BaseCamp Tutorial
Discussion in 'Mapping & Navigation' started by smbjm, Apr 1, 2015.
  1. ConiKost
    ConiKost Been here awhile
    Feb 3, 2020
    259
    World
    Sure, that's more steps ;-)
  2. ConiKost
    Feb 3, 2020
    259
    World
    I am not using the function anyway ;-)
  3. Bob599
    Bob599 Bob599
    May 5, 2008
    401
    The land of Beer and Cheese (Hartland WI)
    Does anyone know how to export a google map into Basecamp to load in a Garmin device?
  4. ConiKost
    Feb 3, 2020
    259
    World
    You need to create this as a custom map for Garmin devices.
    Keep in mind, that this format is limited and can't be used for a whole country.
    Some info here: http://www.gpsrchive.com/garmin maps/Custom Maps Tutorial.html
    CavReconSGT likes this.
  5. Bob599
    Bob599 Bob599
    May 5, 2008
    401
    I just tried the site MapstoGPX.com and it worked! free to use, but I need to turn it into a turn by turn route. I just copied the URL into the box on their site and presto its now in Basecamp!
    Hopefully not with a virus or malware????
  6. LewisNClark
    LewisNClark Long timer Supporter
    Apr 12, 2004
    3,568
    North GA and Atlanta
    Maybe someone knows/has an opinion:
    Many people create and share Basecamp GPX files that have several separate "Tracks" and separate "Routes", all within one GPX file, why do people not combine Tracks and combine Routes (with the Join utility) into one file.
    When doing off road trails why not just do Tracks, aren't Routes a waste of time for off-road "trails", or are people doing Routes just to have Waypoints.
    Thanks for any thoughts.
    Basecamp has been so difficult but I have not found anything any better to create Tracks and Routes.
  7. smbjm
    smbjm Been here awhile
    Sep 24, 2010
    382
    Southern Midcoast Maine
    I'm not exactly sure what you're getting at but you can certainly join a number tracks together and join a number of routes together. It's pretty easy to do in Basecamp but I don't know about other routing programs or apps.
    Routes don't make much sense for off road if the underlying map does not have routable trails for the route to follow.
    BTW you can used mixed profiles in routes. So for example if you have a route that and you want to go off road in a section you can change the activity profile to direct for the off road section and that section will effectively be a track imbedded in the route. Can't do it for long sections because of shaping point limitations though.
    PRW likes this.
  8. LewisNClark
    Apr 12, 2004
    3,568
    Thanks for responding - Cannonshot (and many others) did a great Pony Express GPX file he shared...but has 3 or 4 separate Track files within his one GPX file...and several separate Routes. I know, it's easy to Join Tracks into ONE track, but wondering why some done join them and leave several small tracks non joined in their gpx file. I think I understand about multiple profiles etc.
  9. CSpringsRider
    CSpringsRider Been here awhile
    Apr 17, 2015
    505
    Colorado Springs, CO
    Which GPS are you using? If using a Zumo XT, you can use the Trip Planner to convert the track to a route. It won't be called a "Route," it will be caled a "saved trip."
  10. bnschroder
    bnschroder Been here awhile
    Nov 4, 2015
    123
    Atlanta
    I have a hypothesis: older GPS units had limits how many way points per track they would process. So splitting tracks makes sense to manage them.
    FireDog45 likes this.
  11. CSpringsRider
    Apr 17, 2015
    505
    I've used mapstogpx quite a bit to convert Google Maps routes to gpx tracks and it does not seem to have any virus or malware issues. At least nothing that Norton has detected. FYI, if you are creating the loop route, the start and end point cannot be the same or you'll get an error.
  12. jfheath
    jfheath Tourer
    Sep 20, 2016
    101
    Ilkley, West Yorkshire UK
    A trip (converted from a track) behaves a bit like a normal route when navigating, but it has no Via or Shaping points. It comes from a track rather than from a series of intermediate routing points.
  13. renogeorge
    renogeorge Let's ride!! Supporter
    Apr 7, 2007
    6,901
    Reno
    Any tips on how to copy my Basecamp file setup (file folders, lists, etc) from one computer to another? Thanks
  14. ConiKost
    Feb 3, 2020
    259
    World
    Just use the fuction to create a backup inside BaseCamp and import that backup file on a new computer?
    CavReconSGT and renogeorge like this.
  15. smbjm
    Sep 24, 2010
    382
    If all you want is to copy the data file then just use Basecamp's Backup function, and restore I to the other computer.
    If you want to be able to access the same data from two computers then you should look at the write-up on the New England Riders website on using Basecamp with a shared drive.
  16. renogeorge
    Apr 7, 2007
    6,901
    Reno
    Thank You guys!
  17. LewisNClark
    Apr 12, 2004
    3,568
    Just in case you’re not familiar with “flash drives”. I use the basecamp Export menu option copy files to an SD card or Flash Drive. They use the import menu option to copy them on to the other computer. Also have a backup folder on basecamp computer and Export files to them folder, and can then simply Email the needed basecamp files as email attachments…use this same method to move files to my iphone.
    renogeorge likes this.
  18. renogeorge
    Apr 7, 2007
    6,901
    Reno
    Thanks for that. It was the backup and restore functions I wasn’t aware of. The file moving part I had figured out—kinda. Thanks
  19. Antti
    Antti Been here awhile Supporter
    Mar 14, 2003
    680
    Finland
    I`m moving from Windows to Mac.. how can I convert route to track on Mac?
    Just got new macbook Air with M1.. sweet but some things as stupid as only Apple can be :lol3
  20. FireDog45
    FireDog45 Squirrels get enraged when they see me naked Supporter
    Sep 16, 2006
    2,005
    Central, Ohio
    Right click on the route (control click if you don’t have a two button mouse)
    Select “create track from route”
    Once created you can double click on the track then click circled three dot icon (lower left of the info window) to make adjustments like filtering, inverting etc
    Antti likes this.
