1. eNewsletter Sign Up
Base plate for KTM 990 ITG foam air filter.
Discussion in 'Vendors' started by gefr, Feb 27, 2013.
  1. Nosferatu82
    Nosferatu82 n00b
    Jan 20, 2016
    7
    Malta
    Just send him a PM. I ordered one like 2 weeks ago and it was delivered without a fuss and in time. I am impressed with the sturdiness of the plate.
    If you (like me) did some reading on the issue you will find that ordering the plate from Gefr and the filter from a Supplier (I ordered mine form MerlinMotorsport.co.uk) will cost you abt 60-60% less than buying the full set from "a" Supplier. From what I can tell now, everything points in the direction that the quality of both solutions is equal.
    #21
  2. SE-Des
    SE-Des Adventurer
    Feb 1, 2016
    27
    Sweden
    Thanks, arrived at the same conclusion; base plate from Gefr and ITG filter from local supplier Trendab (I'm in Sweden) for about 60% the price. Just have to learn how to re-map the beast when it's all installed
    Sent from my ONE E1003 using Tapatalk
    #22
  3. thebarber
    thebarber Been here awhile
    Nov 10, 2008
    105
    Hi Gefr, would this filter fit https://www.merlinmotorsport.co.uk/p/itg-megaflow-air-filter-jc30-itg-jc30
    hi, would the Rottweiler skins fit the original jc30/65 filter?
    I'd like to do this but would prefer the added security of the skin.
    Cheers
    #23
  4. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,047
    East Med, Greece
    #24
  5. thebarber
    Nov 10, 2008
    105
    #25
  6. SE-Des
    SE-Des Adventurer
    Feb 1, 2016
    27
    Sweden
    #26
    thebarber likes this.
  7. thebarber
    Nov 10, 2008
    105
    Seems like a lot of money for an ally plate tho.
    I'm also interested in the Rottweiler storage box but again ££££££
    #27
  8. SE-Des
    SE-Des Adventurer
    Feb 1, 2016
    27
    Sweden
    It's stainless steel. I saved a bunch by using gefr's baseplate and an ITG filter as opposed to the Rottweiler kit, so figured why not.
    #28
  9. thebarber
    Nov 10, 2008
    105
    I'm gonna do the filter 1st
    #29
    SE-Des likes this.
  10. SE-Des
    SE-Des Adventurer
    Feb 1, 2016
    27
    Sweden
    Good choice. Apart from the fact it makes filter cleaning a doddle and reduces weight it does make a wonderful growling noise when you give the throttle a good twist.
    #30
  11. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,047
    East Med, Greece
    Sorry, I do not make snap out brackets.
    Cheers
    #31
  12. thebarber
    Nov 10, 2008
    105
    No worries, I've sent funds for the base plate
    Cheers
    Andrew
    #32
  13. benlikes69
    benlikes69 Been here awhile
    Nov 24, 2013
    107
    Hi mate,
    How do I order one of these.
    Ben
    QUOTE="gefr, post: 20820754, member: 19808"]Aluminum base plate cut with laser for KTM 990 ITG Superflow foam air filter. Matches with ITG JC30/65 and JC30/80 model.
    Cost will be 45€, shipping is free.
    It can take up to 22 days to reach buyers, though it usually reaches USA in 14 days.
    Upper side:
    Lower side:
    Plates without the breather hole and/or without temp sensor are now available, you just need to ask them specifically.
    I can also include blanking plates with another 5€.
    DZUS half turn clips and sealing flanges for throttle bodies are included. Sealing flanges should be fitted under the base plate.
    Foam filters are not included. You can find a local distributor here:
    http://www.itgairfilters.com/megaflow-introduction.asp
    one shop option:
    Merlin Mailorder Ltd, Wiltshire, SN14 7EZ, UNITED KINGDOM[/QUOTE]
    #33
  14. mountaincadre
    mountaincadre Long timer
    Jul 18, 2012
    1,797
    Mid Calder,Scotland
    [/QUOTE]
    Gefr are you still making baseplate for the itg air filter for the 950?
    #34
  15. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,047
    East Med, Greece
    Yes Sir. 990 and 950.
    Cheers
    #35
  16. benlikes69
    Nov 24, 2013
    107
    Can you please email me so I can order a base plate.
    chefbhp@gmail.com
    Thank you
    #36
  17. X@v
    X@v n00b
    Nov 19, 2007
    2
    Normandy, France
    Plate and filter installed last week-end on my Adv 950 S MY2004. Works fine ! :clap
    Some pictures during installation :
    Info needed:
    Model / Year : ADV 950 S / 2004
    Kms to date : 67500kms
    Carbs
    Kms since last valve adjustment : just done
    Fuel type / RON 98
    Home Altitude (Above Sea Level - ASL) : 100 ft
    Operational riding range relative to Home altitude (+/-).
    Exhaust System - 2-1 Adventure Spec
    Silencers - Akra / DB killers Yes
    Carb Settings:
    Main Air Jet size - Stock
    ACV Air Jet size - Stock
    Idle Air Jet size - Stock
    Low Speed Jet size - Stock
    Starter Jet size - Stock (42)
    Main Jets size - F 170 / R 170
    Needles / OEM
    Needle Clip Position - 3
    Needle Clip washers - OEM Std
    Float height (in mm) 3mm
    Floats measure method: Carbs tilted on side
    Idle Air Screws - F 2.25 / R 2.25
    Carbs Sync'd? - Y more or less...
    Performance comments:
    Warm Idle : Stable and even
    Acceleration off Idle from standstill: - Clean, no hesitation
    Cruise performance (4 - 5K rpm): No hunting
    Hard acceleration in 5th gear from 4K+rpm : Whoa !
    WOT acceleration: Whoa !!
    Over-Run / Decel exhaust Popping: None
    Fuel Economy: Miles/PG or / Litres/Km : not measured yet...
    #37
    MadM and SE-Des like this.
  18. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,047
    East Med, Greece
    #38
  19. rinho
    rinho Rinho Féroce
    Jul 19, 2009
    1,731
    back in France but Soul still in North America
    Hi Xav... tiny typo here, I guess :D
    #39
  20. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,047
    East Med, Greece
    Excuse me? What do you mean?
    #40
