Bent frame KLR650
Discussion in 'The Garage' started by apostis, May 28, 2020.
  1. apostis
    apostis Adventurer
    Jul 10, 2013
    59
    Hi,
    A few weeks after I had my new KLR650 it tipped over on an uneven surface.
    The bike was standing, fully fueled, had crash bars and panniers mounted.
    This happened over a year ago. I never had any issues but a while ago I have noticed this:
    Not my picture:
    The "ignition bump" does not align with the "frame fitting" when the front wheel is straight.
    Also, the rear wheel does not align with the rear light.
    Kind of like in this front picture (not mine):
    Where you can see that the front fender is a bit further to the left than the center of the wheel.
    Except for me it's the rear and it's probably more noticeable.
    I never had any issues, but I do wonder does that mean the frame is bent?
    And if so, is there a way to fix this at all? Is that a major repair? What kind of place would I go to to fix this?
    The bike is in perfect condition and like mentioned almost new.
    I find it strange that it tipping over from standing would bend the frame. I thought panniers if anything would prevent that.
    As for the rear part, I don't know whether the "tail" is off or the wheel.
    What do you think?
    Could that be something else?
  2. Chuck Pryce
    Chuck Pryce Been here awhile Supporter
    Feb 1, 2006
    539
    western n.c.
    The fork tubes may have slipped in the clamps , loosening the clamps up and realigning the forks should fix it.
  3. apostis
    apostis Adventurer
    Jul 10, 2013
    59
    Thanks for your reply. I'm not sure I get it though. Are you suggesting the handlebar may have shifted sideways? I don't think that would explain the indicator on the ignition being turned more to one side?
    Also there would still be the question of why the rear seems shifted too.
  4. mikejjmay
    mikejjmay Long timer
    Dec 15, 2008
    1,150
    Wisconsin
    My guess is if you never had any issues, and dont have any now, you didnt bend the frame. Your picture showing the alignment, is that a picture of your actual bike or a picture just showing how to align? on the 5 KLRs I have owned, nothing ever has lined up absolutely perfect. They are great bike but budget machines made at bottom dollar. If that picture is of your actual bike, it doesnt really seem to be off much there, and i dont think i would take a steering stem lining up with a fairing mount as an indicator of a bend in the whole frame. Honestly i bet if you had checked day 1 off the factory it would have looked the same. I would say just ride it!
    spokester and Beezer like this.
  5. PeterTrocewicz
    PeterTrocewicz Been here awhile
    Nov 18, 2009
    830
    Kincardine Ontario
    Chuck Pryce is saying that sometimes, depending on how the bars are turned, the forks can twist a bit when the bike falls over, or the bars can twist . Or it may have tweaked the faring mount. If so, its an easy fix. If the front wheel is straight when the bars are straight, then all's OK.
    If the rear wheel aligns with the front wheel when the front is straight, that's good. More than likely, all you've done is tweak the plastic fender, and plastic fenders are seldom ever perfectly straight when new as mentioned.
    As said, KLRs never were the best in fit-and-finish. Odds are highly improbable that you bent the frame.
  6. apostis
    apostis Adventurer
    Jul 10, 2013
    59
    I don't think the plastic fender is the issue because that never touched the ground. The whole rear part seems to be shifted.
    As mentioned none of the pictures are mine and the shift is more noticeable in mine in the back.
    The front is also very noticeable. The indicator part is off by about 5mm or so.
    I've had a KLR before and that one definitely didn't have any misalignment like that.
    I can imagine that the KLR isn't perfect even from the factory, but this just seems like an odd coincidence with it having tipped over and like I said it's very noticeable. Like half an inch in the back, maybe even more.
  7. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    7,875
    Southern Illinois USA
    Aline your sprockets, by shifting the axle one way or the other in the swingarm. Aline the fork at 90 degrees to the handle bars, by putting the tire against a tree and turning the bars. And ride, the frame isn't bent.
    BTW; You never told us how the second front flat turned out.
    https://advrider.com/f/threads/repeatedly-flat-front.1409424/
    Hate when people ask for help but won't share the final result that might help others down the line.
  8. Feo
    Feo Commentator
    Oct 21, 2006
    11,304
    Pansy's Palace, Illinois
    Can't really tell without seeing it, but sounds as if your subframe got tweaked in the tip-over.
    Not unusual, make sure that it hasn't pushed anything too close to the tire or chain (if it was a year ago and you haven't had issues you probably won't).
    If it worries you, strip the bodywork and pannier racks off the rear and investigate with a tape measure and maybe a framing square or other straightedge.
    I've manipulated several steel subframes back into usable shape with a 4-ft two-by-four.
    As the Charlotte weatherman says, YRMV.
    #8
  9. Mattbastard
    Mattbastard Lazy ass
    Mar 30, 2005
    4,989
    Tampa
    Exactly! Chances are here you won't get closure either.
    #9
    sieg and spokester like this.
  10. BtoV
    BtoV FNG
    Jan 11, 2006
    498
    Bakosfield
    I doubt you bent the frame in a tip over, this is what a bent frame looks like.
    Chalk line is centerline through the frame and the pointer is through the steering head. I have heard of Brit bikes having misaligned frames and needing to be straightened.
    #10
  11. BtoV
    BtoV FNG
    Jan 11, 2006
    498
    Bakosfield
    This is 20181223_140118.jpg after I straightened it
    #11
