best sleeper torque wrench?
Discussion in 'The Garage' started by photomike, Jun 8, 2014.
  1. photomike
    photomike Top-notch MoFo
    Jun 10, 2006
    54
    The Great State of Texas
    Looking for a good qulaity, low-cost torque wrench to use on my Land Cruiser as well as the bike.
    I know that Snap On is really good and $$$. Anyone have any mid range quality torque wrenches that they have some experience with?
    Cheers,
    Mike
  2. pennswoodsed
    pennswoodsed lizards,bugs and me
    Jan 20, 2007
    1,033
    Reading,Pa
    Every wrench/wretch/tech in my age bracket has the 1/2 snap on clicker that they blew out for $100 , mine has been used at least 15 times . There must be many good used ones out there. Snappie can check them on the trucks for calibration . I have seen threads on here ? that point towards Craftsman's being as accurate.
    Luck,Ed
  3. rustycager
    rustycager Long timer
    Apr 13, 2013
    4,226
    Southern Indiana
    Check out the USA made husky at home depot. It's a armstrong or apex rebanded. I've always been told a big 1/2" isn't accurate for small stuff so look at getting a 1/4" or 3/8" also.
  4. clintnz
    clintnz Trans-Global Chook Chaser
    May 17, 2004
    5,002
    Rotoiti, North Is, New Zealand
    You'll have trouble finding one with enough range to do most fasteners on both a bike & a 'cruiser.
    I have a 40-200Nm Teng 1/2" & a 10-100Nm SP 3/8" that work good for mid range $.
    Cheers
    Clint
    Jack90210 likes this.
  5. k-moe
    k-moe Long timer
    Jun 27, 2012
    6,745
    44ยบ W
    E-Bay and garage sales are where you'll find the best deals on good tools.
  6. MotoChris521
    MotoChris521 motominded
    Aug 30, 2007
    3,182
    south west
    You really need three.
    3/8" inch pound
    3/8" foot pound
    1/2" foot pound
    Brand , yeah Snap-On are hard to beat , but $$$.
    But , i own a klr ,so it's Sears for me.
    cide1 likes this.
  7. _cy_
    _cy_ Long timer
    Sep 25, 2011
    6,845
    Tulsa, Oklahoma
    the best deal for torque wrenches is ... you guessed it used Snap-on in like new condition. if it looks worst than excellent .. pass .. unless it's got a recent calibration sticker.
    exception is dial type Snap-on wrenches .. those are almost never out of calibration. most folks don't like dial type torque wrenches in favor of clickies. so dial types can be picked up cheap .. most times under $50 for 1/2 drive.
    always keep an eye out .. last 1/2 Snap-on clickie torque wrench was scored on a local gun forum for $95 shipped. it arrived in NEW condition in original case. looked unused just like this ..
    bonified tool nut here ... beam torque wrenches are typically more accurate than click types. part of problem is folks don't unwind their wrenches, so spring takes a set. always unwind after use, unless you've got an internal beam clicker.
    here's pics of different types of torque wrenches, including several 1/4 in drive in lb. one beam 0-120 in lb, one screwdriver style 2-36 in lb and clicker style 10-150in lb.
    Snap-on electronic torque meter to calibrate other wrenches and to document precise settings. with 1/4in, 3/8in and 1/2in torque sensors. which are sitting on Snap-on 1/2 dr beam 0-200ft lbs
    note the in oz setting on Snap-on electrotorque meter
    slime and Lambo like this.
  8. plodalong
    plodalong Now if we just.....
    Jun 29, 2007
    818
    griffith NSW
    trouble with the Break type torque wrenches is users tend to forget to back off the adjustment setting. If they're left with the adjustment wound up they quickly go out of calibration. In a previous job I checked the calibration of aircraft tools and even Snapon get out of calibration.
