1. eNewsletter Sign Up
Best way of tieing down a fuel bladder
Discussion in 'Australia' started by El Ponkin, Jul 15, 2011.
  1. El Ponkin
    El Ponkin Bloodrunner
    Oct 21, 2006
    3,157
    Brisbane
    Need ideas on the best way to tie down a 10 litre fuel bladder.
    I tried it yesterday in one of my Andy Straps Panniers but I only have the lightweight pannier frames and the bladder looks too heavy for it all.
    I didn't want to carry the weight up high but I guess the only option is strapping it on top of my tent roll on the back of the seat.
    So whats the best way of tieing it down, on carribeenas through the loops or ye big old ratchet strap straight over the bag a couple of times.
    Andy
  2. jardine
    jardine 86
    Mar 18, 2009
    1,542
    Gippsland
    I am in the same position so was going to do the same - on the tent roll behind me but using straps not clips so it can be adjusted??
  3. abhibeckert
    abhibeckert Long timer
    Feb 15, 2010
    2,032
    Cairns, Australia
    Don't own a bladder but plan to buy one... I'd use the eyelets *and* a couple of straps over the top. Seems the eyelets would be more secure, but I'd be worried about one of them failing.
  4. ciedema
    ciedema мотоциклист
    Oct 14, 2007
    2,329
    Boonah. Qld
    How far back are you putting your luggage on the seat/rear rack?
    I usually put them on the seat behind me and tie them on to my bed roll/top box.
    If it is only one 10l one it only has to be on for about 1 1/2 before you can empty it.
  5. Happy Snapper
    Happy Snapper GOMOB.
    Feb 14, 2009
    3,776
    Brisbane, almost heaven!
    Calling Goosefeather to the Batphone!
    He's done it on the way to Birdsville!
  6. Joe Watson
    Joe Watson Long timer
    Jul 20, 2008
    1,034
    Sunshine Coast, Qld, Aus.
    When I strap mine down I use a mini bungie net over all the stuff, but it is also tied down with the main strapping system too.
  7. LC8TY
    LC8TY must......find........fuel
    Dec 25, 2006
    2,367
    Carnarvon, Australia
    I use 4 el cheapo snap clips and run a couple of straps through them.
    The wieght is high but the 990 gets through fuel pretty quickly so it's not there for long. Normally I don't have that much stuff in the duffle bag and it sits down better.
  8. ciedema
    ciedema мотоциклист
    Oct 14, 2007
    2,329
    Boonah. Qld
    2 bladders for my big girl Birdsville to Windorah
    #8
  9. Goosefeather
    Goosefeather Captain Slow
    Apr 6, 2006
    1,041
    Brisbane, Queensland, Australia
    Until needed for the final leg, I carried the bladder empty in a pannier bag. When filled, I used cheap webbing straps and laced them through the loops.
    Travelling light, filled with fuel (put a tarp between rack and bladder due to paranoia about chafing):
    Travelling heavier on the return - full of water, trying to "defume" the bladder:
    #9
  10. bully1
    bully1 Long timer
    Jun 18, 2008
    6,135
    Perth west aussie
    cable tie it through the eyelets on top of your seat area, once you use it you can roll it up and put it elsewhere. On the GS I remove the rear seat and cabletie it to the rack that is left behind , then put my AAbagz on top, only have to take it off when I REALLY need to use the fuel.
    rule 1 : the only time you can have too much fuel is when you are on fire.
    #10
  11. Cruz
    Cruz Lost but laughing.
    Nov 3, 2008
    11,853
    Northside Brisbane, Qld Australia
    Andy, would 2 x 5 litre bladders be easier to carry, one in each Andy Strapp pannier?
    Bit late for you on your trip but thinking along these lines myself, is it easier to carry a couple of smaller ones than one large one that is harder to strap on or find a place for it?
    #11
  12. emil55
    emil55 sponsors needed...
    Apr 6, 2008
    82
    Kununurra, WA
    but I'll add mine. Got no photos handy but I use one of those cheap canvas army duffel bag things that's got backpack type straps. Loop the backpack straps through some pannier frame or something, stuff 1 or 2 10L bladders in and some wee bits of rope over it - bloody hard to buck off.
    #12
  13. Dr AT
    Dr AT Long timer
    Jul 12, 2006
    5,634
    maffra, vic
    I'd say the opposite- it's easier to use one that's too big and only partially fill it, rest it on the seat with the excess flap rolled up or just sit it over the seat and it makes its own pannier. I strap it using a couple of bungies across the middle, and if I'm going to be riding sand I tie the corners- again using bungies. I guess it helps to have the stronger turtle pack so you don't need to worry about chafing etc. I think I have about 15 litres in this pic.
    I remember terrry using 2 x 20 litre turtle packs in his andstraps panniers , trouble was he needed to empty them equally otherwise the bike ends up out of balance.
    #13
  14. gkNQ
    gkNQ Northern Adventurer
    Feb 20, 2009
    403
    Townsville NQ
    I use a rock strp through the bottom loops to the front of my rack and another rock strap through the top loops to the back of my rack. The bag does not move at all
    gk
    #14
  15. Goosefeather
    Apr 6, 2006
    1,041
    My experience with the bladder was that it holds the fuel in well, but not the fumes. Anything sharing the inside of a pannier with a full (or recently full) bladder will, unfortunately, get smelly.
    #15
  16. ciedema
    ciedema мотоциклист
    Oct 14, 2007
    2,329
    Boonah. Qld
    That's pretty much how I carry mine. Works well.
    #16
  17. ciedema
    ciedema мотоциклист
    Oct 14, 2007
    2,329
    Boonah. Qld
    Kaney how was your trip? Still spewing I missed out.
    #17
  18. Diggar
    Diggar GP Winner
    Oct 28, 2008
    385
    Fremantle Oz
    My 8 litre bladder leaked as I was filling it up in Carnarvon on the way to Gascoyne Junction.I had to cut short my trip through there as a result,but not deterred am going back,this time with 5 litre containers as a backup.My confidence shaken with fuel bladders.
    #18
  19. Afterdark
    Afterdark Gnarled Adventurer
    Apr 20, 2007
    402
    Brisbane
    What brand was it Diggar? New,secondhand,borrowed?
    #19
  20. Diggar
    Diggar GP Winner
    Oct 28, 2008
    385
    Fremantle Oz
    Newish,only used twice,unfortunately let me down first time in anger.I have returned to the people I purchased from over east and I hope we can sort things out.Pity about the trip though,but it is always about the journey ,not the destination.
    #20
