BaseCamp Tutorial
Discussion in 'Mapping & Navigation' started by smbjm, Apr 1, 2015.
  1. ChuckieSmith
    ChuckieSmith Adventurer
    Apr 2, 2005
    71
    I tried the same and got the same results you got. I then went to newEnglandriders.org website then the gps link in the left column and was able to access the tutorial. I hope that all makes sense.
    cwroady likes this.
  2. smbjm
    smbjm Been here awhile
    Sep 24, 2010
    285
    Southern Midcoast Maine
    I updated the link in the original post so it should be good now. Thanks for pointing it out.
    cwroady likes this.
  3. ChuckieSmith
    Apr 2, 2005
    71
  4. Trailryder42
    Trailryder42 Long timer
    Oct 3, 2006
    1,065
    Amarillo, Texas
    Is this tutorial from 2015 still relevant to the 2017 program?
    Any other good tutorials for the current incarnation of the program anyone can recommend?
    Will my previous knowledge and use of Mapsource be a plus or a hindrance in learning and using Basecamp?
  5. smbjm
    Sep 24, 2010
    285
    It's still current, there have been no significant changes to the program. In fact there have been no updates to BC in well over a year.
    There are quite a few videos on the web covering various BC functions but none are as comprehensive as this, IMO.
    I personally used MS for years before switching over to BC, and found I did have to unlearn a few things but it was really not that much, and that was without this tutorial.
    The biggest difference, and I think the most important thing to understand, when learning BC is the database nature of your information.
    kwthom likes this.
  6. abruzzi
    abruzzi Long timer
    May 17, 2007
    1,179
    The New Mexico Desert
    As someone who used basecamp for years on Mac, and just had to switch back to Mapsource on an old XP laptop to use a new-to-me 276C, thats the bit that is the hardest to unlearn. I actually much prefer BC.
    (I suppose I could run an old version of BC on the laptop, but its slow, and even Mapsource struggles a bit.)
  7. dpike
    dpike BeeKeeper
    Nov 21, 2015
    1,185
    New Jersey
    i have the same map version installed on my computer and on my device.
    when i used the map installed on my computer it doesn't show topo shading
    when i switch to using the map from the device it shows shading
    how do i get topo shading to show from the map on the computer ? i tried reinstalling the map on the computer but that didn't work.
    thanks.
  8. Didediedide
    Didediedide Adventurer
    Jul 7, 2016
    30
    How often does Basecamp update the OSM map, I believe the latest version is 22Dec 2017, would this be correct and is it normally updated more frequently
  9. smbjm
    Sep 24, 2010
    285
    BaseCamp does not update any maps.
  10. TomInCA
    TomInCA Been here awhile
    Dec 4, 2010
    738
    Murrysville, PA
    In the Menu under Maps, you can select the map that is being used. Mine is 2019.1, so I would guess that is pretty much updated.
    When you download Garmin Map updates, be sure to select the option to install to device AND computer.
  11. TomInCA
    Dec 4, 2010
    738
    Murrysville, PA
    I just thought I'd add, what a ridiculous naming scheme Garmin has that we are in January, 2018 and these idiot think they are special by releasing version 2019.1.
  12. smbjm
    Sep 24, 2010
    285
    He is referring to OSM maps not Garmin Maps. This is an OSM issue not a BaseCamp or Garmin issue.
  13. Didediedide
    Jul 7, 2016
    30
    G'Day All, Sorry I'm not real computer literate and haven't explained my self very well. I'm only just starting to learn Basecamp and OsmAnd.
    Thru advice on this site I purchased a Kyocera Pro phone and installed OsmAnd .
    I have also been learning to make additions to OSM maps.
    What I'm now trying to achieve is getting the same version OSM map on my laptop on Basecamp and the same version OSM map on the phone
    At present after downloading the latest up date from OsmAnd maps to my phone the map is different to the map which I have just downloaded to Basecamp via Garmin.openstreetmap.nl on my laptop.
    I hope you can make sense of all that, so I can plan a route on Basecamp and the same route appears on OsmAnd
  14. smbjm
    Sep 24, 2010
    285
    The issue you are having is an OSM issue. They need to update the Garmin version of the map and they do not update all versions on the same schedule. Once they have updated the map and you have downloaded it to your computer you will be able to select it in BaseCamp using the pull down menu.
    Since this is not a BaseCamp issue and has nothing to do with the BaseCamp Turorial I suggest that if you need further info you start a separate thread - you will likely get much more response than in this one.
  15. Didediedide
    Jul 7, 2016
    30
    Thanks Mate , a lot of learning for an old pensioner
    Regards Paul
  16. Mossy87
    Mossy87 Irish inside!
    Nov 23, 2015
    204
    SoCal
    Thank you for the tutorials, after two years I will finally be able to use my gps to full potential.
    During the tutorial, you shared those photo points to help us build. Is there any sources online that have POI for each state that I could import to basecamp.
    For instance, if somebody had a bunch of campsites that could be put in a folder etc. would be great to help build a trip.
  17. smbjm
    Sep 24, 2010
    285
    There are a lot of sources for custom POI files. Probably the most comprehensive is POI Factory. They have more POI files than you could ever desire and a ton of information on how to create and use them.
    http://www.poi-factory.com/
    The New England Rider website has a ton of information on riding in the northeast.
  18. longtrip68
    longtrip68 Been here awhile
    Jul 25, 2012
    103
    Michaux State Forest
    I have had this issue too. Any ideas?
  19. Didado
    Didado Long timer
    Oct 5, 2015
    1,226
    Amsterdam
    That's no wonder because Basecamp is dead. Garmin stopped developing the program in 2016. In a month or so, you can't use Garmin's cloud services any longer to backup your stuff.
    I can't even make a backup on MacOS any longer. I get errors all the time. It is just a matter of time before the program will stop working all together as your Operating Systems are being updated.
    It's a pity because I really like Basecamp. Sure, there are a million online routing tools but they are no good when I'm travelling and I have bad cell reception or bad wifi. I haven't found a simple to use alternative yet.
    Magile likes this.
  20. Menhir
    Menhir Been here awhile
    Mar 11, 2017
    104
    Maybe now they'll stop requiring having it as a pre-condition to updating my maps. :eek7
    It would be nice to free up some extra space on my computer for applications I actually use. :-)
