where you said it didn't.
    :lol3
    #19
  20. waylongway
    waylongway madmax Supporter
    Dec 16, 2009
    3,859
    NorCal
    Holes.......:norton Burned in my mind and in my knees.....:yikes
    Now when I said I had a 86, was because Rob had 2 or 3 ......Ever the sought after blue and white one.....:wink:
    He liked to grind the pegs 1/2 off before giving it the final wad.....:flush
    Thanks for the memories.......!! :smooch
    #20
    Wildebeest90210, Te Hopo and larryboy like this.
