Battery Side Post -need help
Discussion in 'Equipment' started by Stroked 550, Jan 16, 2020.
  1. Stroked 550
    Stroked 550 Dirt Nut
    Nov 24, 2009
    1,993
    Outhere
    hey guys
    I need to install a battery side post so I can hardwire my onboard battery charger to it
    The problem I am having is that the battery cable ring has a larger diameter then the battery chargers terminal end so it does seat properly on top of it....
    I bought one of these side post adapters but its too small and I cant seem to find one that has a a bigger diameter ... where can I get one?
  2. bodine003
    bodine003 Long timer
    Jun 18, 2015
    1,580
    Melbourne Florida
    3/8 course thread short SHCS with a smaller OD flat washer. how my Cobra is hooked to my main side post battery in my 79 P-body
  3. Stroked 550
    Nov 24, 2009
    1,993
    Outhere
    I need to buy a different side post terminal, the one I have from napa has a diameter thats too small for my the battery cable to properly seat on
  4. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    15,711
    Silver Spring, Md
    I have been known to use anything that I can get to fit. Sheet metal screws, dry wall screws, small clamps, anything from my neighborhood hardware store. I might ruin the battery that's there or it may come out more permanent. We have these big deal inspection electrical rules here. I've failed several times but I'm good at debating mechanics at the inspection station. Been years tho.
    Here's a good rule I learned on this list I think. "Make all electrical connections mechanically sound and make all mechanical connections electrically sound." Come to think of it I may have gotten that from the Chris Craft forum.
    thirsty 1 and Boatman like this.
  5. Stroked 550
    Nov 24, 2009
    1,993
    Outhere
    its just shocking to me there is not a terminal kit that has a larger diameter outer ring from an online retailer
    I have been searching all day and have found nothing
  6. bigheadfred
    bigheadfred Do it in the Dirt! Supporter
    Mar 10, 2008
    37
    Intersec 522 & 322
    Maybe drill the terminal to fit the post then use the proper bolt.
  7. Stroked 550
    Nov 24, 2009
    1,993
    Outhere
    The terminal fits the post
    The problem is the terminal ring from the battery cable is too large to properly sit on the side post terminal
  8. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,110
    Mill Spring, NC
    There are a couple ways to "fix" your problem with proper stand off. A double male threaded like the one pictured. Or just a plain unthreaded (hole straight through) with a longer bolt.
    #8
    tire joe and Stroked 550 like this.
  9. Stroked 550
    Nov 24, 2009
    1,993
    Outhere
    what diameter should that bolt be?
    #9
