Awesome. Thanks. It looks like City Nav is on my Surface Pro cause I can see it when the Montana is NOT connected. Now I will try to save Topo 100 to it. Thanks for the help.
Hmm. When I do that, I can only see City Nav. Is there a way to select Topo US 100K ? I would like to have that one installed on my computer too.
Well, I don't use Topo maps but I believe it depends on how you purchased the maps were purchased as downloads then I would expect you should be able to download them to your computer. If the maps were purchased on an SD card then they are registered to the SD card and can only be accessed from the card.
If it came on an SD card you will not be able to install the Topo maps to BC. You can, however, see and use them in BC when your GPS is plugged in to the computer. When you plug your GPS in to BC you should see it in the upper left pane "My Garmin Devices". Under the device name you'll see the media card and all the installed Maps. It may take a minute for it to access but there is a progress bar. Click on the topo map and it will then be visible in BC. Hopefully this made sense as I'm confused just re-reading it!
I am from Dover, Ohio. Ever get up to Amish country? If you have never been to the Warther museum, you should take a ride up there. It is amazing!
I downloaded Garmin basecamp today........... It only has mainroads. I wanted to see forrest service roads to start planning my trip WTH?
hmm.. section G, step 6 looks like this to me... as opposed to actually following the roads. i've done this a few times now and it comes up the same thing. what am i missing ?
thank you. when editing the activity profile options i must have inadvertently turned something off since i had the moto icon showing in the profile box. i reset the activity profile and it worked. now back to step 7..
I'm just starting my read, having bought a 390LM last week. A huge THANK YOU to Ed Conde and Steve Bruning!
Regarding new base camp. I see there is a new version out for MAC but I have 10.7 OS. My 2007 iMac will not run the fewer OS. It says to be used with new OS so has anyone running older OS tried the new Basecamp version just released??
