"Best" way to remove Scotchlite reflective tape?
Discussion in 'The Garage' started by duck, Feb 9, 2012.
  1. duck
    duck Banned
    Mar 19, 2004
    10,403
    Seattle (Berkeley with rain)
    Have some old dirty stuff on some side cases that I want gone. It comes off in flecks and I don't want to spend three years picking flecks off.
    Anybody here have a PROVEN way to efficiently remove it?
  2. Ricardo Kuhn
    Ricardo Kuhn a.k.a. Mr Rico Suave
    Sep 20, 2001
    17,054
    Minneapolis (don't even ask how i end up here.
    A head gun will take it off in no time at all
  3. Geek
    Geek oot & aboot
    Jun 8, 2003
    34,989
    8000ft.
    +1 heat.
    I removed a crap load of it from my cases last year.. warm it up with heat (I used a hair dryer) until the glue softens, then just peel it off (look at the bottom right corner in the photo below.. it was coming off in flecks before I hit it with heat)
    Hope this helps
    :freaky
  4. MisterPX
    MisterPX Been here awhile
    Aug 29, 2011
    143
    SE WI
    If you don't have heat, try starting fluid and a plastic scraper. Spray the edges, then small pokes at it, more ether, repeat. ether makes for quick clean up as well of the residue.
  5. mcstark
    mcstark Living brappy...
    Sep 12, 2008
    1,720
    Bflo, NY
    AlH likes this.
  6. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    5,866
    Hiding off Hwy 6, B.C.
    Most , if not all of them glue residues come off easy with alcool,but not the stuff you drink unless it is Everclear.:wink:
    Methyl Hydrate, soak it into a paper towel, apply to the glue "residues" and wait a few minutes.
  7. duck
    duck Banned
    Mar 19, 2004
    10,403
    Already tried some Goo-Gone and WD-40 but it doesn't seem to want to soak in to the adhesive very well.
    I've got a decent two level heat gun from Wagner so I'll give that shot.
  8. concours
    concours WFO for 48 years
    Dec 2, 2008
    7,359
    NH USA
    I know what you mean, the reflective material has no vynil backing... like license plate renewal stickers. I've had to use a razor blade scraper... and a little heat. If you are careful, keep the blade as flat as possible, the glue will act like a barrier against scratching/gouging. Good luck, that stuff sucks.
    #8
  9. H96669
    Nov 20, 2009
    5,866
    Plastic razor blades, soft & rigid, a fine American product.:clap
    No Alcool this time, Rustoleum Wax & Tar remover did just fine on some 3M Adhesive on pastics. Mostly Naphta that Rusto product.
    #9
  10. squish
    squish Out of the office.
    Dec 4, 2003
    9,104
    Where the Ghetto meets the sea.
    Is it really 3m? They make an adhesive remover for the auto body refinishing market. Works very well on glue residue not so much on the vinyl.
    Remove the vinyl with a little bit of heat and an old hotel card key. Then use the spray on stuff. Test it first as its designed to go on surfaces that are being preped for paint.
    Editted after post 11, not the red lable can,
    You want 080908 "Woodgrain and Stripe Adhesive remover"
    #10
  11. Rajin Cajun
    Rajin Cajun Been here awhile
    Jan 30, 2007
    833
    The DEEP South
    +1 on the 3M Cleaner. Works better than the Goo Gone!
    #11
  12. H96669
    Nov 20, 2009
    5,866
    ^^^^ Mostly Naphta, just like Rustoleum Wax & Tar remover and all them other pre-painting prep products. Fine products them for anyone painting motorcycle parts. Gets rid of that pesky sillycone.....no fisheyes please!!!:eek1
    Goo Gone sucks, waste of money that Citrus stuff, they try removing SOLAS tape with it at work all the time, big waste of taxpayer's money and time....:lol3 DON'T use "GOOF OFF" on plastics.:huh
    #12
  13. Joe3
    Joe3 Been here awhile
    Aug 25, 2010
    160
    Motor City
    I've also had bad experiences with GOOF OFF on painted surfaces. You really might want to test first in an inconspicuous area first.:deal
    #13
  14. duck
    duck Banned
    Mar 19, 2004
    10,403
    Plastic razor blades? Never seen/heard of those. Looks like just what I need for a project like this.:deal
    #14
  15. H96669
    Nov 20, 2009
    5,866
    Lee Valley Tools I think....Yes:
    http://www.leevalley.com/en/garden/page.aspx?c=&p=53612&cat=2,42194,40727
    Darn place to shop at, all very tempting.:cry But yes some of the gadgets/tools can be used on motorcycles.:wink:
    Very good selection of good zapstraps also...!
    #15
  16. ttpete
    ttpete Rectum Non Bustibus Supporter
    May 13, 2009
    7,611
    Dearborn, MI
    Xylene won't affect most plastics and is inexpensive. It's also the ingredient in Goof-Off.
    #16
  17. aussie_king_mick
    aussie_king_mick Been here awhile
    Jul 4, 2008
    166
    Sydney, Australia
    Eucalyptus oil, allowed to penetrate, will assist in the removal of adhesive labels. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    #17
  18. duck
    duck Banned
    Mar 19, 2004
    10,403
    Follow-up: Turned out to be very easy. I'm in the Coachella Valley in SoCal today so I let them sit out in 87 degree sunshine to heat up the adhesive. I used a plastic razor blade to start the edge peeling and then they peeled off easily from there. No heat gun or adhesive remover required.:clap
    #18
  19. H96669
    Nov 20, 2009
    5,866
    Plastic blades...I really like them. They have many uses such as removing ugly decals on windscreens or paintwork.Or even applying decals on Tool Boxes to get rid of air pockets.:wink:
    Share your source....I am Canadian but do shop in the USAs and I am sure some could be interested.:ear
    Lee Valley Tools good but....everytime I walk out of there that is $200.00 in a couple small bags.:eek1
    #19
  20. duck
    duck Banned
    Mar 19, 2004
    10,403
    Yeah, I'm sure I'll have lots of uses for them. Up until now all I've had for no scratch scraping is a piece of nylon some mech left in my brother's car when he had the windshield replaced.
    Source: FleaBay
    Item #: 170783078895
    Included: Scraper and blade with pack of 25 extra blades
    Price shipped: $8.29
    #20
