1. eNewsletter Sign Up
Best LED Aux Driving Lights (at a reasonable price)?
Discussion in 'Equipment' started by JimVonBaden, Dec 15, 2012.
  1. swimmer
    swimmer armchair asshole
    Oct 9, 2007
    16,421
    Tucson, AZ
    Thanks for your suggestion. Definitely considering this.
  2. swimmer
    Oct 9, 2007
    16,421
    Tucson, AZ
    I ended up getting these:
    https://www.amazon.com/Handster-Com...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
    Mostly because of their small size.
    My Africa Twin came with the lights found on post 1320 page 66 of this thread but they were mounted to crash bars which I have removed and at the new mounting location which is the Denali aux light mount they hang too low and I think the font fender may hit them if the suspension compresses a lot while bars are turned. Otherwise I would have just kept them.
  3. Bigbugberg
    Bigbugberg De oppresso liber Supporter
    Feb 15, 2010
    795
    1313 Mockingbird Lane
    These look identical to my Baja Designs Squadron Pro. Has the same white FR4 PCB, same housing, similar lens.
    Uke likes this.
  4. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    31,771
    The Berkeley of Arkansas
    yeah they do.
    at one point in time, a spokesperson from Baja Designs warned about buying them, saying they might be confiscated!
    So, I mean if you buy them, keep in mind, some people might try to take your lights at some point in time.
    hahaha
    they are pretty good lights for the money!
    Uke, flinders_72 and JimVonBaden like this.
  5. Bigbugberg
    Feb 15, 2010
    795
    I just measured the amperage of my BD SPros. At 12v they are pulling 8.3A for two. 12v*8.5A=102W or 51W each.
    The Alibaba version claim 50W per pair, so it seems the circuitry is different between the Alibaba version and the BD version.
  6. mouthfulloflake
    Aug 21, 2008
    31,771
    44 watts out of the two of these alibiaba lights.
    but these are too bright use in any sort of traffic, or city scenario.
    so yeah dimmed is the word.
    same PC board, similar looking lights... half the wattage is likely to last longer and run cooler.
    I am not racing in the desert at night.
  7. Bigbugberg
    Feb 15, 2010
    795
    A little less than half the watts but 1/20th the price!!!
  8. mouthfulloflake
    Aug 21, 2008
    31,771
    yeah there is that, Id like to compare some side by side
    I guess I should go to more rallys and stuff
    but I dont like crowds, haha
  9. Baroquenride
    Baroquenride Everyone dies, but not everyone truly lives.
    Apr 10, 2011
    3,949
    Clark Co, Wa
  10. flinders_72
    flinders_72 Long timer
    Apr 21, 2008
    2,566
    Murtoa, Australia
    I have no experience with them but the lack of specifications apart from '12V 50W' would make me steer clear. If they were legit they could set themselves apart from the rest by telling you the type of LED used and the current draw, among other things. There's a reason they don't.
  11. DCR1200RT
    DCR1200RT Adventurer
    Mar 14, 2009
    34
    San Diego, CA
  12. 2cati
    2cati Adventurer
    Dec 3, 2018
    39
    Canada
    How are these working out for you? Any feedback to share and photos?
    Look for to your reply!
  13. Eatmore Mudd
    Eatmore Mudd Mischief on wheels.
    May 28, 2012
    3,543
    Wet side of WA.
  14. Baroquenride
    Apr 10, 2011
    3,949
    Clark Co, Wa
    Thanks, I hadn't caught that. I'll keep searching.
  15. swimmer
    Oct 9, 2007
    16,421
    Tucson, AZ
    I put these on and am pretty happy with them. The size is perfect, they feel pretty stout (for whatever that is worth) and, while I have aux lights primarily for conspicuity, I am fairly impressed with their lighting capabilities.
    Shaggie likes this.
  16. ter240
    ter240 Adventurer Supporter
    Apr 9, 2016
    37
    Roanoke
    DENALI Electronics likes this.
  17. DENALI Electronics
    DENALI Electronics Been here awhile
    Mar 15, 2019
    188
    Exeter, RI 02822
    Those look great, and will definitely be noticeable by cagers coming at you! Would you mind if I put those pics on our vendor thread
    Shine On And Show Us Your High Beams
    I think people would like to see how they look on a mighty-mighty Tiger!
    Your Denali Design Team
    www.DenaliElectronics.com
  18. ter240
    Apr 9, 2016
    37
    Roanoke
    Sure thing. Always happy to support a good product.
  19. WindBlast
    WindBlast Jesus and Tequila
    Apr 1, 2007
    2,705
    Philly is ova dere
    I just bought some really inexpensive LED lights at Harbor Freight for my DRZ400S. Using the ubiquitous coupons I got two spot lights and the wiring harness (with switch, ring lugs, and fuse) for less than $70. I fabbed up some mounts and Bob's your uncle. They are a bit large and heavy but for the money they seem to be a bargain and are very bright. Draw is 15 watts each side. Time will tell if they hold up as well as Denali and Clearwater. The same setup can also be had at Tractor Supply for just a couple of bucks more if there isn't a HF nearby.
    Trailrider200 likes this.
  20. flinders_72
    Apr 21, 2008
    2,566
    Murtoa, Australia
    And thank you for putting in the relevant specs for the lights.
    Specifications:
    • LEDs: (4) 7-Watt Cree XPL HI
    • Power Draw: 2.3 Amps
    • Beam Distance: 375 Feet
    • Beam Width: 75 Feet
    • Raw Lumens: 3066
    • Intensity: Single Intensity Harness
    • DataDimâ„¢ Compatible: Yes
    • Operating Voltage: 12 VDC
    • Pod Size: 2.75in square x 1.97in deep
    • IP67 Waterproof & Submersible
