1. eNewsletter Sign Up
Base plate for KTM 990 ITG foam air filter.
Discussion in 'Vendors' started by gefr, Feb 27, 2013.
  1. rinho
    rinho Rinho Féroce
    Jul 19, 2009
    1,733
    back in France but Soul still in North America
    Nothing, my mistake.
    #41
  2. rinho
    rinho Rinho Féroce
    Jul 19, 2009
    1,733
    Baseplate (and filter) received, nice job
    Oil vent oil hole is not where I'd have drill it, kinda hard to put everything in position, somme pressure on the baseplate may wear the plastic ring on the carb.
    However, not sure it could have been put in a different way (filter wall is thick, air trumpets are wide, throttle mecanism on the other side...).
    Deception, JC30-80 is too high, seat is against it, making the glove box being raised (Rotweiller Snap Out used here)
    Note related to the baseplate but maybe (I did not check) the carbs holes can be moved a little bit to get the filter a bit forward ?
    I hope the filter frame will bend instead of the baseplate
    I made a firewall, during the first test (half an hour riding) it keep the carbs 25celcius lower than parts being under the protection (vacuum pipe from front carb)
    [​IMG] [​IMG]
    First test:
    Info needed:
    Model / Year : ADV 950 S / 2006
    Kms to date : 64000kms
    Carbs
    Kms since last valve adjustment : 10K
    Fuel type / RON 98
    Home Altitude (Above Sea Level - ASL) : 5 ft
    Exhaust System - 2-1
    Silencers - Akra / DB killers Yes (from Leo Vince, bigger)
    Carb Settings:
    Main Air Jet size - Stock
    ACV Air Jet size - Stock
    Idle Air Jet size - Stock
    Low Speed Jet size - Stock
    Starter Jet size - Stock (42)
    Main Jets size - 168/172 (first test
    Needles / OEM
    Needle Clip Position - 3
    Needle Clip washers - OEM Std
    Float height (in mm) 3mm
    Floats measure method: Carbs tilted on side, un bit over to make it easier
    Idle Air Screws - F 2.5 / R 2.5
    Carbs Sync'd? - recently but not since ITG
    Overall feeling is like I was riding one gear lower than I actually was.
    Need some fine tune but looks to be 98% ok.
    I wonder if I shouldn't try going 172/176 before
    #42
    dooby likes this.
  3. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,047
    East Med, Greece
    Thanks for detailed description.
    Cheers
    #43
  4. rinho
    rinho Rinho Féroce
    Jul 19, 2009
    1,733
    I just don't know why I ordered 80mm, I guess I read too quickly and mixed information...
    #44
  5. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,047
    East Med, Greece
    Maybe you can send it back. They were very friendly when I bought one.
    Cheers.
    #45
  6. rinho
    rinho Rinho Féroce
    Jul 19, 2009
    1,733
    You are right, I can try, but I oiled it and used it before seing it's too tall.
    I'll send them a message.
    #46
    motow4life likes this.
  7. Winterwolf
    Winterwolf n00b
    Feb 16, 2017
    3
    Am just about to order the base plate (I emailed you this afternoon) it's for my injected 990 smt without the breather hole... And will order the air filter this afternoon
    .... Not sure what these blanking plates are for this, and do I need them?
    Cheers
    Ben
    Sent from my Nexus 5 using Tapatalk
    #47
  8. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,047
    East Med, Greece
    http://advrider.com/index.php?threads/sas-epc-removal-950-super-enduro-vs-950-adventure.721683/
    http://www.ktm950.info/how/Orange Garage/Emissions Equipment/epc/sas_epc_removal.htm
    The blanking plates close the openings at the side of the motor, where the EPC/SAS is attached. This system allows some air from the air filter to enter the exahausts in order to enrich the exaust gas with oxygen in order to pass emissions regulations. When the air box is removed, these openings at the side of each cylinder need to close. You could stick a thick bolt inside the ruber hoses, or remove the whole system from the motor sides to the valve at the rear of the air box.
    Hope that helps.
    #48
    Winterwolf likes this.
  9. Winterwolf
    Winterwolf n00b
    Feb 16, 2017
    3
    Thanks.... I've got a SAS blanking kit somewhere I never got round to fitting.... Perfect time to do it now ☺️
    #49
  10. mimmo
    mimmo n00b
    Feb 18, 2017
    3
    I gefr I write from Italy, I am interested to the base plate for a ktm 950 adventure, could I contact you tu buy it?
    #50
  11. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,047
    East Med, Greece
    Hello there,
    Base plate costs 45€, blanking plates another 5€ if interested, shipping included.
    I need to know if you need the breather hole on your base plate.
    Please make sure your mail address is included in your Paypal details.
    Cheers.
    #51
  12. mimmo
    mimmo n00b
    Feb 18, 2017
    3
    The plate is arrived a week ago :-) I want to buy the filter and the socket from Merlin, I read they have the grommets for the holes on the plate. Need I them? Thanks
    #52
  13. Winterwolf
    Winterwolf n00b
    Feb 16, 2017
    3
    Got my base plate today (cheers George!).. Will try and fit it all over the next couple of nights.. Wish me luck
    #53
  14. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,047
    East Med, Greece
    Sorry, I got confused. Did you receive your aluminum air filter base today, os a week ago?
    Did you find the elastic grommets in my envelop? Why do you need the ITG grommets? I am not sure they produce a diameter that fits the KTM base plate.
    Cheers
    #54
  15. mimmo
    mimmo n00b
    Feb 18, 2017
    3
    I received the plate a week ago, but only yesterday I went home, so I wished to thank you. I have received the two sealing flanges with the plate. I have seen on the Merlin's site the grommets and I wasn't sure they were the same thing.
    Thank you for your prompt reply
    #55
  16. gefr
    gefr Life is a trip
    Nov 26, 2005
    5,047
    East Med, Greece
    Cheers.
    #56
  17. omega300
    omega300 n00b
    May 16, 2016
    1
    Italy
    Hi gefr, sent you a PM
    #57
  18. MadM
    MadM Dreamer Supporter
    Jun 12, 2008
    1,098
    Slovenia
    Another happy customer! 950 Adv with no breather hole.
    #58
  19. Edys
    Edys n00b
    Oct 1, 2017
    3
    Worcester
    A great piece of the set
    #59
  20. Duker1991
    Duker1991 n00b
    Apr 8, 2018
    1
    Holland
    are they still available for superduke 990 ??
    hope i can order still.
    also which ITG filter fits a superduke 990?
    #60
