1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
Best GPX-compatible GPS app for Android
Discussion in 'GPS 101 - Which GPS For Me' started by GravelRider, Mar 23, 2018.
  1. ohgood
    Sep 21, 2010
    10,151
    alabama
    see osmand, locus, oruxmaps. i like locus because it handles THOUSANDS of tracks and TENS OF THOUSANDS of waypoints very easily. no more plugging in to the computer to transfer ONE RIDE and then having to make room/etc afterwords. also, you have OFFLINE ROUTE BUILDING with locus (via the brouter app) that means when you find a bridge out you can build a route around it in seconds.
    gpx / kmz / kml and a lot more gps file types are supported by locus. you can also convert (export) to other file types with locus.
    check out the locus thread, it's long but very thorough.
    #21
    CapeMan likes this.
  2. petertakov
    petertakov Been here awhile
    Jun 19, 2012
    967
    @ohgood Does Locus do snap-to-road on GPX tracks - basically match the track to the underlying map and calculate a route along the GPX line and navigate it? I mostly use OSMand and it has a "snap to road" option for GPX but it can't do that (I still haven't figured out what this feature does exactly).
    #22
  3. ohgood
    Sep 21, 2010
    10,151
    alabama
    the definition of "snap to road" changes from app to stop, gps to gps.
    some will say it's putting YOUR POSITION on the closest road, even though you're actually off the road.
    others will say it's during the route building process, that each route segment is confined to the road, as you're building it.
    locus has this option in its navigation settings:
    it can build routes like this, keeping the tracks points on the road exclusively:
    and here's what it looks like using the snap to road option following a track:
    i probably didn't answer your question very well, sorry, i don't use that setting very often.
    #23
    petertakov likes this.
  4. petertakov
    Jun 19, 2012
    967
    @ohgood Thank you, OSMand'd snap to road feature looks exactly like in your second screen shot and is supposed to (I think) to link each and every shaping point of the GPX line to nearest road on the map and that is exactly what I want it to do but it just doesn't work for some reason :-))
    The reason I need this is because OSMand has an option to turn the screen off and switch it back on before an upcoming turn which is great for saving battery and dealing with device heat. The problem is that with GPX it can't differentiate between an actual turn (at a crossroad) and a sharper twist of the GPX line and as a result it switches on the screen almost constantly unless you are on long stretch of straight road but who wants to ride on such road anyway :-))
    #24
    ohgood likes this.
  5. ohgood
    Sep 21, 2010
    10,151
    alabama
    cool. i get around the "too many curve announcements" issue by placing waypoints at the important turns, then using the waypoint proximity alerts. it's really not ideal, but it allows me to follow a track and be notified of a waypoint approaching. it's not turn by turn, but it sticks strictly to the track instead of recalculating
    #25
    919nick and petertakov like this.
  6. petertakov
    Jun 19, 2012
    967
    @ohgood I gave up OSMand "navigation using displayed track" altogether and just follow the track. I hope this spares some battery but can't really tell.
    #26
    lanztek and ohgood like this.
  7. ohgood
    Sep 21, 2010
    10,151
    alabama
    @petertakov I've been watching the battery drain issues with interest. recently I've found some bugs that can't be explained /fixed, and always interested in new developments. the users always end up being smarter than the apps.... which is so cool to watch happen
    #27
  8. 919nick
    919nick Been here awhile
    Mar 12, 2009
    278
    Reidsville, NC
    I recently got a DF Pro and found the battery draining faster than the charger could keep up. I was also getting a message on the phone about slow charging. After a few emails with the guy at 3BR, I learned the the DF Pro uses the data line in the charge cable to negotiate the faster charge rate. Bought the TAPP USB outlet from 3BR and problem solved.
    #28
    petertakov and ohgood like this.
  9. PNWet
    PNWet Long timer
    Nov 2, 2014
    1,266
    Puget Sound, WA, USA
    Lots of options. I've used Gaia (iOS), Locus (Android), and OsmAnd (Android). I really liked Gaia but when I switched (i.e., saw the light) to Android, I tried both Locus and OsmAnd. I found OsmAnd drained my battery faster than Locus.
    I hear Maps.me, Backcountry Navigator, and others are good. Depending on your trip, Cartographia (Mexico) might be a good option.
    My uncle is a hunter, and likes US Topo Maps (Android).
    #29
    ohgood likes this.
  10. ramjet
    ramjet Long timer
    Jul 8, 2004
    3,024
    Super F'd Up N. California
    ohgood, I notice you have Max allowed deviation set to 500km, wondering why. So as not to interfere with finding new routes when off track?
    #30
  11. ohgood
    Sep 21, 2010
    10,151
    alabama
    I don't like things changing unless i request them to change. but yes, you're right
    #31
  12. mosey.levy
    mosey.levy Long timer
    Jul 13, 2013
    2,473
    NYC
    #32
    ohgood and PineLaneRider like this.
  13. chrish4ku
    chrish4ku Long timer
    Jul 30, 2009
    1,049
    San Leandro, CA
    So in Osmand, is it possible to import a "route" from basecamp in GPX format and then have the app "navigate" it ? I can import my route, but it just shows up as straight lines to each point...?
    #33
  14. chrish4ku
    Jul 30, 2009
    1,049
    San Leandro, CA
    To answer my own question, sort of, - http://www.gpsvisualizer.com will take a gpx file with a "route" or series of "routes" in your file, and convert them to a gpx containing tracks! Fantastic way to quickly convert routes to tracks. It also allows you to omit bringing in the 'waypoints' which helps unclutter the new tracks. My only issue with OsmAnd, is it can NOT properly handle a gpx file with mulitiple routes or tracks. Gotta pull them in 1 by 1 - hopefully that gets an improvement someday. The online planning tool is clunky, slow, and not intuitive.
    What I'd really like is a garmin Montana refresh, let's say - half the bulk, SPOT functionality, larger screen, easier custom map importing, wifi/bluetooth transfers, built in traffic, weather overlays, ability to see other buddies, voice commands, etc.
    Oh well, for now it's just a list of compromises...
    Ride on
    #34
  15. ohgood
    Sep 21, 2010
    10,151
    alabama
    Bc routes only exports the SHAPING POINTS plus start and finish. It relies on the good to guesstimate the path to take between them.
    Use tracks
    #35
