1. eNewsletter Sign Up
Best LED Aux Driving Lights (at a reasonable price)?
Discussion in 'Equipment' started by JimVonBaden, Dec 15, 2012.
  1. 16VGTIDave
    16VGTIDave Reaver made me do it...
    Nov 4, 2012
    1,397
    Drumbo, Ontario, Canada
    I recently picked up a pair of used Rigid Industries D-Series pod lights at a swap meet for $20. :wings They came with what Rigid calls "Surface" mounting brackets and the stainless hardware, but no wiring harness. They are a wide angle flood light, so not much effective range, but good for using as DRL's, cornering lamps, and my main concern: illuminating the sides of the roads where the critters are lying in wait at night.
    They weren't exactly what I was looking for, but the quality and price made it an easy buy. I won't cry if one gets damaged. And who knows what I'll find at the next swap meet? :dunno
  2. Bigbugberg
    Bigbugberg De oppresso liber Supporter
    Feb 15, 2010
    788
    1313 Mockingbird Lane
    Sometimes, like now, I wonder why I try to help at all... The lack of objectivity is astounding.
    Uke and SoggyDonkey like this.
  3. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    31,718
    The Berkeley of Arkansas
  4. JimVonBaden
    Feb 11, 2005
    88,552
    Alexandria, VA
    Seems reasonable. I wonder if they were claiming "50 watt equivalent"?
    flinders_72 likes this.
  5. mouthfulloflake
    Aug 21, 2008
    31,718
    JimVonBaden likes this.
  6. flinders_72
    flinders_72 Long timer
    Apr 21, 2008
    2,545
    Murtoa, Australia
    Even though I've had pretty good luck with most of the lights I've bought, given some of the claims made these days I'd always make sure they tell you what brand and model (eg, Cree on its own isn't good enough) LED is in the lights (not that there aren't fakes around) and the current draw. If those two things aren't advertised along with claimed Watts, lumens, etc, I wouldn't bother. I also wouldn't bother with low powered floods.
    50W halogen equivalent perhaps (although I know that's what you meant), otherwise you're comparing it with 50W of nothing.
  7. mouthfulloflake
    Aug 21, 2008
    31,718
    well, I bothered.
    they are less than $20 each, and brighter than the other cheapo LED lights I have on hand.
    Time will tell how they hold up, but they look as well made and as sealed up as any that I have had in hand.
    JimVonBaden and flinders_72 like this.
  8. wibby
    wibby BrotherFromAnotherMother
    Mar 20, 2005
    10,953
    Grass Pants Orygun
    92DFF497-C764-4901-B770-DD7248417B6E.jpeg Under $15 on eBay for the pair and completely happy with them
    I got to see an elk run across the road and off into to brush last night that the headlights alone wouldn’t have lit up
  9. lacofdfireman
    lacofdfireman Long timer Supporter
    Jan 29, 2008
    1,464
    St. George, UT
    Saw today Harbor freight now sells LED Cube lights for just under $20 each. Not sure I’ll be the first to try them out but it sure mount make returns easy with their return policy if they didn’t work out.
  10. flinders_72
    Apr 21, 2008
    2,545
    Murtoa, Australia
    Under $20? Why not. I presume this is for a single light and not a pair? One thing I'd be concerned about is the physical size of the light versus its lumen output - the output for each of the lights is very believable but under 1000 lumen from the 3" isn't enough for significantly better lighting and the others are too big for a bike for the output you're getting. I have a pair of 8" bars on my car that are now almost 4 years old (and were cheap back then) that I believe put out more than the HF equivalent in that video. The 3" is ok for DRL's but not much more unless you ride very slowly. Also, being flood or spot/flood combo they won't have the reach of pure spots.
    In this day and age I'd be hoping for at least 2000 lumen from a single 'bike sized' spotlight at any price and quite a bit more if it was a $premium product. Using my converted torch I'm getting 6000l (measured) from a single 2" light.
    By the way, looking at some LED torches the other day I see they've (allegedly) cracked the 100,000 lumen barrier. Sheesh.
    Wiely and Brun like this.
  11. phillyrube
    phillyrube Long timer
    Apr 7, 2010
    6,649
    Captive in Flatistan...
    Anyone making a full spot led light that throws like some of old pencil beam lights used to? Lucas, Marchal, Cibie, Hella?
    Alexander B likes this.
  12. Shaggie
    Shaggie Unseen University Supporter
    Oct 12, 2005
    4,088
    Christchurch, New Zealand
    Cyclops? @DRV does good work ! :thumb
    DRV likes this.
  13. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    16,375
    Tucson, AZ
  14. Dread
    Dread Putt-Putt Adventurer
    Sep 17, 2006
    627
    Boise, ID
  15. Dread
    Sep 17, 2006
    627
    Boise, ID
    On the bike.
  16. draco_1967
    draco_1967 Spoon!
    Aug 16, 2011
    539
    Salt Lake City
    I have these, and they are great for conspicuity, plus they actually work well in foggy/rainy conditions.
    https://www.amazon.com/dp/B07HR6BCLQ/ref=cm_sw_r_cp_apa_i_eo0wDbJG66P6M
    I have them mounted down low on my FJR:
  17. swimmer
    Oct 9, 2007
    16,375
    Tucson, AZ
  18. swimmer
    Oct 9, 2007
    16,375
    Tucson, AZ
  19. appliance57
    appliance57 Long timer
    Dec 11, 2014
    2,657
    Boston
  20. dietDrThunder
    dietDrThunder Why so serious, son? Supporter
    Jul 29, 2009
    1,614
    Nashville, TN
    Good plan.
    Also, if what you want is daytime conspicuity, you don't need to spend anywhere near that money. I used the lights linked below on my Tenere, and I covered them with the yellow film I've also linked. Total investment under $20 and absolutely excellent DRL functionality. THe LED color temp combined with that yellow film results in a highly attention-grabbing green/yellow, very similar to some of the super bright hi-viz material. I rode my bike for a couple of years and about 40k miles with these lights, always worked perfectly well, no issues etc.
    Ebay link to lights
    Ebay link to yellow film - this is enough for about 47 of those lights, but I never found it in a smaller unit size for less money.
    Here is a pic of the bike and how I mounted them (sorry I don't have a pic of them on, but I promise they work :) ). Note that they 're designed to be installed under stalk mirrors, but the heads swivel on a ball, so they're actually quite versatile re: how you can mount them. Hope this helps!
    Uke and flinders_72 like this.
