Battery Tender Chargers - No DeSulfinate Options?
Discussion in 'The Garage' started by River-Runner, Nov 8, 2019.
  1. River-Runner
    River-Runner Been here awhile
    Apr 11, 2010
    666
    Portland, OR
    Looking for another Battery Trickle Charger and only some of the new ones appear to list the desulfinate feature? The Battery Minders do offer this option.
    Has this feature been found not be beneficial or dangerous as all vendors are not offering it?
  2. showkey
    showkey Long timer
    Jun 25, 2007
    2,411
    Wausau
    Nothing 100 hours of internet reading to make it clear as mud.
    avocadofarmer likes this.
  3. Granitic
    Granitic Backcountry rider
    Oct 10, 2014
    975
    New Mexico, USA
  4. eakins
    eakins Butler Maps
    May 29, 2002
    36,153
    Fort Collins, Colorado
  5. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    9,649
    Kentucky-Eastern that is!
    My CTEK has that cycle and more. My Battery tenders do not. They are great until they die which has been my problem 4-5 times. Also the warranty can be less than you'd hoped for if the one you bought was older stock cause they look at the date codes when I lost my receipt or bought new on ebay. I have a Marinco(off Amazon) that is dual voltage and has nice features BT doesn't have but no desulph feature.
    If only one of the several I own have that feature I'm OK as it's not a must do on every battery very often,etc..
    My larger problem battery is my off grid sawmill but a full size battery so onery to tote to a maintainer location. It recharges off the Kohler engine but also sits around when not used.
  6. t6pilot
    t6pilot Been here awhile
    Feb 15, 2011
    665
    huntington beach
    eakins likes this.
  7. eakins
    eakins Butler Maps
    May 29, 2002
    36,153
    Yep mine really makes the rounds in the winter rotating thru my bikes about once a month. I don't winterize them as I ride them all occasionally. Works great to keep all 5 of my moto batteries in tip top shape.
    This charger and blue marine Stabil always in the gas are my winter tools to keep my machines running great.
  8. eakins
    eakins Butler Maps
    May 29, 2002
    36,153
    Make sure at times to let it run its full charge procedure and stay connected for 24hrs or so...until the light stops blinking.
    #8
  9. ttpete
    ttpete Rectum Non Bustibus Supporter
    May 13, 2009
    7,618
    Dearborn, MI
    I have separate Battery Tenders on all bikes, and they run 24/7. This works very well, and the 2009 and 2010 bikes still have their factory original batteries that have given no trouble. They are plugged in immediately when the bikes are parked.
    Sulfation does not occur if the battery is kept fully charged, and that's one reason for their long life.
    #9
  10. Mr. B
    Mr. B Slowpoke
    Oct 19, 2004
    2,503
    Minneapolis
    I seem to have a lot fewer battery problems than most people. I keep my bikes on basic battery maintainers like "Battery Tender" and "Battery Minder" year 'round. I tend to think the whole de-sulfating thing just might be a bit of marketing hooey, but I welcome evidence to the contrary.
    #10
  11. 2StrokesForever
    2StrokesForever Adventurer
    Nov 21, 2014
    22
    US of Anarchy
    My .02:
    I have three of the BatteryMINDER Maintainers/(alleged Desulphators). I got them through Northern Tool. IIRC, they were $49.99, marked down to $24.99--and that was a sale I saw fairly frequently. (I'm also one of their "Club Members" or whatever, so that does give access to better sales--not sure if that applies here.)
    Anyway, aside from their labels being darker colored, they look like this one:
    https://www.northerntool.com/shop/tools/product_200332201_200332201
    I just realized the linked one has the remote temp sensor option, but mine don't. It's not needed if the unit is at the same temps as the battery. I like that mine and the linked one both charge at only 1amp, as some I've seen charge at 1.5amp.
    While I'm not sure if this is the exact part number, I could check, if anyone's interested. But I don't have much experience with them, having used them only infrequently, until recently.
    And I can't vouch for whether or not the desulphation function actually works, I DID learn two not-great things about these types of "smart chargers."
    1. When the battery is under 10.6v (IIRC), due to the MINDER's circuitry, it will NOT put energy into the battery. Period. The battery must first be charged with an old school charger that "hums" when you plug it in (IME) or possibly one of the pricey, do-all combination units I read about, with 6v/12v/Jump or "Boost" start, and a range of charging amps. (And of course those oldies can charge at a "Trickle Charge" rate which, IME, is 2amps, at the lowest. You want to bring a dead or really dead battery back up as slowly as possible, like on a 2amp "trickle.")
    But, once you get enough juice back (10.6v) the BatteryMINDER's two lights will go SOLID red and SOLID green. This is good, as it means it's charging. (Once fully charged, the red light stays SOLID butr the green light starts flashing, steadily, letting you know it's (allegedly) in "maintenance mode" where the blessed desulphation is said to occur. You can also push a button to go into "Maintenance," but I don't see the point, as it won't do "Maintenance" until it's fully charged anyway, so I dunno....
    2. The lights will easily fool you (well, they did me) IF the battery is below 10.6v--or completely dead, as mine was. Because when hooked up like this, the lights indicate that the (actually, dead) battery is good and is already in "maintenance." In reality, nothing's going into the battery--as I found out, months later, the first time I used it.
    So that''s the fairly-short version. I need about three more units but, after seeing these capacitor problems in the BatteryTENDER, Jr. models, I think I'll stick with these MINDERS. But I know capacitors can cause a lot of problems--like make the ECU in Jeep YJ's stop running. A new computer is in the hundreds, but the capacitor is only $5. So says the interwebs--haven't had the pleasure with my Jeeps yet. They don't run for other reasons. ;-)
    I also bought the kits to make it possible to hardwire the Minder's optional on-board harness to the battery on the vehicle, so you can just plug/unplug. Worth it.
    #11
  12. eatpasta
    eatpasta Lawnmower Target
    Jul 5, 2006
    16,113
    Santa Barbara, Ca
    Just wanted to throw my hat into the ring on this one as I got an Optimate 3 about six months ago and its been fantastic.
    I thought for sure that the battery in my speed triple and the battery in my CB400F were toast. This thing brought them both back from the dead after no-dice on my conventional charger.
    here's my boring ass youtube review but it's got images of Triumphs and CBR's in it so :dunno
    #12
    2StrokesForever likes this.
  13. Grinder
    Grinder Wrong way 'round
    Sep 7, 2006
    3,334
    In DC traffic...
    Just a fair warning to those keeping maintainers always connected.... be sure to put that on a surge protector
    #13
  14. ttpete
    May 13, 2009
    7,618
    Dearborn, MI
    Why?? I don't like small surge protectors because they can start a fire. My whole house is protected by one on my QO breaker panel.
    #14
  15. showkey
    showkey Long timer
    Jun 25, 2007
    2,411
    Wausau
    Think the charger itself might be the problem ..........if they are the ultra cheap no name brand.
    Buy a quality brand name unit to start with. The likely hood of a problem is very very low.
    If the charger ( or any other device) over heats ( melt down) the breaker or surge protector will not protect charger from meltdown. Melt down failure due internal parts failure or high resistance will not increase the amp draw where the circuit breaker will trip. Similar to frayed extension cord or over heated wall socket.
    #15
  16. Grinder
    Sep 7, 2006
    3,334
    In DC traffic...
    Then you’re fine. You don’t want a voltage spike to travel through to the bike. This can fry an ecu but sounds like you’ve got it covered. None of the chargers I have will handle a voltage spike, say a lightening strike. Mine are deltran.
    #16