    The deflecting beam type stay in calibration unless they're really abused. Warren and Brown deflecting beam types were very good and reliable, Not cheap but if you want consistent accuracy I guess you have to pay for it. In my experiance most automotive mechanics dont use a torque wrench except for head bolts and the like. With age and experiance you get a feel for how tight things should be and can't say I've ever had a problem with over or under tightening hardware.
    Warren and Brown website http://www.warrenandbrown.com.au/precisiontools/news_details/255
    #8
    spokester and JimVonBaden like this.
  9. _cy_
    _cy_ Long timer
    Sep 25, 2011
    6,845
    Tulsa, Oklahoma
    sounds like an excellent torque wrench .. but OP is looking for a deal on a low cost torque that's still quality. which eliminates new Snap-on .. but there's loads of used Snap-on torque that comes up at very reasonable prices.
    much rather spend say .. $125 for a used Snap-on beam type in like new condition vs a brand new mid priced torque wrench. would not even consider a used screw style torque wrench unless it's like new and/or have a recent calibration sticker.
    good point about remembering to unwinding screw type torque wrenches. otherwise calibration is quickly gone ..
    totally agree most experience mechanics only use torque wrenches on critical bolt/nuts like the LH crank nut to 133ft lb on KTM 200 I just did. had to use a Snap-on dial type 1/2 in torque wrench that works left handed.
    #9
  10. motu
    motu Loose Pre Unit
    Dec 28, 2001
    6,806
    New Zealand
    #10
  11. tirebiter
    tirebiter Been here awhile
    May 8, 2004
    501
    #11
    Gravels and REALGRAVEROBBER like this.
  12. mcma111
    mcma111 Long timer
    Jul 17, 2007
    17,716
    San Francisco,Ca.
    Amazon.com has CDI torque wrenches for even better prices than ^
    #12
  13. 2speed
    2speed Puching adventurer
    Mar 29, 2006
    940
    State of Maximum Density
  14. HanShotFirst
    HanShotFirst Been here awhile
    May 22, 2013
    534
    This...
    I can't say how accurate these are, but I've never had ANY issues with anything I've ever torqued with my Harbor Freight torque wrench. Admittedly I don't use it often, a couple times a year for the past 20 years, but mine has been very good. So good that I went ahead and got a 3/8" when they came on sale; just for giggles.
    But if you're constantly working on stuff that's really critical, then a used Snap-On that's been verified to be accurate is the way to go. Professionals need professional grade tools, simple as that.
    The home hobbyist needs good tools, but doesn't always need the best.
    #14
    slime likes this.
  15. Langanobob
    Langanobob Been here awhile
    Dec 23, 2006
    373
    Reno
    Are you sure about the Made in USA? I haven't seen a made in USA Husky tool since they became Home Depot's house brand. I hope you're right on this.
    #15
  16. rustycager
    Apr 13, 2013
    4,226
    Southern Indiana
    #16
  17. ttpete
    ttpete Rectum Non Bustibus Supporter
    May 13, 2009
    7,618
    Dearborn, MI
    Sturtevant beam type wrenches are accurate and can be found used. I have several, from inch-lb to a big 300 ft-lb one.
    #17
    REALGRAVEROBBER likes this.
  18. B02S4
    B02S4 Aye
    Mar 9, 2009
    2,110
    I prefer beam torque wrenches & find the Craftsmen 3/8" & 1/2" wrenches to be decent value. They also have dual scales for ft/lbs & Nms.
    #18
  19. SHEP_5
    SHEP_5 Been here awhile
    Jan 11, 2014
    965
    Western NY, somewhere between Buffalo & Rochester
    after some internet research and shopping around i bought this husky from home depot 3/8" drive and the 1/4" drive when i rebuilt my yamaha 350 motor, worked great
    and yes the 1/4 is made in USA i believe, i can double check but i dont think i would have got it if it wasnt.
    #19
  20. BossMaverick
    BossMaverick Been here awhile
    Jan 6, 2012
    285
    That's what I use. I wouldn't say that I prefer them to a quality and calibrated clicky style torque wrenches, but the Craftsman beam wrenches are priced well and work well for my purposes.
    #20
