Belt masters only
Discussion in 'The Garage' started by parannoyed, Apr 5, 2019.
  1. parannoyed
    parannoyed When in doubt, mumble.
    Mar 22, 2012
    279
    Westfield, PA
    Hey guys, found a broken belt on my dentist chair I use in the office.
    I need to know how to buy the correct belt to replace it. Which measurements are the ones I need?
    Also are these things rated for stress? It mates to the big electric motor to lift clients up, and some of them will not be easy lifts.
    Any help would be great. It's old, no part number interchange that I can find and chair company name is M.I.A.
  2. gonerydin
    gonerydin Been here awhile
    Feb 14, 2012
    376
    Iowa, USA
    SmittyBlackstone and parannoyed like this.
  3. parannoyed
    Mar 22, 2012
    279
    Westfield, PA
    Perfect, I wasn't sure where to measure the pitch. That link was a huge help. Thank you!
  4. Boomer343
    Boomer343 Been here awhile
    Apr 14, 2014
    677
    Calgary
    Shouldn't be too hard to find, just a cogged belt. I assume there isn't a portion missing and it just split.
    Take a look at this video
    The video is from Gates, more than likely they have one.
  5. parannoyed
    Mar 22, 2012
    279
    Westfield, PA
    Thanks, I think I did find the right belt. I appreciate the help.
  6. Beezer
    Beezer Long timer
    Oct 26, 2004
    8,795
    Anchorage, formerly Spenard (hub of the universe)
    must be one hell of a drill.........
    SmittyBlackstone likes this.
  7. parannoyed
    Mar 22, 2012
    279
    Westfield, PA
    LOL I wish. They wouldn't give me the fun attachments with the chair.
    Beezer and SmittyBlackstone like this.
  8. katbeanz
    katbeanz earthbound misfit, I
    Feb 12, 2005
    9,091
    Kansas City
    The curvi-linear we always called poly drive, but those and the timing belts will stretch a bit after they've ran a while. There's probably a formula for tension at the Gates link, but as a rule of thumb if there's reasonable distance between the sheaves, (lock out tag out) grab the belt mid span and if you can twist it 90 degrees by hand with a moderate amount of force it's about right. Too tight puts too much load on bearings, and too loose it may skip a bit, shuck off some teeth and break. They deteriorate with age, just like me. :D
    #8
    parannoyed likes this.
  9. cagiva549
    cagiva549 whats a cagiva
    Oct 10, 2004
    5,544
    Cypress Tx
    Number on the back should be all you need , if its not some obscure foreign brand any power supply house can cross it over to their brand .
    #9
  10. kantuckid
    kantuckid Long timer
    Nov 29, 2007
    7,864
    Kentucky-Eastern that is!
    Dentists that do wrenching on "the chair":rofl? Whats next?
    I go to a dental college for my own work U of KY) and hear the stories about costs of private practice equipment as one more layer of debt.
    Before I started getting my work done at the school, some years and many students ago, ALL my street dentists had an airplane & an exotic car and a set of clubs,etc.. Well, except the last one who had a bass boat and real conservative.
    #10
